0 Members and 54 Guests are viewing this topic.
MenofFather
Quote from: Grumage on August 08, 2013, 11:12:12 AM
Dear All.
There seems to be some new interest in the devices recently posted by Sergey. And some new constructors, that's great!! I spent quite a lot of time with this one but found that the Resonator details were missing. With the most recent posts new data has been furnished with regard to said resonator. Namely that it should be 300 turns CW/CCW from center. I have posted a picture of one I wound recently. It is made of 0.72mm dia wire and wound 150 over 150 so as to get a length suitable to fall within the outer coils length. I am currently waiting for a price on some Nanoperm toroids to fit within the coil tube.
For those that may not have seen my original experiments with this device....................https://www.youtube.com/watch?v=VXIca35GeIY
I was using a Royer oscillator driver instead of the spark gap generator.
I hope the above is of some use to our very welcome newcomers.
Cheers Grum.
I think you can use electric spark gap like Dally, but woltage, better is highter. Best it be about 2000 V and shorter is better. Can use 1000 V and nanosecond pulses like Dally make. What you voltage of you pulses, like I understand?
zcsaba77
Quote from: magpwr on August 07, 2013, 11:36:24 PM
I would like to get involve in this HV project but i'm currently involved in HHO project - increasing HHO production using just 1 watt of power using just tap water only.Just to observe increase in bubble production using lower power at first before increasing power.Ultimately my experiment may go 2 ways one way to create HHO fire(2800C) via blow torch to power existing stirling power generator(Master plan is to power 1 or 3KW solar concentrator engine(Merely need 2000C ) or buy 1 K/W small common generator and fine tune engine for hho.
I just release one more video yesterday in my youtube channel "https://www.youtube.com/watch?v=NJw4SSjnejM" version 2.0 of 1watt HHO generator.
Hi MagPWR
... and did you OU in HHO production?
regards zcsaba77
zcsaba77
Quote from: steadyfield on August 08, 2013, 09:48:56 AM
Hi,magpwr
well,here's another schematic with the same coil configration.
If you look the schematic carefully,you'll find that the resonator coil L3 is wound cw then ccw.So the magnetic field that the L3 generated is zero.
The L2 and L1 are wound in the same direction.The end of L1 is connected to the end of L2 through the load,so the magnetic fields that L2 and L1 generate cancel each other.So the sum of the inductance of the coil L1,L2 and L3 is nearly zero.It's likely that L1,L2 and L3 forms an inductor with an inductance of zero and this "inductor" is connected in parallel with the capacitor C2.One end of the capacitor is connected to the ground.
In this way,we have nearly no inductance in the LC tank formed by L1,L2,L3 and C2.So theoretically,there will be NO RESONANCE in the LC tank.It seems that the the circuit needs NO TUNNING.That's so strange to me.But I do think the circuit needs unconventional ways of  tunning and there are some kinds of resonance in an unconventional way.Do you have an idea of tunning it?
I'm sorry for not being able to explain what I mean clearly,Also for the grammar mistakes.I hope you understand what I mean.
thks a lot!
Hi
I dont know which one video was, but I saw somewhere on mr Aldis Masteiko channel:
https://www.youtube.com/watch?v=m_juZJSV9jE
One bifilar coil inner end was connected and next end was loaded by bulb or water heater kettle, and work, I same not understood how, but work.
regards zcsaba77
p.s.: but mr. Sergej V. can explain how it possible
steadyfield
Quote from: stivep on July 09, 2013, 11:32:39 AM
I was ask for help from China 我是问中国的帮助 谢谢你,我的中国朋友们
http://www.youtube.com/watch?v=j7mh0NuUsvg
There was so many similar construction designs to the point of response requirement.
I'm asking to participate in it by posting all of other designs similar in nature and your response to it.
My personal opinion can not come prior to me analyzing it.
Please notice that only one of coil connection ways makes motor to turn.
60W light bulb, unknown voltage and unknown current as of yet.
Light bulb is sort of interesting by itself
Please include links related to 3 coil transformers or modified transformers.
As this experiment is so easy to replicate I assume that there would be many of you checking it up on the spot..
There is also need to find exactly the model number of motors used in experiment.
What I have noticed is that windings are exposed so natural question would be if original winding was altered or not.
Wesley
由于这个实验是如此容易复制,我以为会有很多你当场检查..
还需要准确地找到实验中使用的电机的型号。
我注意到的是,绕组暴露,所以很自然的问题是,如果原绕组被涂改或不。
有这么多类似的建筑设计的角度响应要求。
我要求参加张贴所有性质类似的其他的设计和你的回应。
我个人的意见之前,我不能来分析它。
请注意,只有一个线圈连接方式使电机转。
60W的灯泡,未知电压和未知的目前尚未。
灯泡本身是一种有趣的
请包括3线圈变压器或改性变压器相关的链接
Hi, everyone
well,someone talked to that chinese replicator yesterday and he posted some pics about the shaded pole motors self-looping device.
As the pics show,the rotors of the shaded pole motors have been modified.He added a ferrite ring magnet to each of the rotors.
So as it spins,the coils generates electricity.
As it comes to why he chose shaded pole motors to modify,I think it's because of their high mass rotors,which could act as flywheels.
That chinese replicator said "I'm not claiming any free energy."Maybe he is afraid of FE suppression or something else.
For the Chibinidze kapanadze device,I decided to wound 20 turns on a pile of 3 ferrites for the resonator coil.10 cw and 10 ccw.
If that doesn't work,I will try winding the 20 turns in the same direction.
regards,
steadyfield
