joaouchoa and 217 Guests are viewing this topic.
ariovaldo
Quote from: zcsaba77 on June 18, 2013, 03:09:03 AM
Hi ArioValdo
These are dependent or independent devices from (wall) power supply?
Regards zcsaba77
They are saying and showing the equipment connected t to the grid. Probably, if the equipment is for good, they are afraid to say it is self-running...
verpies
Quote from: Zeitmaschine on June 18, 2013, 06:38:40 AM
So the suggestion is to heat up an iron core transformer by means of an induction heater resulting in more current out than in?
This suggestion makes some sense to me, because most heating in laminated transformer cores happens due to ferromagnetic hysteresis losses.
These hysteresis losses are the greatest when the core becomes saturated periodically.
IMO it is this external saturation of the core, that allows deep penetration of high frequency fields into the greater depth and volume of the core.
For example:
Only 0.1% of a 100kHz field remains at a depth of 0.1mm in electrical steel, that most LF transformer cores are made out of.
However, 91.2% of a 100kHz field remains at a depth of 0.1mm in electrical steel that has been saturated, because saturation decreases its differential magnetic permeability from 5000 to 1.
This is 912x increase in penetration depth!  ...a very significant increase, if you assume that the high frequency field does something in the core.
sparks
Is it possible to couple a primary tank's oscillations through a capacitor in series with a diode to drive a load that doesn't damp the primaries oscillations.   Tank-cap-diode-load-ground    I think the diode would allow any electrons accelerated out of the load side of the cap to not return when the primary side of the cap goes low.   So I would think that you would have to take and ground the load side of the capacitor to supply slow electrons to move from ground into the load side of the cap to turn into fast electrons slowing down in the load.
@veripies
    During investigation of the Steven Marks tpu it was determined that he was using a high impedance winding driven with dc to magnetically saturate the copper collector winding.  There was talk of pulsing the "control" coils at a frequency equal to the nmr of iron.  (never determined which isotope of iron)  If a neutron decay's inside the neucleus to a proton wouldn't the chiral bag burst and we get a fast proton also?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
