joaouchoa and 176 Guests are viewing this topic.
anandml
Quote from: zcsaba77 on June 19, 2013, 06:12:50 AM
Hi Anandml
One question: mr Akula speak english? if yes, I wanna contact with his, I wanna understood/learn, who the device work.
regards zcsaba77
I think Akula don't know English.  Just try to contact him via this web address http://my.mail.ru/mail/akula0083/ I tried to contact him via email  but he is not ready to reply my message. Otherwise just create an account in realstrannik.com after that contact with Tiger 2007 to get more details about this device. He is the another one person knows more details about this device.....
MenofFather
Quote from: Overschuss on June 18, 2013, 05:19:31 PM
@ Zeitmaschine
Da koennte vielleicht was dran sein, wenn man einem russischem Forum-Mitglied (PMOB11) trauen darf. Der behauptet naemlich, dass er nur 8W benoetigt, um eine 40W Gluehbirne mit voller Helligkeit leuchten zu lassen. Die Spule ist Bi-filar, Luftkern, 2 x 27 x 0,44 mm Cul.
Und hier ist die Schaltung:
PMOB11 use 12 volt battery and 0,5 amps is curent and 40 W bubl run on half, how he say. So 6 watts in. Inverter efficienty on that power can be 60 precents. Output is let say 10-20 W. He say, that perfect work without ground. Coils are half spiral, tick wire, how I remember.
MenofFather
Quote from: sparks on June 18, 2013, 10:44:26 AM
Is it possible to couple a primary tank's oscillations through a capacitor in series with a diode to drive a load that doesn't damp the primaries oscillations.   Tank-cap-diode-load-ground    I think the diode would allow any electrons accelerated out of the load side of the cap to not return when the primary side of the cap goes low.   So I would think that you would have to take and ground the load side of the capacitor to supply slow electrons to move from ground into the load side of the cap to turn into fast electrons slowing down in the load.
@veripies
    During investigation of the Steven Marks tpu it was determined that he was using a high impedance winding driven with dc to magnetically saturate the copper collector winding.  There was talk of pulsing the "control" coils at a frequency equal to the nmr of iron.  (never determined which isotope of iron)  If a neutron decay's inside the neucleus to a proton wouldn't the chiral bag burst and we get a fast proton also?
I think maybe key is heat. Stev Mark divice produce heat. So maybe in free energy divice be must heat? Akula also say about heating transformer. One men Fel, from one forum also make divice free energy based on Tesla coil, and say that in plase of inductor (who of 60 turns), wires makes heat.
sparks
Quote from: MenofFather on June 19, 2013, 11:43:01 AM
    Heat to my understanding is because of the internal vibrations of a molecule.  When the molecules reach a certain density the probabalitiy of the contracting and expanding molecular fields to  interact is increased.  These edge collisions cause the molecules to move in random directions.  In a contained system, pressure is the amount of collisions per second with the walls of the containment vessels.
My premise is that these molecular intrinsic vibrations impart inertia to the electrons.   When a gas is ionized (like in a spark gap) the ejected electrons will now respond to an external electrical or magnetic field whereas in the bound state this was not the case.  Ionizing radiation causes the molecules to become ionized and when this happens in an electric field,  the electric field accelerates them.  Upon conversion of the accelerated electron inertia to energy  (braking radiation emission)  a portion of the inertia going radiant comes from the heat vibrations of the parent  molecule.   I believe this is related to electrostatic cooling effects.  Coils with very high voltages present in the apparatus have been reported to form frost on them.  It appears that the heat is leaving the coils field  in the form of fast electrons.   This allows us to take low grade thermal energy and condense it or reduce the intensity of the thermal vibrations due to electron removal from the molecule.  Thermal photons are converted to radiant photons.  It is just an energy conversion process that is reliant upon molecular vibratory energy.  If I needed to get water out of the air like in a desert I would have with me a camper fridge.  I would focus a magnifying glass on a piece of metal where they put the electric heating element.  This takes heat from the inside of the box and transfers it to heat outside of the box.  This is called a thermal expansion system.  It takes the high grade thermal energy of the heating element and spreads it out with the inside of the box a conduit within the system that gets cold.   Then I would open the door every once in a while and gather up the condensated water molecules and drink em.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
zcsaba77
Quote from: anandml on June 19, 2013, 09:12:53 AM
Hi Amandml
You think if I reg on realstrannik, I will understand russian communication!?  :-\  ..and mr Tiger2007 also helpfull person?
regards zcsaba77
