0 Members and 147 Guests are viewing this topic.
NickZ
  But, we must keep the faith that it will happen, sooner or later.
Then sadness will turn into joy. The joy of a working device, made with your own hands, or bought with your own money.
  As there are still many many people in the world without any source of electric power,
at all.
And, we must stop also burning things up, as well.
  So, let's get over our "sadness", and do something more about it.
     NickZ
dllabarre
Quote from: NickZ on July 17, 2013, 12:41:26 PM
    This thread has won the prize... For the most non-working devices shown.
    AND, not one working device with over 1kw to show for it... still.
The requirement I put on myself last year was to not report until I have a working device with ~200-400W input and ~3kW output.
You have to have a goal.  ;D
DonL
Hoppy
Quote from: dllabarre on July 17, 2013, 01:21:12 PM
DonL
Hope to hear your good news before page 2000  ;D
zcsaba77
Quote from: Hoppy on July 17, 2013, 01:48:59 PM
free translated from my language: 'the hope die last'
anandml
Quote from: Hoppy on July 16, 2013, 01:21:44 PM
Dear anandml,
Neither myself or anyone else has confirmed beyond all doubt that TK's devices are either genuine self-runners or fakes. As you can see from my last few posts, I strongly believe that both the Green Box and Aqua2 devices are fakes and most likely all other video demonstrated devices of his. I have suggested an easy way that the Aqua2 device could be faked in a safe manner by anyone with basic electrical knowledge. In fact its so easy in principle that its rather pointless in building a replication. However, if anyone is interested and just cannot resist a build project, then here is a shopping list of parts: -
Glass or clear plastic tank / box.
2KW electric fire or 2 x 1KW elements, (from ebay) suitably and safely mounted if a suitable electric fire cannot be obtained.
6 metres of 7mm or 10mm wide copper braided cable sleeve. usually sold on 10m roll.
2 x 7m lengths of 19/0.15mm high temperature PTFE insulated wire.
Car ignition coil or other suitable coil and transistor driver for spark generation.
A couple of auto spark plugs to form the spark gap.
230V / 12V mains transformer and rectifier / smoothing capacitor to power coil driver.
Suitable looking Tesla style air cored transformer and perhaps another transformer or choke for eye candy. The incoming mains supply should be fed to the electric fire via this coil as in the Aqua2.
A few empty plastic boxes and an assortment of old surplus and populated PCB's for added effect.
Hook-up wire and switches to connect the parts that actually work, plus the parts that don't, just to enhance the illusion.
The PTFE wire can be easily threaded through the braided sleeve, as the sleeve surrounds a plastic tube that can be removed once the wire is threaded through the sleeve.
A steel bolt and washers to clamp the braid to a suitable rod or wire connected to a protective mains earth. The braid needs to be carefully split in the centre, so that the bolt can pass through without damaging the live and neutral wires laying on each side of the bolt. The bolt then needs to be fixed into a lump of concrete or flagstone, such that there is a concealed hollow underneath where connection can be made to the mains supply and earth, to complete the illusion.
The spark gap capacitor needs to be sized to give approx a 5Hz spark repetition frequency to match the Aqua2. The frequency should rise a little when the electric fire is switched-off as with the Aqua2.
Last step: Bring in the investors  ;D
Thanks for your reply hoppy. Yes you are right TK's Aqua2 devices are not genuine its look like fake device especially the rod connected to the earth. I have another one doubt how Tk got patent of his device. I think Tk 2004 device is not fake.....
