0 Members and 132 Guests are viewing this topic.
stivep
Quote from: sparks on July 11, 2013, 10:04:08 AM
    " Bohr realized that when an electron falls in towards the atomic nucleus it will lose
energy to radiation and become captured in different distinct orbits where the
frequency, energy and velocity of each orbit are determined by Plank's constant
h. Thus, the energy of atomic orbits became quantized. "   And may I add it's momentum has been increased by the fall.  The particle was accelerated therefore it's mass/velocity increased.  Inertia was transferred from the nucleus to the electron.   This increase in momentum becomes apparent when the captured electron is freed and doesn't fall back into the nucleus but results in inelastic collisions in a target of negatively charged mass.   This randomly occurs in cathode ray tubes.   The electrons are donated by the grid metal.   The electric field extends through the grid and accelerates the free electrons from the grid to the phosphorescent coatings on the anode.  This malfunction of the picture tube is usually due to transient spikes showing up in the signal.   The grid becomes a free electron source and the electrons are accelerated by the cathode anode field.  The transient not only free's the electron from the bulk of the metal it accelerates it away from the bulk.   This allows the accelerating field between anode and cathode to increase the free electron inertia that then deaccelerates in the anode metal.   This emits hard xrays that are transparent to the flurescent coatings and bombard the viewer with ionizing radiation.
Let me rephrase it:
Quotewhen an electron falls in towards the atomic nucleus  it will lose energy to radiation and become captured in different distinct orbits where thefrequency, energy and velocity of each orbit are determined by Plank's constant
Yes   but ask yourself  why?
That must be something causing it to fall.( energy  lose is  always the manifest of  fall down)
QuoteIt's momentum has been increased by the fall.  The particle was accelerated therefore it's
mass speed and velocity
Quoteincreased.
QuoteInertia was transferred from the nucleus to the electron.
no it was not if the speed  of acceleration is higher than attraction force of nucleus than electrons can bombard nucleus and exchange of energy is  than much more interesting.
NO it not always take this path.
If energy of electron  now is causing not fall back but fly out than it can happened say due to the reason. and that reason might be external x-ray( xrf,edxrf, electron dispersion) neutron bombardment,
proton bombardment
atomic level of matter (molecules and atoms) and the subatomic (electrons, protons, and even smaller particles).
the simultaneous wave-like and particle-like behavior of both matter and radiation energy, is described in the wave–particle duality.
1.whenever electron under external influence fly out  say K orbit( the closest to nucleus) its place than is immediately attractive to electrons from higher orbit( higher energy level) so one or  two or more try to rush to the empty space in K.
There is however mutual attraction  as influencing factor from nuclei  is even more tempting.( presence of protons in large number say tungsten =74 protons)and presence of large mass.
But to do so electrons must  lose energy to get to the level of K
2. And manifestation of that energy is mostly in frequency band of xray photon.( but not always)
The running out  or catapulted  electron does it in sort of   Hertzian  ( snake like) way.
in both instances we are dealing ( not always but   for the purpose of explanation we take this scenario) with:
  photon( xray  photon) - no mass  at first that is / or might be converted to mass when influencing or say pushing out
electron  from K orbit
Than electrons(- mass particles) from higher orbit while  falling down to K lose energy in mass-less
form as photon- again mostly x-ray photon.
and we know photon is energy  with no mass
So there  you go...
despite the fact of what is going later on ----------- it is the first place  where science stay that mass= energy+ losses
where losses are/is mass and/or energy not yet converted but who cares.
My Colman uses energy of mass-less radio-waves( electromagnetic  wave) to  create mass response in the Colman Compound.
THAT IS GUYS YOUR EXPLANATION!!
the same way  as outside implemented massless xray can catapult electron from K means kinetic response into mass of electron and structure of atom and bonding forses of an atom the only  question is how much of xray.................. or how good - much less of xray  is concentrated into a beam to affect  atom. The interesting fact is that  ejected electron does it at certain  angle of incident. :)
but  science? ??? ??? ??? ?? throw them  Colman in front  of their eyes and they will say   that  it does not work
So anything and  everything might produce x-ray in energy exchange process.
  This randomly occurs in cathode ray tubes.   as well as x-rays but  x-rays is more often.
QuoteThe electrons are donated by the grid metal.
Who cares?
