0 Members and 121 Guests are viewing this topic.
Grumage
Quote from: elementSix on July 29, 2013, 02:32:28 PM
Thanks yfree.  I always appreciate help in trying to understand this.  I think I just got a little more info in my head and got the whole workings of this phenomenon.
This is a questions for Grumage and Zeit, because I value your input.  Weather its in opposition or in a helping way.
I was reading about how Tesla saw this radiant spike when working with Edison's linemen.  The moment of switch closure when the HV DC hit the long lines of resistance, the radiant spike would appear right at that instant.  He also says that the moment the electrons start moving in the line, the spike disappears.  The current stops the radiant spike from forming.  He calls this Electrostatic Force.  So in a way the HV DC creates this Electrostatic force to appear at the moment the Impulse is created, but the current makes it stop.  So in a way the a very quick and abrupt HV DC impulse that travels over a wire creates a form of electrostatic radiant energy.  Now this is my question.  Do you believe that if the current was eliminated completely, would it be easier to create the radiant spike?  Look at it in just a different way of Resonance with the Current.  Isn't that what Resonance is, when there is no current being consumed in the circuit.  Or am I completely off the course?
Dear Element 6.
You have sort of answered your own question. What you are doing is feeding your circuit with HV pulses. No current flows until the spike appears. But then that current dies untill the next pulse comes.
Unfortunately Current goes "hand in glove" with Voltage and Resistance.......http://en.wikipedia.org/wiki/Electric_current
Resonance is the flow of Voltage and Current between an Inductor and a Capacitor, if there were no resistance in the circuit then it would "Ring" forever. But in the real "Room temperature world" we cannot escape the resistance. So we always see a "ring down"!!
Recently T-1000 suggested that it could be possible to bring the two elements, Voltage/Current, along different paths and combine them at the load. Unfortunalely I have since forgotten the middle bit :)
Cheers Grum.
Zeitmaschine
Quote from: Grumage on July 29, 2013, 05:18:58 PM
High voltage attracts electrons from ground. Since the high voltage circuit is not closed there is no load on the power source. But since more electrons means more current, the output power is amplified. Now implement this idea in a SIMPLE (3-phase) device. That's the middle bit. :D
magpwr
Quote from: Zeitmaschine on July 29, 2013, 09:00:00 PM
Hi Zeitmaschine and Grumage,
I think this "Ring down" mentioned by Grumage  and electrons from ground mentioned by Zeitmaschine did ring a bell for me.
You see i worked with "useless to many people" micro voltage as low as 25mv...45mV and boost it to useful voltage around 8volts.If you do search in youtube "25mV" or "sanjev21" my video posting.I have also posted in this site under joule thief\25mV.... where few people successfully duplicated my device and miniaturized it.One of the member in my created topic  is using "low voltage from ground "to power my device and it works.Unfortunately i live in an high rise apartment not grounded property for me to easily connect something to ground.
Not lets get back to the topic,This part i'm gonna attempt to explain to everyone whom is working on Kapanadze device on how i link my observation in few Kapanadze video in a very simple way.This might allow some to understand.
For a start i'd assume everyone whom is reading have seen Kapanadze video where a person just use a 12v battery merely to kick start the oscillation to power lights then disconnect the battery.Keeping in mind there is only single wire connection to the ground to obtain power.I'd believe this allows the Kapanadze device to "sustain oscillation" or prevent a ring down as mentioned by Grumage.
Now lets get back on my findings related to low voltage source example:ground power.Base on my knowledge if you use any npn or pnp transistor for it to self start oscillation provided there is small voltage source.There is 2 ways for transistor based oscillater to self start 1)Provide sufficient voltage exceeding 0.6 volt eg:1.5 volt or 12 volts battery as seen in Kapanadze video.
2)Temp Short the emitter and collector of transistor if voltage is below 0.6volts to kick-start oscillation.
I hope my explanation does ring a bell for some involved in Kapanadze.
elementSix
I found a British patent for Tesla that had all his High Frequency Impulse driven devices in one patent.  These parts are taken from that Patent..
Сергей В.
Всем Здрасте !!  :D
Finnaly elementSix !!
It's main reason why i have uploaded a link on Tesla archive !!  :D
WATCH CAREFULLY EXPERIMENTS, THINK, AND MAKE OWN CONCLUSIONS !!  :D
http://www.youtube.com/watch?v=7jtjgAwXqGg
http://www.youtube.com/watch?v=6_W3ElVScHw
QUOTE Руслан:
"The GOOD FELLOW "chiksat", the only, correct and visual aid for understanding process of energy transformation, without going into details. Laziness to describe all Charm of this direction, because here are all so clever, and all-knowing. Only for some reason passed all this, by ears and eyes! any more one hundred times. Just in case I will write, maybe suddenly it will interest someone. To move a heap of sand whiff of a wind it is necessary to throw it, and here, we raise electrons, thereby we provoke them to be as though in a suspension, then with a unipolar magnetic impulses we blow off, thereby we give movement to charges in the direction necessary to us! passing resistance of conductors, so it is created pseudo over conductivity, and some more effects. Only after that, removing the resultant energy, we will transform in form necessary for the consumer.
P.S. - Specially wrote this post, that your video of Uv. "chiksat" looked once more and reflected
those - to whom it is necessary !!".
http://realstrannik.ru/forum/39-kapanadze/108060-generatory-kapanadze-obshhaya-tema.html?start=5670#144629
QUOTE With:
"You correctly focused attention on this video, and about a phenomenon of emergence of "statics" in such system. If with a smaller share to "sarcasm" we look at the scheme which was thrown out by somebody "Akula", it is possible to notice that the author in the design modulates an "electrostatic" charge with a powerful magnetic field, received in an inductive chain of separate oscilating contour, resultant modulated "the statics merges" through active loading to the earth."
http://realstrannik.ru/forum/39-kapanadze/108060-generatory-kapanadze-obshhaya-tema.html?start=5670#144651
So folks now you Finnaly know how to get FREE ENERGY !!  :D
It's all ok but there is one of biggest problem currently unsolved on this Midgard Planet. How to stop JEWISH ILLUMINATI CABAL to start WW3 and finish with all Life on our beautiful planet ? If somebody have any idea i am listening carefully !!
Their last madness - Very soon they will hire professional killers and mercenary as a "PEACE KEEPERS" for UN DIRTY JOBS like OFFICIAL U.N. WELL PAYED INDEPENDENT WARRIORS "U.N. PEACE MAKERS TROOPS". !! NWO ZOG ARMY !! Read the Trumpy blog he have really great infos - http://endzog.wordpress.com/
THIS MEANS ONLY ONE - PREPARATION FOR FINAL WW3 !! WHO WILL NEED FREE ENERGY ON TOTALY BURNED AND RADIATION PLANET ??
ps: РУСЬ БЫЛА ВСЕГДА !! И БУДЕТ РУСЬ !!
Умом Россию не понять
Аршином общим не измерить:
У ней особенная стать –
В Россию можно только верить.
Ф.И.Тютчев (1866)
Удачи всех благ !!  :D
Сергей В.
