0 Members and 72 Guests are viewing this topic.
penno64
TEKTRON
Quote from: stivep on July 09, 2013, 05:04:33 PM
some other craps
http://www.youtube.com/watch?v=P-a8QAeCoNU&feature=c4-overview&list=UUgUBFNW5fUfO6IQbaoaA5Mg
Wesley
I can understand the need to slowly load the unit but the shut down procedure is uncalled for. We need to see the system wind down. Just unplug the motor from the light socket if this is not a hoax!
TEKTRON
Quote from: minde4000 on July 09, 2013, 07:14:50 PM
Here we go. I went and got 4 of them - 2 different pairs. I have tested 1 pair only.
Used caps: 2.72nF  - 1uF - 3.3uF - 4uF - 8uF
Inductance:   304 mH  @ 100 Hz    (BK Precision 879B)
Resistance:    18.8 ohms                  (Fluke 87V)
I tried to switch out leads cross them and else. Besides I use another motor to speed this one up to 1500+ rpm and as soon as I let it goes into freewheel for a second or two and then stops.  It stops at same phase regardless of short crossed or even disconnected. Cost me $5 a piece so no harm... Connecting belt is pretty loose however does not slip and in the same time does not load bearings. Does not work for me simple as that.
Minde
Minde, I thought I read somewhere the drive motor has to be 220v and the driven motor 110v. But I wouldn't waste any more time or money.  ;)
stivep
stivep
Please disregard this note as below that  is asking for participation
-as it is no longer valid:
Quote from: stivep on July 10, 2013, 02:11:06 AM
QuoteThere was so many similar construction designs to the point of response requirement.
I'm asking to participate in  it by posting all of  other  designs similar in nature and your response to  it.
My personal  opinion can not come prior to me analyzing it.
Please notice that only one of coil connection ways makes  motor to turn.
60W light bulb, unknown voltage and unknown current  as of yet.
Light bulb is sort of interesting by itself
Please include links related to  3 coil transformers or modified transformers.
As this experiment is so easy to replicate  I assume that there would be many of you checking it  up on the spot..
There is also need to find exactly the model number of  motors  used in experiment.
What I have noticed is that windings are exposed so  natural  question would  be if original winding was altered or not.
Recall 3 coil transformers
Dr Peter Lindemann motors
Thane transformer-Thane C. Heins.
回想3线圈变压器
彼得·林德曼博士电机
领主变压器领主C.海因斯。
由于这个实验是如此容易复制,我以为会有很多你当场检查..
还需要准确地找到实验中使用的电机的型号。
我注意到的是,绕组暴露,所以很自然的问题是,如果原绕组被涂改或不。
有这么多类似的建筑设计的角度响应要求。
我要求参加张贴所有性质类似的其他的设计和你的回应。
我个人的意见之前,我不能来分析它。
请注意,只有一个线圈连接方式使电机转。
60W的灯泡,未知电压和未知的目前尚未。
灯泡本身是一种有趣的
请包括3线圈变压器或改性变压器相关的链接
Additional information:as of 7/10/2013 ( one day  after publication of that Chinese video by me)
based on quick analyzes I Wesley  have not found merits or basis for that Chinese device to work from theoretical standpoint but there is need  to practically conform that thesis.
附加信息:截至2013年7月10日(一天公布后,中国的视频我)
基于快速分析,我卫斯理没有发现优点或从理论的角度来看,中国设备的基础工作,但有必要切实符合该论文。
有任何支撑因素,从实际的角度来看,是不存在的证据
韦斯利
Wesley
Additional information:as of 7/10/2013 ( one day  after publication of that Chinese video by me) 2 hours after posting statement  from  theoretical standpoint now I post it from  practical standpoint as well.
Based on quick analyzes I Wesley  have not found merits or basis for that Chinese device to work from  practical standpoint as well
There is no evidence of existence  of any supporting factors from practical point of view
and there  is no evidence of that device ever be able to work.
Based on evidence:
voltage conversion to rotation is rapid and has no steady delta T equal or similar to normal  operation of the motor that means that kinetic energy as primary inertia  does not correspond with created EMF able to carry on  60W ( even if that happened  for load connected  for period of  few seconds )
however reverse  of the same should apply: that means rotation conversion to voltage picturing  one from above.- and it is NOT!
The wire gauge is insufficient to carry on predicted current.
The practical replication does not work as well without any modification and modification of any sort is not a part  of  video.
Wesley
附加信息:2小时后发布声明从理论的角度来看,截至2013年7月10日(一天我公布后,中国视频),现在我发布它从实用的角度来看也是如此。
基于快速分析我韦斯利还没有发现优点或从实用的角度来看,中国设备的基础工作以及
有从来没有证据表明该设备能正常工作。
基于证据:
电压转换到旋转迅速,没有稳定的温差等于或类似的表示动能的电动机作为主惯性不符合创建EMF能够进行60W到正常操作(即使发生负载连接期间几秒钟)
但是扭转相同的:这意味着旋转转换成电压生动描述从以上。 - 它不是!
线径不足进行预测电流。
实际复制不起作用,也没有任何形式的任何修改和修改不属于视频。
