0 Members and 49 Guests are viewing this topic.
Grumage
Quote from: 00 on August 09, 2013, 01:41:20 PM
hello grum c!
this coil is to be wound  like akula type coil in two layers. with 40 turns in each layer. since output coils are 80 turns. ratio is important.
00
Dear 00.
Many thanks for the tip I will give it a try once I have my Nanoperm!!
Dear magpwr.
This one, for "Your eyes only"..............https://www.youtube.com/watch?v=S13wymzV0po....... :)
Cheers Grum.
Zeitmaschine
Just for fun: What could be the result when the Barbosa patent is combined with the Kapanadze patent?
The result at least looks interesting. Very interesting. :)
Quote from Principle of work of Tariel Kapanadze's device:
1. The amount of energy, extracted from the second induction coil must be of a magnitude 10-1, or even more, less then the amount of energy, created in the first induction coil.
2. As a consequence of that, the second induction coil's magnetic field has to be much smaller then the magnetic field of the first induction coil.
3. Due to the magnetic field requirement, the physical measures and the induction capacity in Henry of the second induction coil have to be smaller then the first one.
4. Extracting power from the second induction coil - It is a consequence of the difference between the resonant frequency of the first and the second induction coil!!!
Quote from Electromagnetic device for capturing electrons from the ground to generate electricity:
Wrapping the turns of the coil 1, at least one conductive element even in closed circuit 4 itself, forming at least one link (s) / loop (s) lead (s) 4 - may have other shapes - making at least one back around the turns of the coil 1, preferably two turns if the goal is to generate electricity, and preferably four laps if the goal is thermal energy. Either this winding, as the number of turns of the coils around the coil 1 are directly related to the amount of current to be generated in the (s) link (s) / loop (s) driver (s) 4.
End quote.
That means to me, according to both patents the output coil should have only a few (2 to 4) windings and therefore a very low inductance in Henry.
elementSix
This video shows how this guy turns an OP Amp into an impulse gen..  Its not true impulse, but it is the newer type of circuit impulse waves.  It could be useful in the Akula setup.  If I am right, that is an Impulse signal you are feeding from the transistors into the yoke..  If you can tune this circuit and make it more powerful, it might help some one with their replication.  Just an Idea..
http://www.youtube.com/watch?v=6nL3T82nDlo
Check out the video anyways.....  Turn an OP AMP into an Impulse Generator!!
verpies
Quote from: elementSix on August 10, 2013, 12:46:50 AM
This impulse idea and video have a very large yaaaawn factor.
For short and powerful nanopulses, better watch this and this and read this.
