0 Members and 83 Guests are viewing this topic.
vrand
Quote from: xenomorphlabs on June 07, 2010, 01:18:47 PM
The thing is that it´s not that easy. Matrix-ru and Hvlabs have a couple of dozen experimenters that did exactly that in the course of this year with no gain after SR came up with his replication.
Part of the secret is the coil interconnection.
That and maybe +10 more differences that we can not see on the videos.
We all look forward to Jean-Louis Naudin continuing to show fellow "free energy" researchers, as he has done over the years, his exact circuit specifications so others can replicate this very interesting energy design.
Regards, Mike R.
forest
hmm...can we make it safe by manipulating output frequency ? I guess it is harmful because of wide band of output frequencies of low range.If we make it like Tesla working at ONE frequency for example 20khz then I guess due to skin effect we would eliminate dangers of huge power electrocuting impatient experimenters.
Still further we need a way to learn how to make it zero electric current device (cold electricity)
e2matrix
Also as I think I mentioned previously it may be important for the center rod (or heavy wire?) to be off center.  This was gleaned from info I found at hvlabs.  Most of the apparently working coils I've seen appear to have something coming out slightly off center.
   I would agree Naudin doesn't have a complete circuit yet compared to TK's and it would certainly be useful to get some better output measurements.  I also call BS to not post details of construction simply because it's dangerous.  Just post the warning in big letters and that's all that's needed.  Sheeeezzz it's dangerous to cross the street but if there's a warning what more is needed?
DreamThinkBuild
@Baroutologos,
From the book: The Gateway to Understanding: Electrons to Waves and Beyond
By Matthew M. Radmanesh
This is only a preview page but I found it interesting.
http://books.google.com/books?id=HwzXige6_WAC&pg=PA339&dq=displacement+current&lr=&cd=25#v=onepage&q=displacement%20current&f=false
"...9.7 MAXWELL'S QUEST
Having added the displacement current term to the first equation, Maxwell had a set of four electric and magnetic field equations in free space, which actually predicted that there could exist a "self-propelled and self-sustained electromagnetic wave motion". This set of four equations implied that any disturbance causing a changing electric field must produce a changing magnetic field, which in turn, must produce a changing electric field and so on and so forth. That is, energy is alternately exchanged between the two fields and the wave phenomena advances outward in this process..."
@Bolt, I know what you mean about heating. I run an outdoor furnace right now for heating in my house (water and general heat). I'm in a rush against time to find another method of heating because local town/state laws want to ban the use of outdoor furnaces to force you to pay for oil or grid electric so they can get their hands in the tax revenue. With a COP>8 this has got my attention. Even if we have to reverse engineer it.
@e2matrix, I won't show you how to butter toast because the butter knife has a sharp edge and it might be dangerous. I can understand the frustration but I also can see Jean's perspective of limiting liability. He should have a exclusion of liability form you have to sign before downloading the plans if he doesn't want any problems.
leo48
Warning lamps are lit only less than half power then the COP is less
8)
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
