0 Members and 296 Guests are viewing this topic.
Zic Hailev
Colleagues, and what inside of the coil Naydine, what for a rod{core} who can explain from what it{he} consists?
I from Ukraine!!!, excuse for my English!
bolt
Quote from: Zic Hailev on June 08, 2010, 12:30:44 PM
In Naudin system probably only thick copper wire but coupling can be improved using 5 ferrite toroidal  cores through which the thick wire passes through the center of each core.
Please avoid using microwave oven transformer its VERY dangerous and they have no self current limit. Use car coil or NST instead.
bolt
Quote from: slapper on June 08, 2010, 08:17:42 AM
I understand the attraction to these arrestors. Several years ago when I was trying to get lower spark gap voltages
(120 to 250 volts) I ordered these things from about 3 different manufacturers. They are a great deal slower than a
spark gap and they then will tend to dissipate some heat. From memory, their reaction times where micro seconds
as opposed to nano seconds.
Take care.
nap
speed don't matter they are used as a regulator to ensure each bulb only gets no more then 250 volts. Without these and slight miscalculation on coil ratio will blow all these bulbs in half a second.
vrand
Quote from: bolt on June 08, 2010, 01:49:10 PM
In Naudin system probably only thick copper wire but coupling A using 5 ferrite toroidal  cores through which the thick wire passes through the center of each core.
Interesting idea.
Has anyone tired this?
xenomorphlabs
Quote from: vrand on June 08, 2010, 02:26:21 PM
Interesting idea.
Yes, about a couple of hundred people after SR revealed that he used ferrite toroids for his core ;)
