0 Members and 86 Guests are viewing this topic.
verpies
Quote from: elementSix on July 16, 2013, 12:55:44 AM
This Q? is for Verpies..  In a Resonant System like TK where everything from the Resistor to the coil, Capacitor and the input are all in resonance.  When the HV DC Impulse goes into the coil, does this mean that their is very little to no amps being consumed? ???
Yes, if the HV input pulse is narrow and coincident with the peak of the LCR voltage waveform and the amplitude of the resonance had the time to equilibrize wit VMAX  (assuming it starts from 0V) and the damping factor is low enough for the amplitude of the LCR oscillations not to decay too much between the HV input pulses.
That's a lot of "ifs" and there is even more of them if inductors use ferromagnetic cores.
Also do you think that using an older style Capacitor Discharge Ignition would be proper for my mechanical replacement of my Impulse Circuit?? I need a range of 10 to 100 Millisecond Impulse waves..
I can't answer that.  You are not specifying the f, VPK-PK , DUC, the rise time and the fall time of your pulse waveform.
Hoppy
Further to my post 18155, a better solution to carry the mains current through the braided copper sleeve is to use two high temperature rated 19/0.15mm PTFE insulated wires. The nominal diameter of wire is 1.35mm and is rated at 8A. Insulation is 600V. By earthing the copper braid, this gives a perfectly safe means of powering the Aqua2 device from a remote grid feed.
It would be very easy to clamp the copper braid enclosing the two thin wires under the steel bolt outside the house without damaging the wires.
Zeitmaschine
The only way he could fake the results are to create a Tesla Resonant Wireless transfer of energy from another spot near by the demo..  He could transfer very large amounts and just tune the coils to that resonant frequency like Tesla did..
Yes. And this »spot near by« is called a charged capacitor. The negative plate of this capacitor is the Earth and the positive plate is the Sun. If one disagrees with this he has to show that this capacitor is either not charged or that it is not possible in any way to extract energy from it.
Acca
 This is on  NUCLEAR CAVITATION  DISCOVERY from:  NanoSpire, Inc. it's similar very to the Nuclear ultrasonic generation by the Italians..
below is a clip video clip of the discovery by NanoSpire.
Cavitation Processing Solutions
http://www.youtube.com/watch?v=a7Gqd34R5OQ
https://nanospireinc.com/Fusion.html
In March, 2007 Mark LeClair built and tested the first cavitation reactor powered by the LeClair Effect, based on  patented technology. More research was done from 2007 to 2009 with a variety of other reactor designs that led to a series of key experiments performed from July – August, 2009 under a grant, titled: Utilization of Crystallized Cavitation Reentrant Jets for Zero Point Energy Production. The goal was to produce a next stage hot water heater reactor based on the LeClair Effect and was awarded by a potential investor focused on promoting cold fusion. Mark LeClair and Serge Lebid discovered that the scaled-up LeClair Effect reactor was triggering intense fusion, fission and large scale elemental transmutation using ordinary water. The 1.25" ID by 12" long reactor produced 2.9 kW of hot water using only 840 watts of input, a coefficient of performance (COP) of 3.4 times more energy out than in. The water temperature was raised an average of 18 degrees C (32 degrees F) average passing through the reactor with 28 degree C (50 degrees F) temperature spikes observed. A total of twelve experiments were performed, with 100% repeatability of the high levels seen in excess heat and transmutation in the various configurations.
  The metal that was used for heater was IRON !!
There is a common thread to this NMR as it happens in IRON,
They also had almost leathal dose of radiation twice from their plastic PVC pump as it went nuclear through neutron capture..
Attached are some photos of the cavitation pump !!
Here are the Italian patents on NUCLEAR ULTRASOUND.
PROCESS AND PLANT FOR THE PRODUCTION OF ENDOTHERMIC AND EXOTHERMIC REACTIONS BY MEANS OF PIEZONUCLEAR Ultrasounds cavitation OF SUBSTANCES AND THE
http://v3.espacenet.com/publicationDetails/biblio?DB=EPODOC&adjacent=true&locale=en_EP&FT=D&date=20080410&CC=WO&NR=2008041255A1&KC=A1
WO2008041254
APPARATUS AND PROCESS FOR THE PRODUCTION OF NeutroNs BY MEANS OF AND THE Ultrasounds cavitation OF SUBSTANCES
http://v3.espacenet.com/publicationDetails/biblio?DB=EPODOC&adjacent=true&locale=en_EP&FT=D&date=20080410&CC=WO&NR=2008041254A1&KC=A1
WO2008041253
APPARATUS AND PROCESS FOR THE QUENCHING OF THE RADIOACTIVITY OF RADIOACTIVE MATERIALS BY MEANS OF REACTIONS INDUCED BY PIEZONUCLEAR AND Ultrasounds cavitation
http://v3.espacenet.com/publicationDetails/biblio?DB=EPODOC&adjacent=true&locale=en_EP&FT=D&date=20080410&CC=WO&NR=2008041253A1&KC=A1
[/font]
yfree
Quote from: HG8AD on July 16, 2013, 04:17:38 AM
zcsaba77 !
Szia Csaba! itt van a Mc Freey analizis fordítása ha érdekel...üdv..:Laci...
This is interesting!
My translation of McFreey papers from Hungarian to English was in vain.
Someone translated them back to Hungarian  :) .
Unfortunately, the papers are not up-to-date. I will try to get you the up-to-date ones.
