0 Members and 266 Guests are viewing this topic.
bringdownthezog
Quote from: Сергей В. on August 13, 2013, 02:41:30 PM
Привет всем !!
Good news folks.  :D Stepanov OU device is in Germany !! So what can be expected ??
Well very soon OU devices will start show on the day light in Germany and start selling in great ammount to all who need Free Energy for family and home.
The Germany will be the fisrt country which will bring down the JEW.S.A. ZOG !!  :D
After massive population of OU devices first in Germany and than in whole Europe - with JEW.S.A. EMPIRE IS OVER !! The Europe will be Free form ZOG influence.
I hope in Europe will not be in near future some unexpected conditions (HAARP ATTACK, induced earthquakes, massive floods or man-made volcano eruptions like for example uninterrupted HAARP Geo-Meteo tornado attack on South-East China and East Russia).
What will be will be. Stay tunned and check up all sudden weather anomalies - if happend.
About experiments which SteveP did, He told the truth but he couln't say more details because ZOG laws in JEW.S.A. which can bring him for his own truthful words in any ZOG JAIL!!
His OU device is working without nuclear radiation and produce Free Energy. You have all important info on site !!
For all other folks who make experiments with Ferrites, Magnets, Nanoperm stripes - some more info. HV coil need to be axially wounded over sausage - of course on plastic, acryl, carton on any tube form. NF modulation coil need to be radially wounded over sausage. Radially means in 90 degrees apart sausage axis and of course HV coil.
All these coils need to be encapsulated in bigger Aluminium tube. Also you can try like in Bronepozed schematic - small aluminium tube over sausage and NF choke(modulation coil). So main trick here is orthogonal excitation of sausage. In two words on 90 degree.  If you doing the test try it on any small sausage or toroid with orthogonal driving, make coils free movable for tests and slowly rise the excitation power. After you got result, try high power excitation 200-300V  and for any case put a light bulb 100Watts, 220V, 50Hz in series with your power mosfets to save your components.
Lowest power output is about  800Watts RMS power of Free Energy. Upper who knows ?? Maybe MegaWatts or GigaWatts huge power excitation like Tesla did, and big sausage !!
Btw problem with Gravicapa was solved. Antigravity vehicle born in Russia !!
FOREVER MOTIVE ENGINE  MADE IN RUSSIA  !!
http://www.youtube.com/watch?v=6mm0kkTYfus
http://www.youtube.com/watch?v=oOWKjeOgibQ
http://www.youtube.com/watch?v=z5TzKzhzDtg
http://www.youtube.com/watch?v=hRI04OHOVdE
ВЕЧНЫЙ ДВИГАТЕЛЬ ВС МОДЕЛЬ-2013 - We knock on Cosmos Door !! KNock -Knock !!  ;D  ;D
http://www.youtube.com/watch?v=cIpAa7Vn6E8
btw New 2014 year according to ancient Slavonic-Aryans calendar start on Sunny day 22. September. So welcome to FREE ENERGY YEAR 2014 - AND FINAL AWAKEN OF MANKIND !! (I am optimist for our Planet  :D)
Удачи всем !!
Сергей В.
Quotelike Tesla did
http://www.youtube.com/watch?v=soJiZDl4XV4
Удачи всем !!
bringdownthezog
A Free-Energy Device, Fulcrum Dec - 1994
by Paul Raymond Jensen
I have built a transformer which supplies more power to its load than is drawn from its primary source.
I named this device The Unidirectional Transformer (UDT), because the magnetic reaction of the load current does not affect the magnetic action of the primary circuit.
The UDT is composed of a parallel LC resonant primary, a split secondary, a gapped magnetic core, and a "feedback winding." Virtually the only input power needed is that used to magnetize the core.
The magnetic core I used came from a small 60 Hz commercial power transformer made of interleaved silicon steel E and I laminations. I took the core apart, separated the Es and the Is, and made one stacked E core and one stacked I core from the laminations. Then I filed down the center leg of the E core about 15 mils to gap the combined E-I transformer core. The resulting m of the core at 60 Hz was about 100.
The primary winding is wound on the center leg of the core. The two secondary windings are wound on the two outer legs of the core and are series connected. Both secondary windings have the same number of turns. The "feedback winding" is wound over the primary on the center leg and is connected in series with the secondary. The free-energy action of the UDT follows directly from the laws of magnetic circuits.
Consider what happens when an AC sine voltage is applied to the UDT primary. A magnetizing current flows, which can become rather high because of the low m of the core. Fortunately, gapping the core results in a fairly constant m through the entire AC cycle, up to a peak H of about 720 A-T/M. This results in a constant primary inductance, which permits parallel LC resonation. Resonating the primary reduces the magnetizing power to that necessary to match I2* R losses in the primary and the hysteresis losses in the core.
Magnetizing the core results in an AC sine voltage being induced across the secondary. The magnetic coupling between the primary and the secondary is very high, but the core area within each secondary winding is only one-half that of the primary. This means that the volts/turn of the secondary will be only one-half that of the primary. For the secondary voltage to equal the primary voltage, the secondary must have two times the number of turns in the primary.
The primary also induces a voltage across the feedback coil, but the purpose and characteristics of the feedback coil will be explained later.
When a current is drawn from the output, the two secondary windings each generate a magnetomotive force (MMF) directed against the MMF of the primary. The MMF of each secondary winding "sees" a series-parallel magnetic circuit through the transformer core. One magnetic circuit, "seen" by each secondary winding, is through the center leg of the core. The other magnetic circuit "seen" by each secondary winding is through the two outer legs of the core.
