0 Members and 78 Guests are viewing this topic.
magpwr
Quote from: Grumage on August 16, 2013, 08:39:30 AM
Dear magpwr.
Sounds like a good plan. I will try and execute later.
Dear 00.
Thank you for your post. I can now see the different elements in play!!
One further question. Should the internal resonator (Choke) (Drossel) be resonating at the same frequency as that of L3's resonant frequency? At the moment it finds it's own frequency irrespective of that of the drive!!
Cheers Grum.
Hi Grumage,
I have just assembled a simple PWM Width Modulator with  Inverted and Non Inverted output using one I/C:SG3525A 16pin .
This is base on link which i have posted 1 or 2 days back .This is definitely a better I/C than 555(single output) to be used as flyback driver and if you check spec it's 400mA sink.This will be connected to my 600Volt mosfet.I've check via scope it's able to produce nice pulse width from around 6%  to 50% frequency maximum support is 400KHZ.I have use 15nf cap to get 4khz to 22khz which is suitable for flyback transformer.
In Royer oscillator as driver for HV transformer i believe there is a small limitation that pulse width can't be tweaked easily for a simple circuit.This will result in higher current consumption.
00
Quote from: Grumage on August 16, 2013, 08:57:38 AM
Dear 00.
Now I AM confused.  L2 and L3 are on the Yoke or in my case Ferite transformer core. Do you mean L5 and the internal choke?  :)
Cheers Grum.
Hi Grum!
see image
00
Grumage
T-1000
Quote from: zcsaba77 on August 16, 2013, 02:43:35 AM
Hi T-1000
What was wrong with device? It was just 50% more consumption!
regards zcsaba77
The output was enough to light up 100W bulb but wasn't for 150W one. We used capacitors and discharges so this defines power factor for each pulse.
x_name41
Quote from: Zeitmaschine on August 16, 2013, 08:50:25 AM
Maybe this question sounds so simple as it sounds odd, but: If a (relatively) thin wire is wound around a (relatively) thick wire (in a manner as depicted in the image below) and the thin wire is connected to earth and the thick wire carries a lot of amperes then could it perhaps be that a novel technical effect accrues? Thus this strange ribbon symbol?
Quote:
»[...] one single conductive element forming a closed circuit with itself (4), that is connected by induction to at least one connecting conductive element (5), which is connected to a grounding mesh, said connections causing, as a novel technical effect, the appearance of an electrical current that circulates within the conductive element forming a closed circuit with itself [...]«
»The device object of the present invention operates as follows: the electromagnetic field generating device to be powered by a power source, produces an electromagnetic field that induces an electric current in the conductive circuit closed in on itself, creating an interaction one between the magnetic poles of the equipment and the magnetic poles of the earth, going to be - through electromagnetic attraction and repulsion - An endless supply of electrons from the earth to the conductive closed loop itself, which is connected to a grounding grid through the conductive interconnect.«
End quote.
The green colored part is a clearly understandable statement, it is a transformer with a shorted two windings secondary, the red colored part is still a red question mark.
So why does this »connecting conductive element« reminds me on the Hall effect and on the homopolar generator? Because these devices are also working on odd (and once novel) technical effects? Or is it because a homopolar generator generates a lot of amps but very little volts as with the conductive element forming a closed circuit? Or is it because the Hall effect works due to a magnetic field perpendicular to the current?
And why at all does Barbosa need this heavy black coated wire (two fingers thick, suitable for thousands of amps) when the thin green wire is obviously sufficient for connecting the device to the ground during the demonstration?
Someone has by chance a very thick wire at hand in order to do little experiments (outside the box)? :D
After all, I'm not sure anymore if high voltage is needed anyway. Because (already mentioned hundreds of pages ago) at 20:20 clearly TK's spark gap fails, most likely meaning the high voltage generator fails too (not oscillating), but the lamps are brightly lit nevertheless. Hence, no spark gap needed, no helical coil needed, no big coil needed, no transformer, diode bridge, filter capacitor needed, no transistors on heat sinks needed. This all is just mumbo-jumbo to fake people out. Thus it seems to me there is not much left of the TK device except a small room in the tin can just big enough for a novel »outside the box« effect.
yes, this brasilian device works on the same principle as the Kapanadze devices, Tariel also demonstrates the homopolar generator in the other videos
http://mazeto.net/index.php/topic,8582.msg54385.html#msg54385
http://realstrannik.ru/forum/39-kapanadze/108060-generatory-kapanadze-obshhaya-tema.html?start=6030#146725
