0 Members and 436 Guests are viewing this topic.
Zeitmaschine
Quote from: Hoppy on July 23, 2013, 03:46:04 PM
Not if the MIB are on your back  ;D
What effect does the increase in current in the system have on the source power supply? The increase in 'zero sequence current' you are referring to, applies to the grid alternating power system, so you clearly accept that the source of power is the grid.
But here the grid is replaced by the inverter which is grounded in an unusual but resonant way in combination with high voltage, means the output current is increased but instead from the inverter the current comes from the ground (capacitor Earth - Sun) because due to this confusing configuration the current is forced to disobey what is written in the textbooks (yet). Could be the MIB already know this. :o
OK, now what could happen when high voltage is connected to ground (with or without a spark gap) through a coil of some kind? I think a magnetic field should be created around that coil. Question: The energy for the creation of this magnetic field is coming a) from the HV power source or b) from the ground (capacitor)? (we keep in mind that this coil is not part of a closed electric circuit)
Just asking. ;D
Hoppy
Quote from: Zeitmaschine on July 23, 2013, 05:15:19 PM
Just asking. ;D
But that's the whole point, the grid is not replaced with an inverter. The inverter works in switched conjunction with the grid IMO.
Neither a) or b) but from the grid.
Zeitmaschine
Quote from: Hoppy on July 23, 2013, 05:41:28 PM
Here the operative word is IMO.
If we put a coil in a 50Hz circuit then this coil works like a resistor (inductive reactance). If we put a capacitor in a 50Hz circuit then this works also like a resistor (capacitive reactance). If both reactances are equal then we have resonance and therefore the current going through a series resonant circuit is at maximum. That means at resonance the LC resistance is almost zero.
Nice. But we do not need a resistance of zero but a negative resistance below zero. Therefore the resonant LC circuit must have the opportunity to draw additional power from a current source, so its resistance can go below zero. Actually simple, isn't it?
What would happen if the primary coil of an insulation transformer is connected to 60Hz mains whereas its secondary coil is connected in series (as choke) to an inverter and a load running at 50Hz? Is the load -according to Rhythmodynamics- powered by the 60Hz grid (negative resistance) or the 50Hz inverter (positive resistance)?
Just asking. ;D
stivep
I need some advice in polishing glass.
I can not use this one as glasses to my lead helmet I.m designing to make
But it might  be good for lead box to  view of what is going on with Colman.
When I paid for it  I thought this is good $28 investment :)
The new one cost about 10k.
I had no idea That I'm participating in disassembly of possibly american heavy armor  antinuclear tank or sort of this kind device.
Does anyone know what antinuclear armored  vehicle it come from? :)
So I need to make it  transparent.
I'm sure you guys can help me out.
Everything about process .. how to do it yourself?
Wesley :)
magpwr
Hi,
I have found a link which maybe useful for those whom are working with high voltage coil(Telsa) and obtain resonance from coil.
The author of site shows in details how to tap center coil to get resonance frequency of the coil as well.
He did show a Nice trick on how to connect oscilloscope to high voltage coil as well.
There is also a online java program in his site  to insert your coil values as well.
http://www.hvtesla.com/tuning.html