The resulting magnetic flux generated by the MMFs of the two secondary windings is dependent upon the reluctances of each of the magnetic circuits. Because the center leg is gapped, it has a higher reluctance than do the outer legs. This means that less magnetic flux from the secondary will pass through the center leg than will pass through the outer legs.
In my transformer, the reluctances of the magnetic circuits through the center leg were three times higher than the reluctances of the magnetic circuits through both outer legs. This was difficult to achieve and required hours of filing, polishing and fitting of the E and I cores. The alternative was to increase the gap, which was not acceptable in my particular design because I was driving the transformer at 60 Hz and could not afford any additional loss of m in the core.
Since the reluctances of the "center leg circuits" were three times higher than the reluctances of the "outer leg circuits," one-quarter of the secondary flux passed through the center leg, while three-quarters of the secondary flux passed through both outer legs.
The magnetic flux from the two secondary windings cancels in the "outer leg circuits," leaving only one-quarter of the total flux generated by the output current to react back upon the primary. This resulted in a current gain in the secondary, relative to the primary. Lenz's law was bypassed, and free-energy resulted.
An alternate explanation for the current gain in the UDT is to consider each secondary winding as acting as the primary winding for the other secondary winding when an output current is drawn because the two secondary windings generate geometrically opposing fields.
Now consider the "feedback winding." It is connected in series with the secondary and is wound over the primary winding on the center leg of the core. When the core is magnetized, an induced voltage will appear across the feedback winding which will subtract from the voltage across the secondary. The purpose of the feedback winding is to cancel the remaining secondary flux passing through the center leg of the core. It effectively isolates the currents in the primary and the secondary at the cost of a reduced output voltage. The feedback winding generates a magnetic flux equal and opposite to the residual magnetic flux from the secondary when an output current is drawn.
Given the above example, where three-quarters of the secondary flux self-cancels in the "outer leg circuits," the feedback coil will only have to oppose one-quarter of the total secondary flux. Since the feedback winding has two times the core area of the secondary windings and carries the full output current, it need have only one-quarter the number of turns of each secondary winding. However, this will reduce the output voltage by 25 percent. Therefore, to achieve the originally desired output voltage, the total number of secondary turns must be increased by the factor 4/3; the feedback coil must then have one-quarter of the number of turns of each secondary winding in this new secondary circuit.
Given the condition in which the feedback coil perfectly cancels all the residual secondary flux through the center leg of the core, the power drawn from the output will be nearly independent of the primary input power. The primary input will be the magnetizing power and nothing more. The output power will have a negligible phase angle (due to the leakage inductance) if the m of the core (as seen by the primary) is at least 100. In practice, it is best if the feedback winding is short a turn or two, thereby preventing series inductance in the output at the cost of a small increase in the primary input power. A parallel resonant primary circuit allows for great input power reduction while ensuring voltage stability and linear operation under varying output loads.
The UDT can be used without a resonant primary circuit for the amplification of any time-varying signal. The main flaws of the UDT are the (normally) low primary m and the very long secondary wire required to ensure isolation of the input from the output. A single or double stack of E-I laminations seems to provide the optimum core geometry, all factors considered. At high frequencies it becomes practical to use ferrite cores with "center leg circuit" reluctances less than their "outer leg circuit" reluctances because the volts/turn of each winding can be made very high. Conventional transformer design techniques should be used once the basic UDT topology has been determined.
I have invented and developed the UDT on my own, without benefit of any knowledge of other free-energy devices, if they exist, which utilize the basic principles of UDT operation.
Please feel free to use this information as you desire. However, I hope that no one will attempt to patent and control this type of transformer. The time on Planet Earth is 15 minutes before midnight; there is no time left to waste.
Free-energy technology is not meant to be controlled by vain and greedy parasites who wish to use a gift from God to exploit their fellow man. Free-energy technology represents a spiritual transition of the human race. Free-energy is not meant to be owned, period!
UDT EQUATIONS
Number of Turns = N
a = V(output)/V(primary)
V(Primary)/N(Primary) = V(feedback)/N(feedback) = V(secondary)/N(secondary)/2
N(feedback) = [N(secondary)/2] [(R of outer circuit)/(R of outer circuit)+(R of center circuit)]
a[N(Primary)] = [N(secondary)/2)-N(feedback)]
R = Reluctance = Y/mA
http://www.zaz.com/usp/fulcrum.v3n2/udt.html
MenofFather
Quote from: bringdownthezog on August 14, 2013, 02:17:36 AM
UDT EQUATIONS
Number of Turns = N
This link open only www.zaz.com
bringdownthezog
zcsaba77
Quote from: T-1000 on August 13, 2013, 08:03:00 PM
Just to clear some missleadings - Antanas was only man with web page. The experiment was done by me and Aidas
Please read my http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg302619/#msg302619 and further old posts.
Also it is interesting to see someone to pick up whole topic and actually try to replicate it only 2 years after it was intentionaly shared for this... ;)
Also please see original fixed circuit from our first document:
Hi T-1000
You are right person (because you are was witness), who can answer for us because we cant decide the real input consumption, in video your friend calc on paper 3,4 Watts, but your ammeter showed 30 Amp on 0,5A switched state, if I good know that is 0,15A on 230 Volts is 34,5Watts, right? or no?
2. question we cant decide the 100Watts bulb was run on full bright, because trough the camera its hard to believe, yes or no? (two same bulb one for FE and second one for the grid, side by side, better for real proof, what you thing about this, my friend?)
best regards zcsaba77
