0 Members and 74 Guests are viewing this topic.
baroutologos
Hoppy
T-1000
Quote from: xiaoke2727 on July 10, 2013, 03:28:41 AM
1,链接两个电机的材料,用导体,形成闭合回路,阻碍磁力线穿过,延时作用
2.皮带轮换成直径比较大的
3,皮带尽量宽松,减小阻力,视频里的转动很灵活
4,电容用0.68u
这是我的建议,但是我并没有实验过
我生活在山区,购买实验器材非常麻烦,最快也要7天
china
王刚
Quote from: minde4000 on July 09, 2013, 07:14:50 PM
Here we go. I went and got 4 of them - 2 different pairs. I have tested 1 pair only.
Used caps: 2.72nF  - 1uF - 3.3uF - 4uF - 8uF
Inductance:   304 mH  @ 100 Hz    (BK Precision 879B)
Resistance:    18.8 ohms                  (Fluke 87V)
Ok, As I was mentioned in previous posts, here is my quick video analysis what raises more questions :)
The Chinese MG looks like is looped over magnetic field and over LC resonant paralel circuit which should make a bit out of phase oscillation in this setup. The high voltage generating coils usually express speedup effect when loaded up on certain frequency range.
Also what I found interesting in that video, there are insulated wire 3+2 turns coils in addition to the 220V coils and my question is - why it is there and is it shorted? If shorted, may it be on purpose to create additional in-phase magnetic field for cutting off main coils out of magnetic path from rotors?
TheCell
Have you never seen this type of motor in washing machine pumps , older turntables, ventilators. It generates the 2nd phase by this shorting wires. Normally a run cap is used for that in induction motor, or whats called a asynchron motor. This type of motor is an asynchron motor, but without run cap.
verpies
Quote from: T-1000 on July 10, 2013, 07:45:37 AM
Those shorted coils are the shading coils.
Their purpose is to create an out-of-phase magnetic field over a portion of the magnetic pole (not an in-phase field!).
This secondary phase-delayed field together with the main primary field forms a 2-phase rotating magnetic field, that is useful for starting the motor.
For more details see here and here.
