0 Members and 309 Guests are viewing this topic.
Zeitmaschine
Quote from: jbignes5 on June 24, 2012, 07:48:48 PM
Also I am gonna be starting a replication of kapanadze system from 2004. The exact replication. I think his system just utilizes ground loops which have been a bane to most electrical systems. I know I had tons of troubles eliminating them from house wiring and devices that do not isolate the ground from the working unit. Computers are very susceptible to these loops. In fact one loop was soo bad the electric companies ground connection was cherry red. By the way the ground wire was 3 inches thick and glowing red but not one effect could be seen but for the interference to the computers. Once the ground loop was figured out all the computer systems worked flawlessly.
Ground loops can be very powerful with very heavy current flows. Of course with those flows a huge magnetic component was associated with it. This tended to pick up and amplify any signal and inject it into the AC system. You would think the power company would have known about it but they even were scratching their heads. They tried everything and it only took me about 2 hours to figure that out and fix it. They had to buy a new air conditioner but it was worth it in the long run. Something was wring in it and even when they took it to be examined by a qualified repair man he gave it a clean bill of heath. Yet when put back into the system in the exact spot as before it happened again.
Think about the amount of current flowing in that loop to turn a 3 inch ground cable cherry red. I didn't have anything to measure the current but the power company said that it was impossible to do what it was doing, yet it was happening.
Now thinking about the ground loop and the current it was carrying if you put a coil around that what kind of current do you think you would induce off of that? Maybe thats all Kapanadze is doing? Creating a ground loop by exciting the separate ground connections through the coils then sucking off that loop. This is what I'll be testing because it is better then energy from no where.
A three inch ground cable cherry red? Interesting! Barbosa measured the temperature of his loop cable too. Maybe he was afraid it could melt. ;D
jbignes5, any success so far with testing? :)
x_name41
Nilson Barbosa and Cleriston Leal device works on the principle of potential difference, in such a system is required AC or positive charge relative to the ground because ground has zero charge!, high current is already pre-created :)
00
Quote from: Zeitmaschine on August 16, 2013, 02:00:24 PM
Hello! Zeitmaschine !
barbosa works!
you can test it straight away with a ferrite rod with 50 turns magnet wire connected to 1.5 v ac and another winding of 10 turns thick any wire say 1 mm  multi stranded connected as closed loop with earth ground. it lights up 3 v led. without earth or hand touch led is not lit. since its just ferrite rod the led is not bright as it should be. using transformer the results are much better.
00
Zeitmaschine
Just my two cents about the principle of work of the Nilson Barbosa, Cleriston Leal, Tariel Kapanadze and Arkady Stepanov devices:
The primary coil of a 50Hz transformer is connected to the grid. The secondary coil consists of only two windings made of thick (stout) wire and is short-circuited. Therefore, a high current circulates in this coil generating a very strong magnetic field even in a short segment of that wire. If a thinner wire connected to earth is wound around this thick wire the electrons in the earth wire are attracted or repelled by this strong magnetic field. Since the two wires are connected galvanically (direct metallic connection) the electrons can flow from the earth wire into the wire of the short-circuited coil. More moving electrons in a circuit means more current. But in this case the current originates from the ground not from the primary coil. Thus the linkage of the device to the ground is of the type galvanic and electromagnetic at once.
Now someone please tell me that the Kapanadze mystery is finally solved. :) :(
But at least this principle would comply with the construction of a 3-phase device so simple you'll laugh.
BTW: Any idea what Tesla patent this could be?
Grumage
Quote from: Zeitmaschine on August 16, 2013, 05:35:34 PM
Dear Zeitmaschine.
You may well have the answer!! A shorted turn on a transformer would make quite a noise! Possible reason for the noises heard in some of TK's videos??
Presumably as the current grows via your galvanic connection the primary load would decrease? I am assuming that a transformer secondary would then be employed to power the load?
In box, or out of box? :)
Cheers Grum.
