0 Members and 78 Guests are viewing this topic.
slapper
Quote from: baroutologos on May 03, 2010, 07:10:17 PM
Then the lamp is lit by appling it to copper tube endings! Have not seen anything like that before. By
the way, i spent few hours with it and i concluded that the tube acts as one turn to the parallel winding.
Any ideas if this single turn would be a good primary for an autotransformer?
Another dumb question. Is the gray tube that Naudin uses for the Kapagen plastic or steel?
I've been blamed for seeing patterns where none exist.  :-\
Thanks.
nap
we are not alone :)
e2matrix
I'm quite sure that gray tube is an insulator (definitely not steel) and very likely schedule 80 PVC pipe or similar.  Inside the pipe though I think an iron, ferrite or heavy copper wire is making a single run through the middle (but offset a bit).
slapper
we are not alone :)
slapper
Okay. I get it. Schedule 80 PVC with perhaps a metallic
tube in the inside. That's where the clamps come in. doh
Sure wish we could narrow down on that material.
Thanks.
nap
we are not alone :)
bolt
nothing fancy about the tube you can use a cardboard tube work just fine.
