0 Members and 140 Guests are viewing this topic.
verpies
Quote from: Zeitmaschine on August 12, 2013, 09:25:25 AM
Now what if the electric field created by the high voltage attracts the electrons from ground (cathode) and the magnetic field of a transformer keeps them in a closed loop (anode)?
Sounds rather easy since the electrons can stay in a wire all the time, no vacuum necessary.
The confined electrons would be deflected and confined circularly by the static magnetic field, but:
1) I vacuum they would lose their kinetic energy due to the Synchrotron radiation.
2) In air they would also lose their kinetic energy to collisions with air molecules and Bremsstrahlung radiation (also see other  scattering)
3) In metals they would also lose their kinetic energy to collisions with the metal lattice (a.k.a. resistance).
Lenz law also applies to currents and magnetic fields formed by free circulating electrons.
The Faraday Homopolar generator and the Hall Effect work on the principle of deflecting electrons in solid matter by magnetic fields.
magpwr
Hi everyone,
I have just killed 2 birds(2 successful experiment) with one stone(1 hour)late last night.
My initial objective of the experiment on Avramenko Plug experiment v1.0- To prove Tesla theory "1890s" "Single-wire electrical energy transmission based upon the principle of longitudinal electrostatic waves" (It's also known as scalar wave).
This is the part where it gets intertwine with overunity devices where some or many people describe as getting excess energy from external source.
There is indeed truth in it as it pulls electron from air with HV.(All these are not taught in our school books so don't worry)
Refer to my Avramenko Plug ver 1.0 experiment
https://www.youtube.com/watch?list=UUVgRz6F_kUvAO1l0CPIZRAw&v=AZIpIS_R6LI&feature=player_detailpage
After this experiment i decided to use earth to boost power like Kapanadze as an example.
But since i'm living in a high rise apartment.I can only use the earth from electrical plug instead of ground so there is no chance for me to isolate any other possibilities.
It doesn't matter if mains is switch on/off since mains switch is connected to live wire.
The new setup based on v1.0 Avramenko experiment but this time i connected earth wire to negative terminal of battery in disposable camera circuit.
To my amazement the voltage in my flash circuit based on v1.0 boosted to around 500volts instead of v1.0 experiment around 200volts.
This is the real best part(A eye opener) i decided to connect flash capacitor rated 330v only 120uf which was previously desoldered from disposable camera flash circuit.
The capacitor is able to be charged at rapid rate .This is the part which is off interest to many people it doesn't load the camera circuit.In another words there was no noteable increase in current draw from 1xAAA to camera circuit  "while flash capacitor being charged up".
Many people realised using camera with flash would drain the battery quickly due to frequent or rapid charging of capacitors due to constant flashing.We can normally hear a high pitch sound especially while capacitor is being charged up.
But in my experiment this was not the case due to no loading on transformer.(Anyone please feel free to explain)
2nd experiment within same hour this time using the most recent assembled cadecus coil with pickup coil.(As shown in my recent posting yesterday)
I used "Avramenko plug formation" with another 2 HV diodes but this time i am not using any capacitors at all.
I merely connect the output from Averamenko to my cadecus coil.Then i did check on voltage output from secondary pickup coil it was around 80volts A/C.
But take note i get better reading from meter if i don't connect to anything.I used a test pen to check on 3 points from pickup coil.All point neon light not lit.
Now this is the part where it gets very interesting i merely try to connect one end of 10mm white Led to pickup coil with another end merely connect to wire which is not connected to anything.The led light lit brightly.I used my hand the led lit up even more brigthly for 5 seconds(Take note there was no heat felt)then led went dead for good.This part kills few minutes i then realised the led is dead.I used another 10mm white  led same thing happend after couple of second.
This time i used a zener diode it was late i did not have time to check specs connected it in parallel with 3rd white Led this time i have solved the led problem.But if were to touch the end of wire from led which was not connected to anything the led lit to it's maximum and created a usual light spot on celling.
This 2nd part i'm suspecting a "strong radio wave" at this moment for example if you touch a antenna of walktakie using test pen it won't light.But if you use\purchased a mini circuit to capture radio wave like those found in some girls phone where they attached some fancy light to antenna of phone years ago upon using phone it stay lit.
Other details i wouldl like to reveal is from Hv inverter circuit if i connect to small vintage air cap(Which i in this case used as it air gap for low power hv) then other end of cap to Avramendo plug.The led indicator from pick coil stays the same.
This is the 2nd stage of my discovery where the key interesting thing to note there is no noteable increase in current draw from battery to camera circuit while a flash capacitor is being charged.
This is just the tip of the ice berg.
magpwr
Quote from: bringdownthezog on August 12, 2013, 11:02:30 PM
Can someone please translate this video to English ? Thank you!
http://www.youtube.com/watch?v=GleKyj3S5C4
Hi bringdownthezog,
I have already replicated the circuit using a virtual-electronic-lab since i thought in my mind it should work,on the day that you 1st posted about this circuit diagram.I merely use signal generator IN VIRTUAL running at few KHZ instead of using 741 op amps to transistor.
I did subtitute some components unknown ones or changed to lower value in my virtual circuit.
There is good news and bad news for you.Good news is this is the 1st circuit i have seen in my virtual eletronics lab upon disconnecting the power to the power cap the circuit output to virtual voltage meter is able continue to increase in voltage to a certain point.It stay charged.
Now i got all excited and happy i then tried using load like 10w bulb -no good(expected voltage dropping).
1 watt bulb - no good same effect.
I even used 1K resistor same effect voltage keeps dropping.
I have kill many hours trying to improve.My final outcome the circuit works with no load .Or you like it only works maybe if load is in Mega ohms.
But in actual real life there are loses in capacitor,components and etc so this is a "Fake".But it was a nice logical concept for overunity attempt.
Sorry.
bringdownthezog
Quote from: magpwr on August 12, 2013, 11:25:36 PM
Hi bringdownthezog,
Sorry.
Hi, Wonder what your virtual electronics lab says about 2SGen ?
I'll give you a hint. This very same configuration is used by Kapanadze in his aquarium device and few other devices and is called non-radiative energy transfer in mainstream science.  Thanks for trying   :)
