0 Members and 225 Guests are viewing this topic.
grizli
Quote from: bolt on June 08, 2010, 01:49:10 PM
In Naudin system probably only thick copper wire but coupling can be improved using 5 ferrite toroidal  cores through which the thick wire passes through the center of each core.
Please avoid using microwave oven transformer its VERY dangerous and they have no self current limit. Use car coil or NST instead.
MOT+ spark gap usually requires ballast..
Zic Hailev
I think that inside of coil Naudina located rings from ferrite and
Rod{Core} from the twisted wires (polarizer)! Here the schema{circuit} of the coil!
grizli
Quote from: Zic Hailev on June 08, 2010, 05:37:19 PM
Hmm, but this has been replicated unsucessfuly for many times after SR declared ferrite is inside
FreeEnergyInfo
info
hartiberlin
User Dragon had some success with his circuit.
he wrote:
I've made several attempts with different coils and this is one of the better ones. The whole thing is Tesla basics as you can see in the diagram of the circuit. The picture's show it running a small 40 watt bulb at around 7 watts of input, the variac is set at around 50 volts. The NST is a 120V input with a 6500 volt .02 amp output. I have 2 earth grounds on this one but the second doesn't seem to add anything and can be removed without changing the light intensity or input requirement. One is required.
I've found by playing with various coils and bulbs it's not so much the wattage of the bulb in as much as the resistance of the bulb or bulbs. I have no real way of measuring the output at a wattage level, no claims are being made.... just an interesting experiment.
Thanks for the vote of confidance baroutologos, I don't see it as any magic happening, although, it may appear to be on the surface. I'm not convinced the double ground is contributing anything to the system, it runs the same with only one connected. Positioning may play a part in that.
Since I really don't know how JLN or Kapanadze is actually going about it I've been theroizing on my own of how to accomplish it and came to the conclusion it's nothing more than a reverse tesla coil. Instead of putting HV low amps into L1 and converting it to extreemly high voltage you do just the oposite... put the HV into L2 and convert it to lower voltage and higher amps through L1. The trick is getting L1 to resonate with L2 in its reverse form.
L1 being very low inductance using the earth ground through a load creates a psudo tank in which L1 can reach high amps. I still don't have the resonance dialed in quite right with this one although it seems to drive L1 reasonably well ( L1 being the 6 turn coil - L2 being the 90 turn coil - L3 the reversed 30 turn ). L3 is used to raise or lower inductance to help match the two. It might even help to make this one adjustable to some degree.
Getting bulbs to light is a matter of shuffling through various resistances to achieve the correct response. I've run 175 watt mercury bulbs with it but those react like FL's and in my mind doesn't really constitute wattage in as much as a voltage response.
I've been doing some tests with a 150 watt halogen and it lights nicely produces lots of heat but is far from full bright. At 150 watt input it will be blindingly bright (sun like to your eyes), driving it with this set up it's bright but not blinding and is using about 35 watts to get it there although I can get an orange glow with lots of heat at 10 watts.
I need to do more work with this coil to dial in the resonance a bit better....
Fun stuff....
