0 Members and 94 Guests are viewing this topic.
HG8AD
Quote from: magpwr on August 04, 2013, 11:56:27 PM
Hi everyone,
After posting Antanas /LITHUANIA circuit diagram and digging through some youtube videos.
I am entice by this full uncut video which also include the ringing up waveform from oscilloscope   https://www.youtube.com/watch?v=A7jbUA6_10c      which also speaks some english.
A person in video mentioned there is high level of violation related to conservation of energy and there is a part where they measured in the input from mains at 3.4watt to power 100watt light bulb.
This is for people whom wish to build this OU device.I am currently involved in HHO project at fine tuning stage to further increase HHO bubble production after my recent video upload.Refer to my youtube channel "sanjev21" .
At this moment i manage to grabs the full understanding on how to assemble the coil base on youtube description and video.
Procedure to assemble primary and secondary coil base on my understanding as shown in video.
Caduceus coil primary winding using (length 1metre/100cm per strand) of 2mm wire which consist of 5 strands in parallel on 45mm diameter tube-Video.
Please see youtube description.
https://www.youtube.com/watch?v=PmJg1Kmbgk4
There is a layer of insulation between primary and secondary.This would make tube diameter increase to 60mm.
Secondary winding description-
60mm with insulation one wind secondary wire length: 23.5cm Secondary coil: secondary wire length 520cmx2, 10cmx3 for connections The right hand + left hand winding. The right
hand winding goes to caduceus coil connectors side. capacitance between primary and secondary 143-147pf All wires have same diameter - 2mm.
(My observation base on video related to secondary coil from center tap is 24 turns(2mm wire) towards to the Caduceus leads out and i noticed 24 turns towards the another
end which is not connected to anything.Refer to the full uncut video https://www.youtube.com/watch?v=A7jbUA6_10c at 2:44min.From centre tap i understand what right hand winding and left hand winding finally means.)
https://www.youtube.com/watch?v=A7jbUA6_10c      (15:02/31:30)
The current uptake not 15mA , rather 150mA... so the primer performance uptake 34,... watt ...
elementSix
Hey, I think I found a switch that might work for my Tesla Kapanadze replication.  Since I am broke at the moment, I think I might try this or something similar.  Any thoughts on me using a switch like this to create the Make and Breaks for the Impulse wave??  I will eventually get a Thyristor type of Impulse generator to create much faster Impulse trains and be able to vary the speed of the impulses and maybe see if that will keep resonance.  If not I am sure I can figure another way to do it.
ELECTROSWITCH 6 CIRCUIT ON/OFF 30 AMP/500 VOLT ROTARY CAM SWITCH
http://compare.ebay.com/like/151093915900
Acca
To: magpwr.......
here is the video when Wesley went to Lithuania and shot that video of the diagram post by you.  try stivep1 on youtube.
https://www.youtube.com/watch?v=7GlaYj7J5s8
Acca..
Zeitmaschine
Quote from: TinselKoala on August 05, 2013, 09:42:54 AM
I have long been of the opinion that one of Tariel's tricks is to use a simple wireless inductive power transmission system.
Then what are the tricks of Nilson Barbosa?
Astoundingly no one here seems to be interested in the Barbosa patent CAPTOR DE ELÉTRONS since pages. Could this be a hint that this is the right track to go? :D
Could there be indeed a »trick« of Nilson Barbosa? Is this »trick« to use coils on an E-core with DC current?
»It is observed also in Figure 4, the power wires 3.1 and 3.2 - phase or neutral - that are input from external power coil 1. The power coil 1 can be provided from any source of supply of electricity with electromagnetic potential as a power grid. The trap electrons can be built to current configuration or setup for alternating current. Thus, if the power source is alternating electrical current - AC, the sensor provides alternating electrical current - AC. If the power source is in continuous electrical current - DC, the sensor provides continuous electrical current - DC. The trap electrons earth can be single phase, two phase or three phase, low, medium or high voltage.«
An E-core transformer (actually transducer) that works with DC? ???
Maybe I should do some experiments ...
NickZ
   Zeit:
   I've tried to look for information concerning the device invented and patented by Nilson Barbosa, but I have only found a video of his lecture on the internet.
I am interested in his ideas, but, when trying to open the PDF file that you've linked to, I can only view the first page, or so.
  So, do you have a link that will open, to view more of his work? Or is it just me that can't get to it? I can read and write in his language
   NickZ
