0 Members and 125 Guests are viewing this topic.
Grumage
Quote from: elementSix on July 21, 2013, 07:07:55 PM
On a lighter note...  Has anyone ever run a FlyBack with a circuit from a CFL??  It looks cool and if you buy a good  high watt CFL, it should last a good while..
Link to CFL Page
http://www.instructables.com/id/MAKE-A-HIGH-VOLTAGE-SUPPLY-IN-5-MINUTES/step2/Some-Info-about-Flyback-Transformers/
Could TK be using the transistors to pulse HV DC?  I am sure there is a circuit using two transistors that can do that. But I'm sure you guys would of figured that out by know..
F_ck TK.  He is greedy and crafty.  His group of buddys are a bunch of ex red mafia guys who are all waiting for a free ride and they look like a bunch of junkies..
Let's put it to rest.  If you haven't tried the Tesla Impulse tech, then you are not looking for FE.  You are on this forum for other reasons.  I know you have to have been reading my posts.  I haven't really posted it in everyone's face, but it works.  Thats as simple as it gets.  If you follow the stringent requirements to get the result that we all are on here for, then you will have what your looking for.  Once I get a few bucks to try the CDI, then I can put out a more detailed circuit.  If you know how then this should be easy to find.  Now if you try it and it doesn't work, then call me a Liar and I will send you a time and place to meet so I can show your face into the concrete. JK.
I know that it needs a lot more work.  I can't get it to work constantly, but I am getting there.  The longest I had it run was 3 min..  It only works with filament light bulbs and heaters.  Why that is I have no idea.  Maybe some one can help me in that department.  One more thing, don't do what I did, the first time I got it to work.  I dumped 6 MOT caps into the circuit and it wiped out my cpu and my multi-meter. EMP tech seems to be the same.  Thats the stinging sensation that Tesla felt when he first discovered DC impulse tech.
Can anyone explain how a simple circuit gets 10 million Volts out of a 12 volt battery, in a stun gun???
                                             Love  e6
Dear Element 6.
There will be no need for "Concrete" :)  I do believe you!! Please scan a simple sketch of your concept.
I was having a chat with T-1000 last night and he was telling me that whilst testing a device that had a caduceus coil primary a nearby remote control went haywire...... LED's lighting up and so forth. Needless to say it never worked again!! He put it down to "standing wave/scalar wave" generation. Now that got me to thinking? What if we are going about this in the wrong way? I wondered if we were to place the primary and secondary of a Tesla type device in the heart and then with a larger tube, possibly wrapped with aluminium sheet and finally an outer wrapping of wire turns we could capture these "scalar waves" before they managed to escape and wreak havock with both electronics and flesh!!  A bit like dear Zeitmaschine's Faraday cage, but in reverse so to speak!! I think a load would have to be permanently connected just to make sure.
I think I may have a clue as to why Inductive loads don't work, it is probably due to BEMF being generated in opposition to the HF input.
Any way as I and NickZ have probably got the only test rigs available, and ready, I suppose I had better give it a try. So dear E6, if you don't want your schematic common knolwedge please PM with what you are using to to "sting flesh" and I will try to tame it!! :)
Cheers Grum.
Hoppy
Quote from: Grumage on July 22, 2013, 01:38:09 PM
Cheers Grum.
Evening Grum,
If the schematic inter-wiring is ignored and the mult-turn choke becomes the secondary Tesla coil with one of the outer coils at one end of the tube surrounding the secondary acting as the primary, then an aluminium sheet wrapped around and above the secondary coil, could act as a top load for the Tesla coil. The remaining coils could then be for pickup.
Please don't use your home mains earth when experimenting at high energy levels. if you wish to employ an earth, then put down a separate rod earth in your garden. I've done a fair bit of experimenting with Tesla type coil setups and made that mistake!
Grumage
Quote from: Hoppy on July 22, 2013, 03:15:17 PM
Evening Grum,
Dear Hoppy.
Thanks for that!! I have been so "into it" I had not seen the connection, it is like a Tesla coil within a tube!! I do have a seperate earth rod but with the move I have not got round to extending it into the new spot.
I have just finished winding the latest choke so I am off now to see what it does. At low power of course!! :)
Cheers Grum.
NickZ
   Zeit:
   I feel that you are completely right.  As no one to my knowledge has really even tried to replicate any of TK devices, to the T.  Exactly as he has it, tin can and all its goddies. Maybe the tin can does more than just hide the contents, also?  As it is located directly at the end of the air coil. Akula also mentioned placing a transformer inside of a magnetic field. Hendershot also places an iron core transformer inside of his home made capacitor/coil.
  Wasn't the insides of what is in the tin can shown in a later garden video? Showing that it has only a big iron core transformer, to step down the voltage??? Possibly along with a rectifier and cap to tune the frequency, also?
  We have made this all too complicated, TK only used a 12v battery/inverter, a couple of transistors, wire coils, iron core transformers, a cap or two... and right in his bedroom, produced the results that we can't even imagine.  Akula shows us that no ground, or battery are really even needed, after start up.
  And so have several others... on the island, in the snow, etz...
The only hidden wires are the ones in our heads, that we haven't yet connected,
to make this work.
elementSix
Hey Hey Hey My MY, Thinking about what a friend had said, I was hoping it was a lie.
Well this morning I was thinking on my on question,  since the impulse wave that appears on the secondary is more akin to an EMP(Electro Magnetic Pulse), the combination of the negative and positive lines.  It works well with filament lights and heater elements because they are both devices that use that energy combined to create the heat/light.   When referring to HF in the Impulse division,  you are talking only about the speed of succession  of the impulses.  Little explosions inside of the primary because this will not work with AC, it's a DC system only.  It works without the capacitor, but the capacitor magnifies the effect by releasing the gates of hell.   I do know that the HELIX coil has the strangest effect when introduced to a working field of reactive radiant energy.  Tesla found this out,  and using this special secondary "His Helix Copper line" with his special primary/circular disruptor line , capacitor and magnetic quench.  He was able to get 240,000 Volts from his 10,000 Volt DC Dynamo.  This was achieved only by following a strict format in which the disruptor line and the special helix secondary's mass was the same.   The best line to use for the disruptor was ribbon.  Like the copper ribbon that TK used in his Red Coil transparent box setup.  I posted some Impulse circuits the other week.  I think it was like6 or 8 weeks ago.  Not to sure, but the impulse wave generator that worked best was one with all the capacitors were connected in parallel with both contacts connected to a long copper ribbon.
Here is a PDF that talks about Impulse waveforms and impulse circuits.
http://203.158.253.140/media/e-Book/Engineer/Electrical/High%20Voltage%20Engineering/22862_06b.pdf
So you can Experiment with a helix coil inside of the disruptor line circle.  Just to get info on this phenomenon.   The main problem I have is getting the Impulse Wave to be Straight up and down.  Thats why I wanted to try to find and older CDI module for a car, but I want one with a Thyristor.  Like Meincenko or what ever his name is.  He used like 8 Thyristors in his setup.  They are the High Power ones used in Steel mills because of the great impulse they can make.  The best way that Tesla found for a discharge device was in Electric Arc Dischargers.   I think that maybe an ARC Lamp can be used in this circuit.  It seems to take all the current out of the DC that goes threw it.   I think that might have something to do with the way this works.  The resonance that must be maintained,  might be part of not having any amps being used in the coils.  Just a thought..
