0 Members and 121 Guests are viewing this topic.
T-1000
Quote from: magpwr on August 13, 2013, 10:13:30 AM
For Antanas /LITHUANIA experiment-
Just to clear some missleadings - Antanas was only man with web page. The experiment was done by me and Aidas
Please read my http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg302619/#msg302619 and further old posts.
Also it is interesting to see someone to pick up whole topic and actually try to replicate it only 2 years after it was intentionaly shared for this... ;)
Also please see original fixed circuit from our first document:
Overschuss
Quote from: Сергей В. on August 13, 2013, 02:41:30 PM
Привет всем !!
Good news folks.  :D Stepanov OU device is in Germany !! So what can be expected ??
Well very soon OU devices will start show on the day light in Germany and start selling in great ammount to all who need Free Energy for family and home. [...]
Hi Сергей В.
I'm German and live in Germany, and know nothing about it. I assume, you too live in Germany. Can you tell me your Sources, please ? Is there any Website that states this ?
Sounds too good to be true (- but i hope you're right)  ;)
BTW: Thanx 4 your Coil-Tips !
steadyfield
Quote from: magpwr on August 12, 2013, 10:50:13 PM
Hi everyone,
I have just killed 2 birds(2 successful experiment) with one stone(1 hour)late last night.
My initial objective of the experiment on Avramenko Plug experiment v1.0- To prove Tesla theory "1890s" "Single-wire electrical energy transmission based upon the principle of longitudinal electrostatic waves" (It's also known as scalar wave).
This is the part where it gets intertwine with overunity devices where some or many people describe as getting excess energy from external source.
There is indeed truth in it as it pulls electron from air with HV.(All these are not taught in our school books so don't worry)
Refer to my Avramenko Plug ver 1.0 experiment
https://www.youtube.com/watch?list=UUVgRz6F_kUvAO1l0CPIZRAw&v=AZIpIS_R6LI&feature=player_detailpage
After this experiment i decided to use earth to boost power like Kapanadze as an example.
But since i'm living in a high rise apartment.I can only use the earth from electrical plug instead of ground so there is no chance for me to isolate any other possibilities.
It doesn't matter if mains is switch on/off since mains switch is connected to live wire.
The new setup based on v1.0 Avramenko experiment but this time i connected earth wire to negative terminal of battery in disposable camera circuit.
To my amazement the voltage in my flash circuit based on v1.0 boosted to around 500volts instead of v1.0 experiment around 200volts.
This is the real best part(A eye opener) i decided to connect flash capacitor rated 330v only 120uf which was previously desoldered from disposable camera flash circuit.
The capacitor is able to be charged at rapid rate .This is the part which is off interest to many people it doesn't load the camera circuit.In another words there was no noteable increase in current draw from 1xAAA to camera circuit  "while flash capacitor being charged up".
Many people realised using camera with flash would drain the battery quickly due to frequent or rapid charging of capacitors due to constant flashing.We can normally hear a high pitch sound especially while capacitor is being charged up.
But in my experiment this was not the case due to no loading on transformer.(Anyone please feel free to explain)
2nd experiment within same hour this time using the most recent assembled cadecus coil with pickup coil.(As shown in my recent posting yesterday)
I used "Avramenko plug formation" with another 2 HV diodes but this time i am not using any capacitors at all.
I merely connect the output from Averamenko to my cadecus coil.Then i did check on voltage output from secondary pickup coil it was around 80volts A/C.
But take note i get better reading from meter if i don't connect to anything.I used a test pen to check on 3 points from pickup coil.All point neon light not lit.
Now this is the part where it gets very interesting i merely try to connect one end of 10mm white Led to pickup coil with another end merely connect to wire which is not connected to anything.The led light lit brightly.I used my hand the led lit up even more brigthly for 5 seconds(Take note there was no heat felt)then led went dead for good.This part kills few minutes i then realised the led is dead.I used another 10mm white  led same thing happend after couple of second.
