0 Members and 92 Guests are viewing this topic.
stivep
Notes from myself to myself :) heeee
QuoteWesley:
Video 6 is excellent, as well as all of the others. Thank You very very much for your expertise, time and efforts.
QuoteI had a couple of questions:
1. What is the voltage amplitude of the RF excitation
The voltage excitation depends  from coupling between transmitting coil and receiving  coil( that do not have to be a coil any conductor will do it- the wavelength of the receiving circuitry is important
You may add variable capacitor to tune but without any indicator  it is worthless- unless your lightbulb in parallel to Colman tube acts as one.
So for simplicity I would use not tune - just accept that I must give more of power from transmitter( output tank of  PA) for more power level to be at Colman tube.
Control of SWR at output is a must
Remember Colman is not only  electricity but key to alter the matter.
It is just tip of an  iceberg that  we are dealing with.
Andrea Rossi gets copper out of nickel
that by itself is prove of "being a God" a creator who plays with atomic structure of nuclei.
sounds unbelievable?
Maybe for some of you but not for me.
The first  what I suggest to myself is to play with solids :)
As SWR is varying due to mismatch of impedance and receiving part is not tuned than the only transmitting part is using tuned  tank.
At some point you dealing in inductive character of that circuit  and at some other in inductive one
There is always high voltage at the antenna if there is any if circuit  has capacitive character.
From receiver point of  view it is not important as coupling is suggested to be air.
Permeability of air is=1
The important is to know that as impedance of any circuit of receiving part of Colman tube is unknown and it changes due to  frequency  change than effective power on the receiving part is always smaller or extremely small comparing to transmitting power.
There is also Colman tube by itself (if conductive)  adding its   combination of impedance related to signal of incident detected in brass contacts of glass tube.
Quotefrequency (received at the tube containing the compound)?
It is from 10MHz to 500MHz but tank( antenna tuner) by itself is made for 100-500MHz but do not forget  about harmonic components of the signal.
Also amplifier is made to work from 100-500MHz however it performs somehow OK from 40MHz with big SWR.
Quote2. What is the signal voltage amplitude of the (27, 142, 222) !important]signal generator that you are
driving the 100w (100 - 500mhz) amplifier with?
It is HP3200B -http://thehistoryofrecording.com/Test_Equipment/Manuals/HP/HP3200B.pdf
everything is there.
The reason I am asking is that I ordered an (Isrial  made) 316 mw (100 - 500 mhz) amps on E-Bay, (which I have received),
My signal generator puts out 1 volt P-P. And I get around 2 volts P-P out of the 316 mw amp. I believe that the 100w amp that Is coming is identical to the on that you are using, and was wondering what voltage output, and voltage  input you would expect.
WOW WOW WOW. be careful!!
this amplifier is as easy to ruin as we speak.
1-use attenuator at input is a must ( as in my video)
2. never start from big power from signal generator
the driving power is about 35 mW
3. voltage is not that important as is power output from your signal  generator
4. NEVER use  amplifier without the heat sink goooood radiator as in my video
http://www.youtube.com/watch?v=WpBpk1Cg7ns
5. control with your hand  the temperature of amplifier with screw in   sink to it.
6. control voltage it is 28v( could go from 24-29V)
7. Do NOT!! USE STEADY CARRIER YOUR AMPLIFIER  GETS NO REST AND IT WAS FOUND THAT COMPOUND RESPONSE IS BETTER IF PRIMARY  GENERATOR IS INTERRUPTED BY MODULATINMG SIGNAL FROM ANOTHER GENERATOR FROM 5-60Hz
QuoteBy the way, It's not to difficult to cast a lead box and a lid using a wooden mold.
Well not only the box but helmet as well !!
I have read that the best thing to coat the mold with is(Liquid (27, 142, 222) !important]GlassMetallic) Seal-Up. (Radiator sealer). It has Sodium Silicate with a lot of copper suspended in it. (A small box takes around 40 to 50 pounds of lead.
Again: Thank You:
Thank you too.
Wesley
PS all of 7 point of  Legal Note  from my previous  posts  apply.
stivep
WELL THIS WHAT IS PUZZLING ME is light bulb raped-up . I do not buy 60W.
But motor by itself combination is intriguing from the point of frequency of repeatedness
of this kind of videos.It must be something in it
So say light bulb is modified light bulb till we find otherwise.
the two cores are as close as possible for magnetic flux to pass. Eddy current  is another  question.
the available literature is l 3 coil transformers with modified core. Dr Peter Lindemann motors
Thane transformer-Thane C. Heins
I did what I was ask to do.............. It does not give harm to some exercising their knowledge in area of motors.
The only valuable I found in this video is  similarity to known art.
I do not take stand on it  but I believe it is worth watching.
energy must come from somewhere and be converted  to something
there is another reason  why I did not discard this video.
And that is  the gentleman  from China  hands  flipping  motors at 90 degrees and still there is no change in speed. If we have been dealing with hidden influence than polarization of the field  makes  response at output on the receiver part. I suggest to see rotation in slow motion maybe you will see what I have did not noticed.
What is negative factor is:
that under load there is no change in speed at all.
that sounds unreal but only to load part of it.
http://www.ebay.com/itm/RMOTEA433WRZZ-SHARP-MICROWAVE-OVEN-FAN-MOTOR-120V-60HZ-/181161903046?pt=LH_DefaultDomain_0&hash=item2a2e1743c6
yes that is almost the one the only difference is that Chinese has metal bracket from both sides:
http://www.ebay.com/itm/RMOTEA294WREA-SHARP-MICROWAVE-FAN-MOTOR-/290460908088?pt=LH_DefaultDomain_0&hash=item43a0d1ba38
some other craps
http://www.youtube.com/watch?v=P-a8QAeCoNU&feature=c4-overview&list=UUgUBFNW5fUfO6IQbaoaA5Mg
Ansis99
Hi! Similar device we see on wits2014 YouTube channel. There "voice" speaks about 220V and 210V- difference between one and other coils. I don`t know. Sr. Timothy say nothing about his inventions. :-( Sad, but it`s true! Donate and maybe there some light will shine in the end of the tunnel :-) .... I think He do great job in Philippines- spread the Message of Jesus Christ :-) P.S. I know only 1 thing- coils are winding in "special" way. That`s it.
http://www.youtube.com/watch?v=EYnWWyAuVIk
Wesley
minde4000
Here we go. I went and got 4 of them - 2 different pairs. I have tested 1 pair only.
Used caps: 2.72nF  - 1uF - 3.3uF - 4uF - 8uF
Inductance:   304 mH  @ 100 Hz    (BK Precision 879B)
Resistance:    18.8 ohms                  (Fluke 87V)
I tried to switch out leads cross them and else. Besides I use another motor to speed this one up to 1500+ rpm and as soon as I let it goes into freewheel for a second or two and then stops.  It stops at same phase regardless of short crossed or even disconnected. Cost me $5 a piece so no harm... Connecting belt is pretty loose however does not slip and in the same time does not load bearings. Does not work for me simple as that.
Minde
x_name41
