0 Members and 538 Guests are viewing this topic.
Zeitmaschine
Quote from: Сергей В. on July 22, 2013, 08:35:31 PM
Only for Experimenters
Гость УСТАНОВКА 2 kwatts on 220V
http://www.youtube.com/watch?v=gz0IPdPbHvA
Author (not ikako chubinidze) achieved 2kWatt output power with 100watts input.
Just two simple questions:
1) I can see a flickering spark but I can also see a steady shining incandescent lamp. What is the physical explanation for this? How can an unsteady current in the primary coil (L1) produce a steady current in the secondary coils (L2 to L4)?
2) What are the output measurements of the coils in terms of voltage, frequency and waveform? The output should be suitable for an ordinary 50Hz transformer (T1 back loop) which is shown in the diagram further down on this page: Kapanadze SOLVED !!!!!!
verpies
Quote from: Hoppy on July 23, 2013, 08:24:45 AM
http://www.scribd.com/doc/129170122/2SGen-An-Amazing-Tiny-Solid-State-Generator-by-JL-Naudin
I've seen this. Two magnetic fields permeating a ferromagnetic core in two perpendicular directions.
That is Steorn's ORBO operating principle. The permeability modulation is nicely illustrated in this video.
This of course means solid-state parametric excitation - some people here think that parametric oscillators output more power than the input power needed to accomplish the permeability modulation.
HG8AD
Quote from: anandml on July 23, 2013, 01:47:44 AM
Thanks Сергей В.
Google translation.....
You tell me it only how the 0.3 mm of inside has an effect on a coil how 2Kw out to go .. if we look at the resistance of the copper only 10.20 ohms... :(
yfree
Quote from: Zeitmaschine on July 23, 2013, 08:30:00 AM
These are excellent questions.
The only other "perpetual" question is: Where is the energy coming from?
One wire is the ground. The unit does not work without this wire. In addition, one battery wire is still connected during the demonstration. This makes two wires.
Is the energy coming through a wire hidden under the battery?
The battery seems to swivel rather than shift when pushed.
