0 Members and 177 Guests are viewing this topic.
Zeitmaschine
Quote from: elementSix on June 20, 2013, 03:02:34 AM
Could he be using the ribbon for some special properties and possibly use it for a Planar coil..
Yes. The special properties of these showcase elements are to distract the attention away from the parts the device is actually working with.
The device must be very simple indeed, given the fact, that this much junk is needed in order to hide it. 8)
Zeitmaschine
Quote from: screen on June 15, 2013, 09:06:20 AM
Patente for Captor de Elétrons in Brazil . Anexo.
I think »Captor de Elétrons« is a very meaningful name. So how to create a circuit that captures electrons from Earth?
What about something like that? It looks simple (to laugh) at least, although I have the feeling there should be a capacitor (or two) connected somewhere in that circuit.
Grumage
Quote from: Zeitmaschine on June 20, 2013, 08:45:27 PM
Dear Zeitmaschine.
What you have drawn there is a synchronisable Avramenko plug!! Just might be as simple as that :)
Cheers Grum.
Zeitmaschine
If the Earth is the negative plate of a (cosmic) capacitor and the sun is the positive plate of this capacitor, then it is obvious that we can't reach the positive plate, we can only connect to the negative plate of this capacitor. In order to do this a single-wire transmission line is needed. And that's exactly what the Avramenko plug is all about. The difference is, there is no man-made generator which provides the electric energy (Avramenko) but the Earth capacitor itself is the generator which provides the electric energy through a single-wire transmission line to a consuming device (Kapanadze and others).
Since Avramenko uses an AC generator for his single-wire transmission line but the Earth capacitor is DC, obviously something is needed to artificially alternate the current in order to transmit it through a single wire (grounding). I think that's where the thyristors (instead  of simple diodes) come into play. Not the source provides AC but the single-wire transmission line itself converts the DC of the source to AC.
idzaza
So far we archived no real result. I am not going to go through all posts, just though what I've seen and heard could be worth mentioning. Tariel said in one of his video recordings that it is a resonance in resonance, Akula also had inside the outer tube another tesla coil with its own primary and secondary. Then in the second video, again Akula had tesla coil(I thinq two TT) as he uses two inductors. How is Tariel's coil constracted in 2004 device we do not know, but in one video klip we all saw tesla's TT secondary coil which basically could be the one gets electrons exited and then he collects with third coil, which is placed between inductive and high voltage windings. I still do not know why he uses 220 volts, it might not be just for transistors.
This is just what I though this morning and could be worth experimenting. I am not an electrition so no need to argue with me about the way I tried to explain. Whoever knows about tesla's technology, should be able to understand what I just wrote.
Thanks
