0 Members and 195 Guests are viewing this topic.
zcsaba77
Quote from: magpwr on August 15, 2013, 10:58:48 PM
....Notice you have already created a measurement circuit to check lumen.
... or just put side by side put another same parameter bulb connected to grid, and check by visualy.
captainkt
@bringdownthezog, I think you just might have something there. Especially as this aqua 2 spark was rubbish and just for show.
Keith
00
Quote from: 00 on August 15, 2013, 05:39:37 PM
Hi Grum!
its both Nmr and tesla !
tesla coil is source of ions! and ground is source of ions! + tachyons!(high impedance coil, use litz wire)
electric current=  copper +electrolyte(ions)+ zinc= amps and volts
ferrite+ions+alluminium= electric current.
caduceus or non inductive or  resisitive bifilar coil as modulator 50/60 hz making alternate ns poles
for nmr  material ---------->copper or alluminium is nmr material. split tube or single cylinder. if using single cylinder use ring magnets facing N-> nmr material<- S. else if split copper is used you dont need magnets then. use then only ferrite rings.
ground replenishes or charge the active material ferrite, copper or alluminium
so its a mix of all.
the minute particles ejected are caught in inductive output coil.
00
Hi Grum!
see more
00
Zeitmaschine
Quote from: Grumage on August 15, 2013, 08:06:18 AM
Just have a GOOD read, I was surprised to see how many builders were active then. Also it was good to see that there were quite a few contributors who are still with the thread today, with us newbies, me included in that statement!!
There are a number of points that may help short cut the present series of tests.
The best shortcut of tests would be not to repeat the same mistakes (thinking inside the box) over and over again. If a test hadn't worked on page 515 then most likely it will not work on page 1515 or on page 2515. 8)
Grumage
To Grumage,
I think i got a another solution which differ from member: 00
Dear magpwr.
Sounds like a good plan. I will try and execute later.
Dear 00.
Thank you for your post. I can now see the different elements in play!!
One further question. Should the internal resonator (Choke) (Drossel) be resonating at the same frequency as that of L3's resonant frequency? At the moment it finds it's own frequency irrespective of that of the drive!!
Cheers Grum.
