0 Members and 444 Guests are viewing this topic.
SeaMonkey
Quote from: Zeitmaschine
Could a appropriate magnet (or electric field) deflect the electrons in such a way that they are forced to move around in a closed loop forever (instead of striking the screen)?
It is theoretically possible to impart such
cycloidal motion but the "forever" part
may be a huge problem.  Magnetrons make
use of the concept with magnetic and electric
fields.
steadyfield
Hi,everyone
I replicated the chubinidze device,unfortunately,without success.
the resonator coil is 10T cw and 10T ccw wound on 3 ferrite toroids.
aluminum pipe is used.
the bulb doesn't light at all!
http://youtu.be/zM6W_SliP7M
capacitors:
0.303uF
0.91uF
Ground is connected.
coils:
80T bifilar
10T CW + 10T CCW resonator
6T big coil
magpwr
Hi Grumage,
I have just assembled a Antanas /LITHUANIA coil using the  caduceus specs which was seen in video base on my posting on page 1233&1234 of this forum.Took me many eye balling to know the details which was revealed in video.
The cylinder diameter is around 4.5cm and 22cm long which is a hard paper roll.
Pickup\secondary coil copper wire (18AWG 1mm instead of 12AWG)25 turns clockwise or anticlockwise from center  reading: 14uh
18AWG 1mm x 5 (strands in parallel) caduceus formation as seen in video. Before winding secondary/pickup coil it was 0.388uh(Micro Henry) after winding it's mere 0.42uh(Micro Henry).
(I don't think i got the strength if i were to use 5 strand of 12AWG together for one person.haha  :D )
Base on attached photo i was using a "spare old floor cover" which was found in my store room as a high voltage insulator.
The capacitance reading is around 80pf between primary and secondary coil instead of around 140pf as seen in the video.
I will post more results of my finding especially once i have obtained a sweep generator -100KHZ ...10MHZ(This is a digital display frequency generator "
AE20125 10 MHz Sweep DDS Function Generator Kit with optional USB interface which is embedded with software"
which is sold as a kit in ebay below US$100.The key feature am looking out for is the cheapest digital generator with "SYN out" to oscilloscope Ext trigger)  which was connected to caduceus coil with 100ohm resistor and osilloscope reading was taken directly from caduceus coil as seen in the video where ringing up is happening especially during inserting the ferrite or toroid core in series which as seen in video was seperated by some tiny gap.
Meantime i will play around with existing HV inverter circuit running at certain frequency ,i will report any unusual findings if i have seen any using existing ferrite rod which i purchased last year.
steadyfield
Quote from: magpwr on August 12, 2013, 04:29:33 AM
Hi Grumage,
Hi,magpwr
I want to replicate this Antanas /LITHUANIA device.Do you think it will work if I replace the caduces coil with bifilar coil connected in a way which both of the coils' magnetic field cancels each other?
rgds,
steadyfield
magpwr
Quote from: steadyfield on August 12, 2013, 08:44:56 AM
Hi,magpwr
rgds,
steadyfield
To be honest i'm unable to advise since i have not "really" started experimenting.No one i think have even started in forum,i think if you talking about 2013.
I have merely finished assembly of coil today and currently on planning stage in my head a mini lab. :D
But i noted in your posting today you showed a picture.For the looks of it you are using a "neon inverter" maybe found in deco pc lighting or something close to that.
Like i have mentioned oscilloscope is required and finding around maybe in youtube is the best place especially in the area of "resonance" ,hv and etc.
You will need to create your driver for hv stage or least follow circuit diagram.If you just post a picture and said oh it's not working.
Nobody will understand.It's best you create video maybe once you done hv transformer with spark flying across something.
Voltage reading from receiver or scope shot or something like that.People may understand what you are doing esp if you show a circuit diagram what you are working on in video.
If you started in this quest as mentioned previously you will need to be well versed in many fields as 1 person or a interested friends within your area  this may speed up discovery as part of R&D.