QuoteThe electric field extends through the grid and accelerates the free electrons from the grid to the phosphorescent coatings on the anode.
yep in CRT.. nothing new
Actually CRT of old TV is your electron  accelerator like in big CERN and others all you need to do is to
collide it with something but not with yourself :)
QuoteThis emits hard xrays that are transparent to the flurescent coatings and bombard the viewer with ionizing radiation.
Yes it is
Everything can be suspected to be Xray transmitter at the right condition including "radioactives" as well.
Even that small Chinese toy from my video
It is only the level of x-ray that matters.
http://www.energeticforum.com/renewable-energy/8454-i-found-gustave-le-bons-missing-book-called-synthetic-radioactivity.html
http://www.asdlib.org/onlineArticles/ecourseware/Palmer/ASDL%20Intro%20to%20XRF.pdf
I love this one from below it  explains so much:
http://archaeometry.missouri.edu/xrf_overview.html
http://www.youtube.com/watch?v=85peFIMURtk
http://www.youtube.com/watch?feature=endscreen&v=dttaxLJ4dgg&NR=1
watch  this and the  one below
X Rays - A Level Physics
http://www.youtube.com/watch?feature=endscreen&v=nSivTK6Icu4&NR=1
A level Medical physics X rays - production - braking and characte
http://www.youtube.com/watch?feature=endscreen&v=N32Jl0mdO2k&NR=1
by looking at this old video I wonder how much of xray is coming of tungsten light bulb at the "right" condition
http://www.youtube.com/watch?v=I3s5HFQ2YME
and partial answer is here:
http://www.youtube.com/watch?v=af8wnm2eGWw
You still not getting it?
Some or most of you?
Do you?
Colman is the  key to CREATION
got it?
no I think you did not
Think again:
Andrea Rossi converts in something that is  half Colman Nickel to Copper where both are fundamental particles.
And Colman is hundreds times less complicated than Rossi however is more demanding and more "moody" but is a lot more going on there.It is like to play with more  Card in your hands, or  more material to build- "whatever" in "whatever form" GOT IT?
you still did not:
think about  this:
Quotehttp://www.attoworld.de/Mainpages/Home/Mission_statement/index.html
most fundamental level electrons maintain and end life in biological systems and serve and save lifes via technical devices. Observation and control of their motion, when covering distances inside or between atoms at a speed of about thousand kilometres per second or generating brilliant X-ray and particle beams near the speed of light are our main goals. Meeting them will affect natural and life sciences and medicine and technology. This calls for a force that can exceed atomic forces in strength and be controlled on the electronic, i.e. attosecond, time scale. Our research provides this force via light with a few-cycle controlled waveform, and focuses on developing multi-octave light sources for its attosecond engineering and boosting to relativistic strengths.
This controlled light force enables us to reproducibly generate and measure isolated attosecond pulses of extreme ultraviolet and soft-X-ray light. (more...)
At high intensities, the attosecond light force can liberate electrons from their atomic binding and accelerate them to velocities approaching the speed of light within a single light oscillation period opening the door to high-field attosecond science. (more...)
We feel obliged to disseminate the knowledge and expertise we acquire and help our discipline to proliferate. (more...)
What is light?
Light is electromagnetic wave
Wesley
verpies
Quote from: Grumage on July 11, 2013, 03:39:18 PM
A gauntlet thrown, and picked up!!
First question answered here.............http://www.youtube.com/watch?v=6MdCkLMEv2E&feature=youtu.be
That was mean!  I yield Sir.
Second question. ..
I'm very satisfied with all of your replies.
Gotta be curt - still traveling...
Grumage
Quote from: verpies on July 11, 2013, 05:10:02 PM
Dear Verpies.
That single statement, coming from you, is all I could ask for!! :)
For me, this particular book is closed. Another volume awaits.
Best wishes to you,and all, Grum.
zcsaba77
I separate it by flex cutter, and one friend veld together the 'E' and 'I'  ::), but with velding is too much free run consumption around 35-40 watts
xiaoke2727
大家好
卫斯理说的正确,你们看到的那段视频,作者不是我,2天前我从网上购买了4个"罩极电机"和一些其他材料,总共花费了103人民币
现在我在等待这些材料,然后复制它,就是这样
中国和美国不同,我们这里的劳动力很廉价,我从早晨7:20去上班,到下午6:00才能回家,每个月只能休息4天,每月薪水大概1000美元
而且大多数中国人的薪水,30%—40%用来偿还银行贷款,所以生活压力很大
china
Gang
