0 Members and 159 Guests are viewing this topic.
Acca
This topic is a liitle off as it deals with HHO, however I feel that there is a link between "iron ferrite" that goes in in to the Kapanadze coil core and the description by Dr. Mark Hugo.. as there is a common thread as to why Iron is so important in this device.. The crystalline ferrite core "of the the RIGHT TYPE" as it's composition is very important. it's activation by the square waves, two units needed.. as well as a "very high frequency"  RF  flyback oscillator in the 22 Khz - to 100 Khz. Now that is being produced is an "RF" type of effect.  Now very high energetic neutrons are generated just enough that the most radiation detectors will not register as these thing just fly through most matter.. What I hypothesize is just like the low 100 watt piezonuclear reaction that the Italians got from ferric chloride was "neutrons" and a cascade of decay.. I am suspecting that the ferrite reactions with the Kapanadze unit was and is a nuclear based generator.. What has to be done is to pump enough amps in to the square waves as to produce multiple harmonics with a combination of the RF component from the HV flyback transformer and start measuring gamas that can be detected if the ferrite core is placed in to a matal tube to slow down those emissions, however that will alter the kapanadze core.. it's a catch 22.. Just some suggestions ..
Dr. Hugo provides an explanation of how the possible HHo has so much power as it does NOT add up.. So his explanation is that it's a nuclear process.. Just what the Italians discovered with 100 watts of power. Once you do NUCLEAR with low energy, it opens all kind of potentials..
http://www.youtube.com/watch?v=foIWltOShO0
Mark Hugo demonstrates how HHO may be a nuclear process involving cold fusion, and may also be the force responsible for the Papp Engine.
After modifying a Buick Park Avenue sedan to run on an HHO (Brown's Gas) and gasoline mixture, he found a 30% increase in fuel-efficiency from the HHO addition. This led to some difficult questions, however, because the amount of Brown's Gas being added to his fuel mixture was miniscule, so he began searching for another explanation.
Hugo found the work of Dr. Richard A. Oriani and James C. Fisher, who claim to have validated cold fusion alpha-reactions inside of traditional HHO cells - which are built very similar to HHO electrolyzers. Hugo found their research compelling enough to begin researching Oriani's tests on cold fusion involving CR-39 detectors, which seem to indicate energy emission during cold fusion events that exceeds even that in traditional "hot fusion" experiments (on rare, per-event basis).
Realizing that HHO and Brown's Gas may in fact contain cold fusion reactions that account for the increased energy seen in his vehicle, he reasoned that modifications to Oriani's design might result in a "closed-loop" cold fusion engine. As he states in this footage, his next realization is that Joseph Papp might have built just such an engine in 1968.
According to Mark Hugo, the Papp Engine patent almost perfectly describes an electrolytic HHO or cold fusion system for producing the compound Hugo believes produces the cold fusion energy.
He indicates that the Papp Engine's DC supplemental power supply was used to prime the engine as an electrolytic generator before actual operation of the engine through the AC electrical system. He also describes Papp's "capacitor plate" system as a form of Jacob's Ladder, or "gliding arc" to carry the plasma combustion current into the combustion chamber.
While Mark Hugo's description of the Papp Engine as an electrolytic cold fusion reactor may not be complete, he definitely provides a wealth of scientific and technical knowledge on HHO and Brown's Gas, cold fusion, and the Papp Engine in this technical interview.
Finally, Hugo provides detailed instructions to inventors seeking to experimentally test this theory based on his research into cold fusion, the Papp Engine, and Dr. Richard A. Oriani's research.
[/font]
zcsaba77
Quote from: Acca on August 09, 2013, 07:21:59 AM
[/font]
I agree with you, these devices (water splitting by pulse or kapanadze's) working allmost on same principle.
Its flying some theories about how possible if burn HHO and gasoline/petrol together why small amount HHO bring out more power from engine:
1. is possible when HHO itself burn help better burning the gasoline too, or
2. when burn HHO under presure will react itself (will break multitimes) once breaked HHO will burn 10-16x in one explosion, or final is
3. when split the water create sometimes mono-hydrogen and mono-oxygen, and if not found its couple before burning, these mono-atoms burns make much more energy
These theories I read in varios place, now I dont know where.
magpwr
Hi everyone,
I have just uploaded a video based on my experiment on "Avramenko plug" where i use single wire from 1XAAA disposable camera(Hot side-The one which cause test pen to light) to flash tube and post it in my youtube
channel.Take note the diode in disposal camera circuit was bypassed with solder.
https://www.youtube.com/watch?v=AZIpIS_R6LI          .For all other videos type sanjev21 in youtube search.
This circuit took me less than 20minutes to assemble base on available parts.Please feel free to alter capacitor especially C1 to increase flash brightness.If you wish to construct.
My  "Avramenko plug" experiment is related to the posting shown below-
Please refer to page "1234" of this forum where i mentioned about "Avramenko plug" after Grumage highlighted to me.
Referring to page "1233" of my posting where i post about "Antanas /LITHUANIA" device which is using single wire electrical transmission using "Avramenko plug".
If i have the time i will try to construct mini version of "Antanas /LITHUANIA" the receiver coil and then tune it via existing ferrite rod to match the frequency from my disposable camera just to see if there is increase in power\voltage  output from the receiver coil.If there is any OU effect.I will be very happy.
00
Quote from: Grumage on August 08, 2013, 11:12:12 AM
Dear All.
There seems to be some new interest in the devices recently posted by Sergey. And some new constructors, that's great!! I spent quite a lot of time with this one but found that the Resonator details were missing. With the most recent posts new data has been furnished with regard to said resonator. Namely that it should be 300 turns CW/CCW from center. I have posted a picture of one I wound recently. It is made of 0.72mm dia wire and wound 150 over 150 so as to get a length suitable to fall within the outer coils length. I am currently waiting for a price on some Nanoperm toroids to fit within the coil tube.
For those that may not have seen my original experiments with this device....................https://www.youtube.com/watch?v=VXIca35GeIY
I was using a Royer oscillator driver instead of the spark gap generator.
I hope the above is of some use to our very welcome newcomers.
Cheers Grum.
hello grum c!
this coil is to be wound  like akula type coil in two layers. with 40 turns in each layer. since output coils are 80 turns. ratio is important.
00
bringdownthezog
Quote from: bringdownthezog on August 08, 2013, 09:45:03 PM
As long as we understand the concept of two toroids in a self-feeding configuration, that other nits can be overcome.
