0 Members and 84 Guests are viewing this topic.
Zeitmaschine
Quote from: Hoppy on July 19, 2013, 07:00:54 AM
Further to my post 18183 and for those wishing to build a replication of TK's Aqua2, I have attached three photos of how I believe TK faked the Aqua2 device using hidden wires inside the copper braided screen
Precisely! And in 2004 video the investor forgot to look under the table for hidden wires, because he was occupied with rubbing his eyes while observing the unbelievable amp measurements. ;D
Quote from: Hoppy on July 19, 2013, 07:40:57 AM
The only reason I post this particular method of faking the aqua2 is that it comes into the category of being 'so simple it would make you laugh'
And I just thought the only reason for posing this is »someone here is getting too close to a simple working device«. 8)
Quote from: screen on July 19, 2013, 08:42:48 AM
Found the bank patent device Brazil, hopefully you have any clue to evolution of projects.
If these patents have the same »quality« like the TK patents then I'm sure no one here has the slightest clue. :(
sparks
     In a charged capacitor the power of the capacitor can be calculated by how many amp hours through a known resistance will it make happen.    A funny thing happens when your load is an inductor.     You short the damn cap and it charges up again.  Now some people are dumb enough to insert a resistor in this oscillating circuit to develop some conversion of current into voltage across the inserted resistor.   This is then transferred to various amplification devices to use local electrical energy to recreate the oscillations they just destroyed.    Whereas some smarter people put current transducers around the buss conductors to measure the magnetic flow into and out of the conductor that don't damp the oscillations.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
elementSix
Just a little more info in a pic.  Just for people searching on google.  I could use help explaining the current amp in a better way.  Ow well  Kapanadze schematic explanation.  Tariel Kapanadze circuit, Kapanadze schematic , Tesla and Tariel similarities.
anandml
Quote from: Zeitmaschine on July 19, 2013, 01:45:52 PM
@ Zeitmaschine
I can't able to believe Tk's 2004 device is fake because of two reasons. There is a possible way to connect hidden power supply under the tin can. I think no other possible ways...
1. He plugged the two pin from the inverter to the grid supply we can able to hear different noise (transformer overload) and after he removed the plug from the socket mysterious noise will be stopped how? (2004 video 11:16)
2.After making the self run he tried to remove the wire from the grid supply at that time the whole bulbs will be turned off. (2004 video 12:45). If he connect hidden power supply under the tin can how it is possible....Otherwise he placed step-down transformer with relay inside the inverter also not possible...
johan4el
Quote from: xiaoke2727 on July 14, 2013, 08:30:42 AM
I failed again
275v  0.47u
275v  0.33u
250v  0.56u
630v  0.68u
1000v     1u
next
i  will think of  some  other ways to make it work
For example, increase or decrease some coil
maybe one of the shaded motor ,, must change or modified the rotor with neodymium magnet ,,and to be a generator ,,,to supply a power to other motor
johan
