0 Members and 196 Guests are viewing this topic.
bolt
How come not ONE person has drawn out a circuit or anything even slightly close to KAPAGEN system?
if so show me..... every one i seen is NOTHING like KAPAGEN.
How can you expect to replicate before having an idea of the circuit?
Same thing happened with the TPU where SM said use 3 control coils and 3 collectors but somehow the forum DECIDED it had to be 1 collector and 4 Control coils.
FreeEnergyInfo
bolt
The spark gap cap is in the wrong place. it needs to go the either side.
NST 25Kz sends pulses thru gap into LC tank where C sets NEW frequency C often only 0.001uf to get 100Khz+ and tuned into L2. The purpose of spark gap is frequency changer.
In KAPAGEN he dont have a cap in vid shot nor even a diode. This is ROUGH untuned using total BRUTE force of MOT to create a total mush and some of the desired harmonic gets through the system. When tuned spark gap tiny corona fiz not more then 25w-100w i/p. However I suspect Naudin has added stuff INSIDE his box to tune up to get better loads as later vids show.
Be aware most NST are center grounded through PSU via mains. This completes the LOOP thus you think only one earth required to o/p load not realising ground number 2 is your mains earth.
Go into middle of field using inverter on battery it will NOT work properly into heavy loads without 2 earths.
O/p requires tuning into load using common RF loading technique. Try using Pi-tank and L trap filters to match load.
RE = RF
hartiberlin
I guess this is really the circuit Jean Louis is using.
It can be dangerous, as when you charge up the HV cap with the MOT,
if you touch the HV cap you will be dead.
So be very carefully, if you play with something like this.
I will take no responsability to any accidents.
I guess the center back and forth wire for the ground1 through the
center of the coil has no real effect.
He could also just lead it directly from the MOT to the ground1.
It is just a reversed Teslacoil and maybe it has additionally some ferrite core rings
in it under the coils ?
Hope now a few guys can replicate it and Naudin will also come
forward and will say something in his videos.
I hate it, when nobody speaks and narrates in their videos...
Are we still living in the silent movie timeframe ??? ;D
Regards, Stefan.
bolt
Well thanks for the circuit least we got something now which resembles KAPAGEN.
In vid shot of open box there was no diode or cap to be seen. Perhaps a slide of hand ploy and it was added later who knows. But this will pump up volts to 4kv with diodes and MOT cap and MOT are shunted design so no current limit. Connected direct to mains will be a disaster!! MUST use current control and dial up voltage supply adjusted very carefully increase from 25 volts and slowly up just to get ARC going. Too much and white molten copper and iron will fly everywhere.
I have a MOT here beside me now. NO WAY i use it like this direct to mains. Use NST or car coil instead.
Now everyone warned many times so go ahead set your house on fire or cya in heaven if you touch it! :)
