0 Members and 70 Guests are viewing this topic.
Hoppy
Now back to the Aqua2 video.
I have now carried out an experiment based on my belief that TK used hidden wires inside the braided hose that he refers to as an earth cable. I used 8 meters of ribbon cable (see attached photo) made up of 6 wires, each with 14/0.2mm strands. The overall width of the ribbon cable is 7mm and the diameter of each wire with insulation is 1.1mm. The cable was split into 2 conductors, each comprised of 3 twisted wires. This cable powered a 230V AC mains 2KW fan heater with barely any heating of the ribbon cable. I used a wattmeter to check the power consumed by the fan heater.
It would therefore IMO have been quite possible for a cable of this type and size to have been concealed inside the braided hose and to have powered the 2KW electric fire just from the domestic mains supply (so easy it will make you laugh :) ). I'm now contemplating wasting a bit of time to build my own Aqua2 replication. The only drawback is that the braided hose will set me back £30.00 for a 10m roll.
Hoppy
Quote from: Zeitmaschine on July 14, 2013, 08:45:04 PM
Now what if that what can be seen in the 2004 Video is nothing special but just that what it looks like? A 50Hz 100VA transformer with a diode bridge and a filter capacitor, running as ordinary DC power supply and two transistors connected as ordinary Royer oscillator in order to get some high voltage. Hmmm ...
Yes, I think you are now seeing clearer  ;D
Zeitmaschine
Quote from: Hoppy on July 15, 2013, 05:27:45 AM
Right :P
Then all what is left to do is to figure out how the mixing stage works that mixes the high voltage high frequency with the low voltage low frequency in order to get high amps out from low amps in. ;D
Hoppy
Quote from: Zeitmaschine on July 15, 2013, 05:42:04 AM
Right :P
Right  :P & Wrong  :P
Right - high voltage for spark gap. Wrong - no need to mix; the 50Hz mains will do nicely for the low voltage, low frequency and high amps out.  ;D
