0 Members and 425 Guests are viewing this topic.
Сергей В.
Quote from: yfree on July 23, 2013, 09:33:49 AM
These are excellent questions.
The only other "perpetual" question is: Where is the energy coming from?
One wire is the ground. The unit does not work without this wire. In addition, one battery wire is still connected during the demonstration. This makes two wires.
Is the energy coming through a wire hidden under the battery?
The battery seems to swivel rather than shift when pushed.
Привет yfree :)
My answer of your «perpetual question.... Where the energy come from» is from Plasma, precisely Magnetic Reconnection Process !!
I think complete matter (organic and non-organic) exist only in one state. That state is Plasma. Why should Plasma must always be in «High Temperature state ??»
Who said that and most important question .... Who has proved that ?? Who was measured the temperature (absolute) of atomic and subatomic particles and what the temperature is on atomic - subatomic and sub-subatomic levels??
Our physical bodies were made from those particles in highly organised cristal lattices (geometric organization). The distances between atomic cores and outer orbits are so huge - for example like from Sun to most outer planets in Solar system and almost complete mass was concentrated in core.  Mass is another unanswered question.
The same thing worth for subatomic particles in atomic cores.
In two words.... I see on all kind of Magneto-Dielectric Fields like Plasma fileds. Also complete highly organised organic matter like kind of Plasma.
ps:
Современные учёные предпочитают математику реальным экспериментам, и, переходя от одного уравнения к другому, они, в конечном счёте, построят модель, которая не имеет ничего общего с реальностью». Никола Тесла. «Modern Mechanix and Inventions». Июль 1934 года.
Modern scientists prefer mathematics instead real experiments and moving from one equation to another they in final account draw up models which have no common points with Reality. Tesla said in «Modern Mechanix and Inventions». July 1934 year.
Привет Hoppy :)
Thanks for links. Very interesting books. I just have downloaded some of them.
Привет verpies :)
Suppose on acrilic plastic or maybe bakelite forms. Interesting his inner tube coils were hot just like in Grumage case. Did Akula have the same problem and how he has soved it ??
Привет captainkt :)
The counter wind mean opposite to each other.  I think output circuit was wired like on the sch. below.
to all
Let's all do some analysis of Coils geometry in devices of Akula, Bronepoezd, Dally, Kapandazde etc.etc. I think geometry is very important.... probably crucial !!
Inductances of both 80 turns outer coils are 120uH each. Both coils were wound in same direction. Withouth GROUND as you can see on video device don't work.
Capacitor(s) must be tunned from 1uF-10uF to get in resonance. I think Tesla-Aviso-Dally-Akula principle work here. Shooting HV pulse (aperiodic - monopolar or unipolar pulse) at top of sin wave in Resonant Bifilar LC contour. How we will know that we have caught right frequency and скважность ?? On one end of bifilar coil (hot end - unconnected for tuning)  powerful фитонка will appear. I think фитонка is a streamer.
Capacitor must be with low ESR HV impulse type. Low quality caps. can explode here very very easy and they did it very often.
Aluminium tube must be cutted through the whole lenght (axially cutted) to avoid short-circuit loop. Good quality Aluminium can be found in big electrolitic capacitors. Than you can wound it axially on some plastic tube 5 cm in diameter but must not be short-circuited (begining and end of winding must not be connected  -leave a space 4-5mm between.
Zeitmaschine
Quote from: Hoppy on July 23, 2013, 01:41:39 PM
??? Why?
Because having the real thing would be somewhat more relaxing.
Harmonics: »One of the major effects of power system harmonics is to increase the current in the system.«
I do not have any objections against that. 8)
Hoppy
Quote from: Zeitmaschine on July 23, 2013, 02:45:17 PM
Not if the MIB are on your back  ;D
What effect does the increase in current in the system have on the source power supply? The increase in 'zero sequence current' you are referring to, applies to the grid alternating power system, so you clearly accept that the source of power is the grid.
forest
zcsaba77
.... from the sun.  ;D
Seriosly. What is here the gain medium?
Is something similarity with this?
http://www.youtube.com/watch?v=J0pAo9rELT8
