0 Members and 40 Guests are viewing this topic.
stivep
Quote from: dllabarre on July 10, 2013, 06:41:04 PM
Wesley
Can you email guy in China and determine if he is using MOT transformer or any HV HF transformer near motors?
I don't believe he is but please ask him.
Thanks
DonL
the guy from China is not the performer  in video.He lives in mountains and he is waiting  for lab instruments now. That is all I know.
I have never  expected that Chinese will pay any interest to myself personally :)
Wesley
verpies
Quote from: Grumage on July 10, 2013, 03:23:11 PM
Using a microwave oven transformer that I had milled the weld from to separate the windings.
I'd like to see how you milled the Microwave Oven Transformer (MOT) !!!
I placed this in close proximity to one of the motors and Presto, it ran even without a kick start. So, to conclude, I think that there is a directed alternating EM field not too far away, but far enough so that a kick is needed.
How far does the MOT need to be in order for the motor to start by itself?
...and how far to rotate with a "kick-start" ?
Also, does the orientation angle of the MOT relative to the motor/motors affect their behavior much?
Finally, was anything connected to the motor's windings when you did your experiments?
I think there would also be sufficient induction to light a bulb as well.
Did you try? At what distance between the MOT and the motor was the bulb lit at full brightness ?
Finally I also thought that if the footage was from different sources, how come the light bulb was the very same? Even down to the insulation tape!! :)
Stevep merely wrote that those two videos, he was referring to, were made by the same person but on different tables and bases.
sparks
    " [size=78%]Bohr realized that when an electron falls in towards the atomic nucleus it will lose[/size]
energy to radiation and become captured in different distinct orbits where the
frequency, energy and velocity of each orbit are determined by Plank's constant
h. Thus, the energy of atomic orbits became quantized. "   And may I add it's momentum has been increased by the fall.  The particle was accelerated therefore it's mass/velocity increased.  Inertia was transferred from the nucleus to the electron.   This increase in momentum becomes apparent when the captured electron is freed and doesn't fall back into the nucleus but results in inelastic collisions in a target of negatively charged mass.   This randomly occurs in cathode ray tubes.   The electrons are donated by the grid metal.   The electric field extends through the grid and accelerates the free electrons from the grid to the phosphorescent coatings on the anode.  This malfunction of the picture tube is usually due to transient spikes showing up in the signal.   The grid becomes a free electron source and the electrons are accelerated by the cathode anode field.  The transient not only free's the electron from the bulk of the metal it accelerates it away from the bulk.   This allows the accelerating field between anode and cathode to increase the free electron inertia that then deaccelerates in the anode metal.   This emits hard xrays that are transparent to the flurescent coatings and bombard the viewer with ionizing radiation.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumage
Quote from: verpies on July 11, 2013, 10:00:08 AM
Dear Verpies.
A gauntlet thrown, and picked up!!
First question answered here.............http://www.youtube.com/watch?v=6MdCkLMEv2E&feature=youtu.be
Second question. The motor has to be almost touching the core to self start and about an inch (25mm) for a kick. And yes the orientation is critical, I made sure that the center core and one of the outer limbs was facing the longtitudinal sections of one of the motors.
Now your final questions are a little harder to answer. I have noted that the 0.5 micro farad capacitor is not needed but the motors run up to speed quicker when conected. I am able to light a 60 W bulb but it is not bright.
As you and I am sure many others will be aware once the top is cut off the transformer it's AC impedance is greatly altered. I can only apply in bursts before the coil gets too hot, but I can get the motors spinning with just 75 Vac applied to the primary of the MOV transformer.
What I set out to prove is that a mutual coupling is possible but what method used, is open to conjecture! As is the wrapped up light bulb!! I know you like rigourous experiment. I also understand that for me to just say something to be taken as red would not sit well with you!! :) So I know where you are coming from!!
Finally, I am sorry I misunderstood Wesly's post, that is why I made the statement regarding the "very suspect" 60 watt light bulb!!
I hope you like the little video? Milling was performed on my 1930's 1 and a 1/2 ton  Knight Jig Borer made in the good old US of A.
Cheers Grum.
