0 Members and 94 Guests are viewing this topic.
a.king21
Sometimes we forget that the ground is a magnetic resevoir  - it's called the magnetic field.
penno64
Quote from: Jack Noskills on August 07, 2013, 08:17:54 AM
Stepanov has got a patent for his transformer/power amplifier:
https://data.epo.org/publication-server/pdf-document?PN=EP2429071%20EP%202429071&iDocId=7713424&iepatch=.pdf
Does anyone know if he has found a partner that has capability for mass production ?
I guess soon there is no need for Tariel to arrange shows anymore. Maybe he does not know about this, if not then I think he should be informed.
Hey Jack,
How are things going?
I had a go at a Tesla switch a while back but, this patent application makes more sense in that the pulse via the transformer (in my case will 240/12) will really drive the secondary.
The TS was said to run best at around 400Hz - wonder what this setup runs best at?
Switching is of concern - what would you use to handle around 400Hz and a couple of amps?
Regards, Penno
a.king21
Zeit: Your patent find is a gem.
Here's an extract machine translated from Portugese:
The equipment object of the present invention works as follows: the electromagnetic field generator device to be powered by an electrical power source, produces an electromagnetic field that induces an electric current in closed circuit in conductor element itself, creating an interaction between the magnetic steam equipment and terraced Earth magnetic, passing there-through electromagnetic repulsion and attraction-an endless supply of electrons of the conductor element in closed circuit itself, which is connected to ground through a mesh of conductive interconnect element. The electrons attracted add up to this current that circulates in closed circuit in conductor element itself, where electricity is available for high power loads, although the equipment object of the present invention is powered with a small power. Thus, in a manner advantageous, the equipment object of the present invention is an electron trap, for electric power generation.
I wish there was an English version
Zeitmaschine
In theory, what could happen when ground is connected via a diode to a circuit or something that acts like a diode?
On the other hand, there is no diode depicted in the Barbosa patents. ???
magpwr
Quote from: steadyfield on August 07, 2013, 02:44:33 AM
hi everyone,
i'm from china and i'm new to this forum.
the translation tool doesn't work very well and it's hard for a chinese like me to get through the translated sentences.
so let me translate what you said.
May i ask which circuit diagram are you using to build this device.
translate:请问你这个装置用的是什么电路图?
Can you upload diagram to show us which one.
translate:你能上传一个(这个装置的)电路图吗?
in my opinion,what xiaoke2727 is trying to replicate is the Chubinidze ikako device.the youtube link is http://www.youtube.com/watch?v=gz0IPdPbHvA
by the way,i'm also trying to replicate this device,but i have no idea how the resonator coil is wound and how many turns is the coil.
in addition,i don't know how to tune it to resonance.
attached is a possible diagram.
sry for my poor english.
Hi steadyfield,
Not bad your english is good.
May i suggest you directly response to  "xiaoke2727" in chinese.He would receive the email notification from you and he would understand.
This experiment you need electronics,electrical knowledge ,equipment oscilloscope,L/C meter to measure capacitance and inductance if your multimeter do not have one.
Additional knowledge in radio tuning like resonance is required.
The easy part of these experiment with electronic knowledge is assembling the driver stage for the hv transformer."""""""""""High voltage''''''''''''''''''''''
Using search in internet there is many sites which shows how to locate ground pin(cold side) for HV transformer.
For spark gap i think using motor vehicle spark plug is better solution.Save time in construction.But spark gap needs to be knocked down a little more to reduce the gap a little bit,maybe.
You will need to know the current resonance frequency of hv transformer while in operation.This can be tuned further at driver stage to reduce current draw maybe.
The receiver stage for this design i'm little lost due to insufficient understanding from drawing.I understand only 1 part, 2 winding of 80 turns to get 120uH.This is subjective as the diameter of coil is unknown,so need to wind 10 turns more at 1st then use L/C meter,value should be around 120uH.
I would like to get involve in this HV project but i'm currently involved in HHO project - increasing HHO production using just 1 watt of power using just tap water only.Just to observe increase in bubble production using lower power at first before increasing power.Ultimately my experiment may go 2 ways one way to create HHO fire(2800C) via blow torch to power existing stirling power generator(Master plan is to power 1 or 3KW solar concentrator engine(Merely need 2000C ) or buy 1 K/W small common generator and fine tune engine for hho.
I just release one more video yesterday in my youtube channel "https://www.youtube.com/watch?v=NJw4SSjnejM" version 2.0 of 1watt HHO generator.
