0 Members and 58 Guests are viewing this topic.
sadang
- 1896.09.22 - GB20981 - Nikola Tesla - Improvements relating to the Production, Regulation, and Utilization of Electric Currents of High Frequency and to Apparatus therefore
And Sergei, we are not alone on this planet, we are very fully observed by different extraterestrial beings... so, just do what you think you have to do at your level of existence... and this is more than enough to change the world!
sparks
   Is the Earth just a piece of metal in a very high voltage electric field?  If we have a capacitor charged  and we insert a piece of metal between the plates doesn't the third plate develop a potentialt depending on it's geometric placement relative to the outer plates?.  Look at Edison's network.   Tons and tons of copper strung on insulators in the air.   Look at the voltage drop per meter between a buried radiator and wires elevated for miles and miles and miles above the ground on insulated terminals.  .   How did Tesla remedy the problem Edison had?  Edison could not bring thousands of volts dc into homes.   They used dc motor generator systems.   The entire network was insulated.  The entire thing represents a conductor placed in an electrostatic field.    Electric fields penetrate insulators and terminate on conductors.  A seemingly huge electric field terminates on the little conductive ball we are flying around on.   It also terminates on the moon.  It also terminates on any of the planets.   Checkout the Brown Bifield  effect.  Two large metal balls charged up to thousands of volts swing in a predictable manner then stay swung.  Defying gravity more or less.   Relaxation of the charged metal balls results in the balls returning to normal gravitational restraints.  He also found that the movement of the moon and other planets results in how these balls fall.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
starcruiser
Quote from: Сергей В. on July 30, 2013, 01:38:55 AM
Всем Здрасте !!  :D
Finnaly elementSix !!
It's main reason why i have uploaded a link on Tesla archive !!  :D
WATCH CAREFULLY EXPERIMENTS, THINK, AND MAKE OWN CONCLUSIONS !!  :D
http://www.youtube.com/watch?v=7jtjgAwXqGg
http://www.youtube.com/watch?v=6_W3ElVScHw
QUOTE Руслан:
"The GOOD FELLOW "chiksat", the only, correct and visual aid for understanding process of energy transformation, without going into details. Laziness to describe all Charm of this direction, because here are all so clever, and all-knowing. Only for some reason passed all this, by ears and eyes! any more one hundred times. Just in case I will write, maybe suddenly it will interest someone. To move a heap of sand whiff of a wind it is necessary to throw it, and here, we raise electrons, thereby we provoke them to be as though in a suspension, then with a unipolar magnetic impulses we blow off, thereby we give movement to charges in the direction necessary to us! passing resistance of conductors, so it is created pseudo over conductivity, and some more effects. Only after that, removing the resultant energy, we will transform in form necessary for the consumer.
P.S. - Specially wrote this post, that your video of Uv. "chiksat" looked once more and reflected
those - to whom it is necessary !!".
http://realstrannik.ru/forum/39-kapanadze/108060-generatory-kapanadze-obshhaya-tema.html?start=5670#144629
QUOTE With:
"You correctly focused attention on this video, and about a phenomenon of emergence of "statics" in such system. If with a smaller share to "sarcasm" we look at the scheme which was thrown out by somebody "Akula", it is possible to notice that the author in the design modulates an "electrostatic" charge with a powerful magnetic field, received in an inductive chain of separate oscilating contour, resultant modulated "the statics merges" through active loading to the earth."
http://realstrannik.ru/forum/39-kapanadze/108060-generatory-kapanadze-obshhaya-tema.html?start=5670#144651
So folks now you Finnaly know how to get FREE ENERGY !!  :D
It's all ok but there is one of biggest problem currently unsolved on this Midgard Planet. How to stop JEWISH ILLUMINATI CABAL to start WW3 and finish with all Life on our beautiful planet ? If somebody have any idea i am listening carefully !!
Their last madness - Very soon they will hire professional killers and mercenary as a "PEACE KEEPERS" for UN DIRTY JOBS like OFFICIAL U.N. WELL PAYED INDEPENDENT WARRIORS "U.N. PEACE MAKERS TROOPS". !! NWO ZOG ARMY !! Read the Trumpy blog he have really great infos - http://endzog.wordpress.com/
THIS MEANS ONLY ONE - PREPARATION FOR FINAL WW3 !! WHO WILL NEED FREE ENERGY ON TOTALY BURNED AND RADIATION PLANET ??
ps: РУСЬ БЫЛА ВСЕГДА !! И БУДЕТ РУСЬ !!
Умом Россию не понять
Аршином общим не измерить:
У ней особенная стать –
В Россию можно только верить.
Ф.И.Тютчев (1866)
Удачи всех благ !!  :D
Сергей В.
I viewed the videos you linked to and noted that the video http://www.youtube.com/watch?v=7jtjgAwXqGg uses 2 separate systems, one is the HV side and the other seems to be a simplistic inverter, possibly square-wave, my assumption due to the chip size looks like a 555 timer for the signal source. The "magic" seems to be the field from the heavy copper coil (inductor) influences the transformer (strengthens it) when it is running. I would be interested in knowing how the proximity of one to the other influences the output.
I am thinking the transformer core is the gain medium/collector in this case thus increasing current and voltage. I would be interested in knowing what the current draw is for the HV system and the inverter system to see if the battery is the current source for the latter (inverter).
synchronizing the 2 systems is rather easy IMO if we are looking for the HV to pulse at the line frequency.
Regards,
Carl
Zeitmaschine
OK now, drawings (Mosaics) of NILSON BARBOSA patents have arrived. So who tells me how this stuff works? :D
Hopefully these are not just another mumbo-jumbo patents like the TK and Stepanov ones. :(
andrea76
Quote from: elementSix on July 29, 2013, 02:32:28 PM
Thanks yfree.  I always appreciate help in trying to understand this.  I think I just got a little more info in my head and got the whole workings of this phenomenon.
This is a questions for Grumage and Zeit, because I value your input.  Weather its in opposition or in a helping way.
I was reading about how Tesla saw this radiant spike when working with Edison's linemen.  The moment of switch closure when the HV DC hit the long lines of resistance, the radiant spike would appear right at that instant.  He also says that the moment the electrons start moving in the line, the spike disappears.  The current stops the radiant spike from forming.  He calls this Electrostatic Force.  So in a way the HV DC creates this Electrostatic force to appear at the moment the Impulse is created, but the current makes it stop.  So in a way the a very quick and abrupt HV DC impulse that travels over a wire creates a form of electrostatic radiant energy.  Now this is my question.  Do you believe that if the current was eliminated completely, would it be easier to create the radiant spike?  Look at it in just a different way of Resonance with the Current.  Isn't that what Resonance is, when there is no current being consumed in the circuit.  Or am I completely off the course?
[/quot
see this post : www.overunity.com/712/the-master-of-magnetics-steven-mark/msg19140/#msg19140
