0 Members and 210 Guests are viewing this topic.
VenomTT
HI everyone:
This look pretty similar to Donald L. Smith device.
https://secure.netsolhost.com/www.nuenergy.org/product_catalog.htm
And this is what I found on the internet research about him.
http://www.zpenergy.com/modules.php?name=News&file=article&sid=1078
I wish i would be true, because it is really simple to replicate, not like the TPU from Steven Mark.
Regards.
jeanna
@samedsoft,
This looks like a joule thief with a secondary which has been "tanked" and another transformer after the spark to a second secondary with yet another spark producing enough energy for the lights.
Basic joule thief with secondary (see Pirate's joule thief thread)
20TBase coil, 6TCollector coil , 0.18mm wire; 1800T secondary. (Hmm I better start winding!)
Transistor KT829A
Base resistor 3.8K ohm
Base cap C2= 0.01 MK? is that pF?
2 batteries in series, unknown voltage with battery cap.
T2 (Tank? 2)
L2 10T 0.35mm
L3 a bunch of words. -- can somebody translate, please?
This circuit has 2 diodes added to a RLC tank and produces a spark. I wonder why that is needed?* I suppose those words will help to explain.
Finally there are 4 parallel caps which work with the T2 L2 to produce another spark at SG2.
This is now regulated from 12v dc to 220 volts ac and lights the lights.
Is this right?
I would love to know those words.
thank you,
jeanna
* I wonder if the spark will raise the voltage even more than the joule thief, or if maybe they don't have the joule thief operating at peak potential.
In fact, a lot of that joule thief up to the T2L2 looks like a fuji circuit. hmm.
samedsoft
Dear Jeanna,
   Thanks for your interest on Russian picture, I found this on Russian forum via translator... Somebody suggests that this is the system used in Tariel Kapanadze's system
   I dont know Russian indeed.. We need a Russian speaker to translate the notes on the picture..
   I guess from this that Germans have replicated Mathertiha and converted to Tesla's system??
Dear Harti,
   http://translate.google.com/translate?prev=hp&hl=tr&js=n&u=http://www.hcrs.at/TESTA.HTM&sl=auto&tl=en&history_state0=
xenomorphlabs
Wow ! Groundloop, that circuit is fascinating !
I can try to find IR2106, 7812, LM741P descriptions to simulate it in SPICE, but i agree that it should work as intended.
Very exciting to soon see the first prototypes of this soon built by some of the contributors here.
Groundloop
@jeanna,
The first stage is a oscillator with a high turn output transformer,
just as a Joule thief, as you said. The two
diodes is series is just a way of getting a high voltage
diode. If you use the 1N4007 then you can handle up to
1000 volt. With two in series you can handle 2000 volt etc.
The first stage outputs high AC voltage and the two diodes
make that AC to pulsed DC. The capacitor will charge up and
when the voltage is high enough, the spark gap will go off,
thus putting the capacitor in parallel with the next coil.
If you want a more powerful Joule thief, then just buy one of the attached toys.
The neon sign runs from 4 AAA batteries. (6 volt.)
Attached is a small circuit I've been working on. Not finished yet. Will report back when completed.
The first part of the circuit, right up to C1 and C2, is the actual circuit
found inside the neon toy.
Also attached a image that show the inside of the neon toy.
Added the small tesla coil I have added to the neon toy. Waiting for
the glue to cure. :-)
Groundloop.
