0 Members and 271 Guests are viewing this topic.
zcsaba77
Quote from: Сергей В. on June 24, 2013, 08:28:47 AM
Some of his videos on the Search Engiine Yandex.ru  :D
http://video.yandex.ru/users/akula0083/
Hi Sergej
Can You translate or subtitling to english these videos, I do not understand too much (except numbers and usual russian words)
Quote from: verpies on June 24, 2013, 09:40:21 AM
Most users of this forum do not like to read about this operating principle because it implies energy from matter conversion (in the copper ring/tube).  It was discussed here before and almost everyone hated it, despite complete lack of rigorous critique.
Hi Verpies
Example I not heat, these energy from copper ring or tube (or NMR), just I cant understand how realy these stuff works, I opened for learn, but I still have not found patience teacher  :P
regards zcsaba77
Zeitmaschine
Quote from: Сергей В. on June 24, 2013, 02:54:11 PM
In Italy Dr. Umberto Stranieri, started Energetic Revolution with his magnetic propulsion generator called E-MAG (EUROPE-MAG!!). Soon the whole Europe will burn in Free Energy Flames !! LOL !! :)
Not Free Energy if I have first to buy an expensive device from a company.  :(
elementSix
Now I hope this doesn't get everyone off topic, But if you used Tesla's Patent,  Method of utilizing radiant energy.  What would happen if you used a thin walled copper tube with a good dieletric  on the inner walls of it and used that tube as a vacuum tube/  Roentgen tube.  Use Hydrogen or oxygen maybe..  Would that change the effect you want or is a glass tube the only way to get Multipactor effect.   molecular polarization process is step one in achieving that I believe.  There are very strange effects with those processes.    Multipactor effects, do cause a very large magnitude of electrons to be released, and the setup used in experiments have the device setup just like Teslas Radiant Energy collection with the Ray Tube.  Having Resonance is needed to achieve the high outputs of secondary electron emissions.  The energy coming off this setup is very very hard to measure and it makes the amp meter jump all over the place.  In the small plastic box that Stivip(Weasley) saw when he went to Geargia.  There was an oil burner device that is the same device used to create ignition in the vacuum tube.  Below are some links to info on how this Secondary Electron Emission takes place and how it is achieved.  Good Luck   E6
    ps.. TK did say that Vacuum Tubes would be the best option to use in the Device, but he said they wouldn't last more than a thousand start-ups or hours.  I'm not  sure  which..
http://en.wikipedia.org/wiki/Multipactor_effect
http://www.scribd.com/doc/39121161/Secondary-Electron-Emission-by-Bruce-Darrow-Gaither
http://www.teslauniverse.com/nikola-tesla-patents-685,958-utilizing-radiant-energy
The multipactor effect is a phenomenon in radio frequency (RF) amplifier vacuum tubes and waveguides, where, under certain conditions, secondary electron emission in resonance with an alternating electric field leads to exponential electron multiplication, possibly damaging and even destroying the RF device.
The secondary electrons are not moving very much after they are multiplied.So they have low voltage—but they DO have AMPERAGE because of the presence of lots of electrons.
elementSix
Thanks for the RealStrannik link Cepren..  This 2013 Patent seems to have been given to a Russian.  He has beaten Tariel Kapanadze to the patent office.  Or has he.  I don't know if it was the only way to get around the sensors, but it doesn't really say it creates more out than in.  They might have only got the patent this way.   If not, WTF is this invention for???
https://www.google.com/patents/US8363426?dq=electromagnet+hi+frequency+us&hl=ru&sa=X&ei=nE63UbiMPKnV4QTvtoHADA&ved=0CFcQ6AEwBTgK
forest
"It appears the reactive power has the same nature, as an active electric power, but arising from a resonance of inductance together with electric capacitance in the power network system, and is always directed back from consumers to their power station generators i.e. contrary to a working current from generators. It causes networks overheating and huge additional quantities of fuel wasting for its compensation"[/font][/size]
[/font][/size]
well it was known  for decades , beside isn't that what Tom Bearden was forcing every year  ? DON'T KILL THE DIPOLE or it will beat you. All solid state ou devices I know are using reactive power in resonance. Even in generators we have magnetic dipole which is broken on each shaft move exactly like described in Energy from Vacuum series videos by Tom Bearden - and again back to 1902 there is Figuera patent descibing the same (don't kill the attraction between magnetic  dipoles (iron cores))and a simple generator with motionless cores. Once more ask yourself : what is the dipole ? isn't that the implementation of Newton law [/font][/size] ::)
