0 Members and 227 Guests are viewing this topic.
stivep
Quote from: Acca on July 18, 2013, 06:07:43 PM
Wesley !! Wesley !!
This link is to you Wesley, as you have worked in geology and will understand the matter of radioactivity in this nuclear burst.
I also work in geology and have very strong interests in the synthesis of elements and the way radioactivity is understood.
The Russian ferrites as well as Bob Byce hex controller which uses a very big ferrite core pulsed, opens up new questions as
to, are "fast neutrons" with out gamma emitted ?? the evidance is just there.. !!! Italians did discover it!!
As to the rest of the forum members this discovery of Coleman is just the most significant re-discovery ever !!
If "you" just don't get it, well it's like all matter is capable of being turned in to pure energy with a  "hammer blow' Yeh it's
like that !!!
Here is a picture of neutron detector CR39 after a nutron burst..
http://vimeo.com/43500015
Piezonuclear Fission Reactions in Rocks: Evidences from Microchemical Analysis, Neutron Emission, and Geological Transformation
Yes I have seen it I did not purchase this one as of yet I was looking     where they sale it.
Thank you again
Wesley
zcsaba77
Quote from: Grumage on July 18, 2013, 05:33:52 PM
Dear all.
There may be some confusion with PJK book. I think I have the latest version where Chapter 3 page 72 is discussing Kwang-jeek's Lees Power amplification patent.
Are you refering to Don Smith's work? As there is a picture of a device in Chapter 3 page 25 that works on the same principle as that posted by Spark's earlier on.
I am using PJK book Version 19.81 12/12/2011. Are there any newer versions out there?
Cheers Grum.
Addendum. I have just downloaded the latest copy :-[   WOW Have I got some reading to do!!
...is too much change in paper from 12/12/2011  ???, in my interesting Two Disk Generator, was warios 1.st without pancake coil 2.nd with, last again without (exchanged coil to cap) ::)
Hoppy
Further to my post 18183 and for those wishing to build a replication of TK's Aqua2, I have attached three photos of how I believe TK faked the Aqua2 device using hidden wires inside the copper braided screen - 'bright'. The 'bright' (6mm dia) is pushed into a 6mm crimp lug and the very thin PTFE wires (for mains 'neutral' and 'live') are taken out of the crimp through a small hole as shown. The hole is already in the lug and just needs enlarging a little. The lug is fixed to the screw earth rod with two nuts and a mains earth can be connected to the rod so as to earth the bright for safety. This is important as it is possible that the thin 600V PTFE insulation covering the wires could split resulting in the bare wire touching the 'bright'. This is probably why the guy in the video was nervously fingering the earth rod. The wires could route down the same hole as the earth rod (channeled slightly under the lower locking nut to allow the wires to pass under) , so again there is potential for a fault to develop here. Alternatively, the wires could drop through a small separate hole made directly under the shoulder of the crimp.  The width of the bright when flattened is approx 9mm.
I have found that 7/0.2 PTFE (6A) high temperature wire could be used as an alternative to 19/0.15 (8A) but will run warmer.
baroutologos
Hey hoppy,
I think , there is a plethora of ways to cheat an audiance to believe the unbelievable. Kapanadze tech is highly questionable and everything could be easily staged to lure naive investors.
There is no point to repeat the "methodology" as much of the thread has done so far, that by looking coils and wires and try to replicate the OU device by the image seen guided by false Teslean muths and legends in the electricity field.
Surely novel ideas have been proposed here (cold fusion, stimulated beta decay, etc etc) that have a plausible reason to be valid but few to none individuals seems to chase after them since they involve highly skilled people, considerable infrastructure and much work to just scratch the surface.
Sorry but no easy solutions for the average "Joe" for a free or very low cost, compact, 24/7 running overunity device.
Hoppy
Quote from: baroutologos on July 19, 2013, 07:29:28 AM
Hey hoppy,
Surely ideas novel have been proposed here (cold fusion, stimulated beta decay, etc etc) that have a plausible reason to be valid but few to none seems to chase after them since they involve highly skilled individuals, considerable infrastructure and much work to just scratch the surface.
The only reason I post this particular method of faking the aqua2 is that it comes into the category of being 'so simple it would make you laugh' and that some posters have criticised the naysayers for being unable to replicate the Aqua2 device running a 2KW fire, let alone the real thing. Otherwise I agree with your comments.