This time i used a zener diode it was late i did not have time to check specs connected it in parallel with 3rd white Led this time i have solved the led problem.But if were to touch the end of wire from led which was not connected to anything the led lit to it's maximum and created a usual light spot on celling.
This 2nd part i'm suspecting a "strong radio wave" at this moment for example if you touch a antenna of walktakie using test pen it won't light.But if you use\purchased a mini circuit to capture radio wave like those found in some girls phone where they attached some fancy light to antenna of phone years ago upon using phone it stay lit.
Other details i wouldl like to reveal is from Hv inverter circuit if i connect to small vintage air cap(Which i in this case used as it air gap for low power hv) then other end of cap to Avramendo plug.The led indicator from pick coil stays the same.
This is the 2nd stage of my discovery where the key interesting thing to note there is no noteable increase in current draw from battery to camera circuit while a flash capacitor is being charged.
This is just the tip of the ice berg.
Hi,magpwr
I'm glad to hear that you have success in 2 experiments. now I'd like to replicate that cadecus device.Could you please show us how to tune that device to maximum output?
rgds,steadyfield
magpwr
Quote from: steadyfield on August 13, 2013, 08:25:01 PM
Hi,magpwr
rgds,steadyfield
Hi steadyfield,
You will need to observe carefully what the team on that device was doing to see the scope shot if there is ringing up.They were using a sweep generator.I will not teach on how to use sweep generator as these are actually considered basics how they done it is already revealed in video and i have already posted how they go about it base on my observation.
All the details is already shown in that 3 or 4 videos it was easy for me to understand after looking at video maybe 40 times to the smallest details as i can.
There was no one whom came to me and whispered in my ears or provided any special secret encoded message. :D
The only doubt i had in video is HV diode spec in video but Grumage and a helpful member have mentioned in this forum it's 15KV diode recently.
I have just purchased "sweep generator" as posted recently which will speed up the discovery process. Although i have a basic 5MHZ function generator and 100MHZ scope.
I'm already regretting my old decision to purchase just function generator without sweep function to cut cost.  :'(
Hence at this moment while waiting for "delivery" there is no chance for me to verify anything.This may take 3 weeks to a month.Before i can post anything on my finding if there is "ringing" up for me
the key magic ingredient before proceeding further. :-X
If you have sweep generator you can proceed assemble the caduceus coil with pickup coil by looking at video and take note of minutes which there is useful information for you to resume.
I did not look at time it's definitely below 2 hours for me to assemble coil,solo.But if you have friends to assist in your quest you may want to go for 12AWG winding which should be better.
But if you don't see ringing up which means you would have to start all over again till you succeed.Hopefully we can all see your video with ringing up before i start.hehe.
Good luck winding. ;)
magpwr
Quote from: T-1000 on August 13, 2013, 08:03:00 PM
Hi T-1000,
It does sound little funny since 2011 no one have started working on this device using cadecus and pickup coil with all the useful information in video to achieve OU which i think believed to be ver1.0 of a successful OU experiment.
Although the output power is not as high as Kapanazde i still choose to on work on this OU experiment to understand even more on basis of operation.
I personally believe everything from A to Z would have to start from small or small scale 1st.This can be applied to fruit,animals ,experiment scaling up and etc.
For Kapanadze device where people see better result in 2 KW or 3KW output in demo "but hardly any information was revealed in the video".But people choose to work on this device instead.
Yet how tiny handful of people managed to replicate Kapanadze successfully without all the vital details shown in video still impressed me even more. Considered "A near impossible feat"
I decided start on this experiment to replicate  and get serious  :D only after something was revealed to me via Avermeko plug experiment using tiny HV generator(Small scale).
Else i would have run away very quickly from this topic for good since if my experiment was a failure after carefully planning how to execute in my head.
May i ask there was a green transformer in driver circuit which was mentioned in video as being extracted from a washing machine if i heard corrrectly.
Is it you are using that tiny green transformer as a isolator to power the hv transformer.
I have other plans to connect to hv transformer.
Have you tried using vertical antenna connecting to a unused point from the pickup coil which i'm not sure at this moment if will extract little more power.
