0 Members and 85 Guests are viewing this topic.
sparks
Quote from: elementSix on July 12, 2013, 05:05:19 PM
Without help from my fellow comrads, I am very confident that I have found a means of replacing my Mechanical Tesla Circuit controller.  I see that a Thyratron Type of CDI module is what I need.  In the TK patent, he has "POINTS" as part of the first Circuit.  I believe this is where he is using the Thyristors for the CDI spark discharge capacitor for his Disruptive discharge system.  Tariel said when he was in Turkey that Vacuum tubes would be the best to use, but he didn't use them because they would only last so long.  In the 50's they tried to use Thyratrons Ignitions systems (Tube Type).  But they had to have a warm up period and weren't very good at high RPM's.  So I will have to buy something along this line.  The problem is that the Thyristors that TK and Meinchenko used are like 75 bucks each.  They are very reliable for capacitor disruptive discharge systems, or CDI's..
Here is good info on the CDI, Thyratrons, and other Capacitor discharge modules."POINTS"..
http://en.wikipedia.org/wiki/Capacitor_discharge_ignition
There was a period of time before semiconductors when they used mercury vapor for rectifiers.  I restored an old antique electric car built in 1897.  It came with a transformer and mercury vapor rectifier assembly.  I didn't rebuild the charger because of the hazards with mv.  I don't know if they ever came up with a mercury vapor triode.  Be cool if they did though.  The forward voltage drop would be really low.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
DimaWari
@xiaoke
What type of TK device did you replicated? SR schematics? STARR circuit? or Akula?
stivep
Revolution has begun Free Energy exposed part 7
http://www.youtube.com/watch?v=gKkcdfSdt5Q
FIRST LIGHT.
Starting from about half of video there is part dedicated to theory and comments .
Wesley
verpies
Quote from: stivep on July 13, 2013, 07:45:17 AM
Thanks for the video.
Does a ceramic permanent magnet, in the proximity of the Colman tube, influence the reading of your gamma meter?   ...when the stimulating RF frequency has been tuned properly.
The word "influence" can mean positive or negative influence.
stivep
Quote from: verpies on July 13, 2013, 11:17:25 AM
The word influence is often used  by me in political phrasing when direct word or discription is inconvinient  due to possible repercussion of it .
You need to tell me exactly the place I have used it and I give you answer.
I did not try it but I should.
magnets are to disperse gamma radiation
that was mechanism used  by Colman to stop or slow down in sort  of controllable action decay as without it it would have life on its own.
He implemented  electromagnets in  the schematic in self controllable fashion.
When I was in the room with my friend and everything was off we have heard Ranger giving us beep from time to time.
It was non frequent , non periodic and non repetitive in any way burst of beeps.
My friend said something about nature  of photo-voltaic.
I was kind of scare as my back was not protected by lead apron.
The reaction was completely random in length and in its intensity.
Eventually  it stooped but  it took  about more than hour.
I have never had vertigo in my life  I did not know how it feels like and how to even recognize it
After that I have noticed vertigo on the left part of my head it was sort of frequent, I have felt fatigue as well.
Vertigo was present any time  I changed position even position of my head.
Than I went ( few days later to work on something in mechanical  part of the lab  and while being  horizontal to the floor  ............ just changing position of the head was kind of vertigo all the time.
After about 2-3 weeks  it is normal.
Got to go with it  to lead box.
Strange enough I feel like I should have proton detector as I did not see enough evidence ( comparing to previous experiments) according to distance square law  to see such  magnitude of affecting factor.
I do not state that I got  proton radiation but what else could be?
Beta box, lead apron, and distance.
I did not use Xray meter I have - well I  should of.
1.See in atomic level almost every energy exchange creates or uses xray.
2.I should ( as much as it sounds strange)  read more about electricity versus radiation  in conductors.
Tungsten is used for xray tubes
3.So what matters?
electrostatic level?
or
4.Speed of particle  in spark gap or ionization chamber?- if so would that  be the  every time  we need collision to get xray of energy out?
5.could you say few  word about this decay process:
http://periodictable.com/Isotopes/027.56/index.p.full.html
6.could you say few  word about this  process:
http://en.wikipedia.org/wiki/Cobalt-59_NMR
Cobalt-59 NMR
From Wikipedia, the free encyclopedia
59Co is a nucleus of spin 7/2 and 100% abundancy.[1] The nucleus has a magnetic quadrupole moment. Among all NMR active nuclei, 59Co has the largest chemical shift range and the chemical shift can be correlated with the spectrochemical series.[2] Resonances are observed over a range of 20000 ppm, the width of the signals being up to 20 kHz. A widely used standard is potassium hexacyanocobaltate (0.1M K3Co(CN)6 in D2O), which, due to its high symmetry, has a rather small line width. Systems of low symmetry can yield broadened signals to an extend that renders the signals unobservable in fluid phase NMR, in these cases signals can still be observable in solid state NMR.
Actually I got to the point  where traditional alchemy  from its science fiction  evolves to the level of reality.
Nonradioactive  substance changing its composition( Rossis Nickel to copper transition ...... knowing that both are fundamental non transmutable particles).
That is what I said about "heaving power of Good of creativity" being able to model anything  right from your desk.
I must be also careful  about my hands close to Colman.
I'm open to your suggestions and criticism.
Comparing Lithuania experiment to Colman  investigation  in Lithuania  right  side of  head pain did not make any additional symptoms just discomfort. And I remember  to convince Aidas I put my head   from left  side of it  next to ferrite yoke that was just after
Aidas  said
I got strike in the head
The assumption was that I got heat by dose  of radiation getting only as much-as far as it could according to its energy level in keV. ending in right part of the   brain.
That also stays about  certain frequency  of that energy  in spectral graph ( its membership to  particular  family of photons)
and I forgot stiffness in my thumb finger. That I had long time only recently  is gone.I have noticed its presence 1 day after the experiment.
Legal note:
All of my 7 points of legal note  from my previous posts apply
All what I say is my interpretation and may not be free of errors. :) :)
Wesley
