0 Members and 113 Guests are viewing this topic.
verpies
Quote from: Hoppy on July 10, 2013, 11:58:16 AM
I think TinselKoala will be interested in this one  :)
Bringing out the heavy guns, huh?
verpies
Quote from: stivep on July 10, 2013, 05:03:11 PM
Verpies do not forget to respond to my posts regards Colman investigation and supporting material that I posted.
I am not going to write much this time because I mostly agree with you and I am still traveling.  Posting from a roaming cell-phone is both slow and expensive.
Of course you are correct that the impedance mismatch between the PA and the antenna wastes most of the power delivered by the amplifier and the resulting reflections can even damage the amplifier.  The remedy is a wideband impedance matching transformer or a narrowband quarter-wave transformer.
I agree that the CW excitation is hard to maintain because of the sheer frequency accuracy required. Also, the electric current generated by the Colman tube creates its own varying magnetic field that alters the optimum excitation frequency, creating a "moving target".  That is why the FM method or the SS method is easier to tune and maintain, albeit less energy efficient.
minde4000
So looks like our Chinese guy has his own web site WITTS Technologies - and it does have that pretty visible DONATE button.
Also I have received few PMs saying I should thread/connect cores with a piece of solid copper wire but then other videos of same guy has no such copper connections.
Minde
elementSix
My faith in Stivep has been shaken.  The fact that he wasted his time with those two microwave fan motors is beyond me.  To achieve what he has with the Colman setup, he must know that that would never work.  Just kiddin about my faith in your work Stivep..... The post I made the other day has been quickly posted out real quick.  Cepra's post was almost a page long.  Huh wonder who the real Troll is??  JK...  His post was a hell of a lot of BS, time wasting material..    I need help changing the DC motor tesla circuit controller setup with a solid state one.  I was able to get Radiant energy from my coil setup and it is all Voltage, which is what I want.  But it came on and off with the varying positive and negative contacts, and the speed of the motor.  All thoe it doesn't function constantly, I am able to get the Radiant Voltage in my secondary.  I am using two hard drive discs for my ant. and my Receiving plate.  I am getting the dc bulb that is attached to the receiving disc to light up very brightly, but it only gets real bright and then after a few seconds it goes out.  My circuit controller isn't very professionally made, it was just for tests and I didn't work to hard on it.  My receiving Disc gets the Amps. It crazy how it works, but I just don't have the math skills to calculate everything in my setup for resonance, or the skill to create the circuit.  Without it, I am not getting what I want to get out of it..  I guess I'll have to go up to U. of Cincinnati to find someone to help in making the circuit and resonance calculations.
The first guy to come out with the video showing two small induction motors driving each other, was an Indian guy.  Not the good Indians from America, but the ones from India.  He is the same guy that invented the power surge strip plugged into itself and also running a Lamp that was plugged into the strip.  He used a piezo igniter from a lighter to start the "Self-Looped" plug strip.  As if it were that easy...
Can anyone tell me why Tariel uses a Converter wherein a piezoelectric transformer input signal is frequency modulated by a pulse width modulated signal.  Could he be using this as his input signal and also his automatic Resonance device??
Here is the link to the Transformer he uses.
http://www.google.pl/patents/EP0758159A2?cl=en
Cap-Z-ro
Also, I seem to remember from a pic posted that it appeared as though something had been added under the tape of one of the coils.
Regards...
