0 Members and 74 Guests are viewing this topic.
Hoppy
Quote from: Zeitmaschine on October 09, 2012, 12:10:43 AM Now I have noticed the same random behavior during my experiments with a transformer, inverter and capacitors. My inverter (not transformer!) makes a humming noise when connected to the transformer and the capacitors. But not always. Without changing anything in the setup sometimes after connection the humming noise is there sometimes it is not. I think the difference is whether the connection is closed at maximum or at zero-crossing of the sine wave.
You may  have also noticed on the 2004 video that a humming noise could be heard before the plug was inserted into the mains outlet but at a much lower level than when the plug was inserted.
stivep
Quote from: Acca on July 25, 2013, 05:29:37 AM
Wesley, here is a nuclear glass polish for the heavy lead glass link..
http://www.raybar.com/shld_info.htm
http://www.raybar.com/cntrl_wndws.htm
Lead Glass does not shield against thermal neutrons or fast neutrons
RAY-BAR X-RAY GLASS POLISH
Specially formulated for gently reducing or eliminating haze or hair-line scratches from soft x-ray lead glass surfaces, or refurbishing old existing medical x-ray glass windows and reducing surface "fogging",discoloration and oxidation from age for a clearer view of patients. Polish and applicator are included along with polishing instructions in this kit. Will not remove etches or deep scratches.
And my video on the piezonuclear effect.
http://www.youtube.com/watch?v=ba-FeswwGNQ[/font]
Thank you very very much
Wesley
Zeitmaschine
Since -as it seems- we are looking for a) a non-ordinary transformer b) a way to suck electrons out of the ground, so what about this brilliant idea? :D
Two flybacks coupled with each other (mirror-inverted) connected to ground but the high voltage coils do not form a closed circuit. As there is no closed circuit but a grounded non-circuit, what are the physical laws in question here?
The ground is negative. Negative means a lot of electrons. The high voltage is positive. Positive means a lack of electrons. So the electrons in the ground are attracted towards the positive side of the flybacks through a coil. Simple in theory. But what could be the outcome practically? And what could be the difference if both flybacks would share the same core? Or if they are connected via a HV capacitor to form a series resonance circuit?
The basic idea here is to get a grip to the ground as power source without necessarily having an output of 220V/50Hz. For a start heaving an arbitrary (over unity) power output would be good enough (for me).
BTW: I think this will not work with DST flybacks (diode-split transformers) because the built-in diodes will prevent the resonance between the two transformers.
So, who can lead a blind man into the light? :)
P.S.: Could it be that this works (if at all) also with two mirror-inverted 50Hz step-up (step-down) transformers? The only requirement would be to have the apropriate high voltage in the open resonance circuit between them. If so, then this could be the Stepanov device.
vrand
Quote from: Сергей В. on July 22, 2013, 07:28:21 PM
Привет всем !!  :D
News from Reptilian's England !! Which can't be seen on any Western MSM. Interesting isn't it ?? Who have banned, for people of planet Midgard Earth ?? MI6 maybe ??
Original footage - From Reptilian Farm somewhere in Lancaster  :D - ENGLAND REPTILIAN-ALIEN-TECHNOLOGY  REPTILIAN-ENERGY-MULTIPLIER-IN-WORK.
Video made by my frend Joe XXXX !! Several hours after posting most interesting videos his channel and many Real Reptilian Video Proofs were wiped-out from JewTube.
Free download
http://webfile.ru/6613164
ps: You haven't any idea how much Reptilain Farms exist in England today !! Even in your nightmares !!. Folks these suffs are only soft things. Hard things which have happend in England you can't imagine. Real Nightmares !! 4million abductions in USA is not a MYTH !! Think about !!
ps2: Almost all Reptilian UFOs can't be seen by Human Eyes watching but any new Cameras and single-lens reftex cameras (photographic) can catch them without any problem.
Question: Why human eyes can't see it while cameras do ? Deduction logic said - Reptilians use PSY WEAPONS  - PSY FORCE FILEDS for cover their material presence and their crimes. You watching in the sky and keep your spirit quite... there is nothing there but reality show us contrary. Conquered and Totally defeated .. even withouth any idea "WHY ??".
Buy samsung sdc-435 ir-security-camera and convince yourself personally.
Thank you for sharing that very interesting video and info on the Samsung video camera, keep up the good work!  :)
Cheers
vrand
Quote from: Сергей В. on July 22, 2013, 08:35:31 PM
Only for Experimenters
Гость УСТАНОВКА 2 kwatts on 220V
http://www.youtube.com/watch?v=gz0IPdPbHvA
Author (not ikako chubinidze) achieved 2kWatt output power with 100watts input.
Use Nanoperm stripes 2cm = about 0.78 inch wide.
Master ТДКС oscillator (HV-TV transformer with built in HV diode(s)) must be very stable and thermally compensated. Any industrial ШИИ (PCM) will be good here. Also you can use master oscillator based on microcontrollers and high speed mosfet drivers. For isolation use GDT gate drive transformers. Optics is too slow here. Schematics can be found on internet.
This circuit need very fine tuning and very sensitive is to pulse-with and Cкважность parameters.
Cкважность is our Russian term and means pulse period-to-pulse duration ratio or relative pulse duration.
S=1/D
D= duty cycle.
Use Aviation aluminium for tube. Diamtere 5 cm - 2inches. Bifilar was wounded in counter-plan. 1/2 half righ direction - other 1/2 left on whole lenght. Output power also depend from distance between Nanoperm windings. Tune it between 1-2.5 mm and keep the distance step constant. Use good Earth grounding. Heavy cooper bars deep in wet soil and check earth conductor with compass !!
Удачи !!
ps: It seems to me there only couple of CE people doing experiments. Other fishing in "troubled waters".
Thank you for this very interesting design!
Can I buy one to power my home?
There is a HUGE demand for such a device!  :)
Cheers
