0 Members and 89 Guests are viewing this topic.
stivep
another replicator only his mechanics is  much better
Wesley
sparks
Quote from: magpwr on August 20, 2013, 12:10:52 AM
Hi Bringdownthezog,
Tips for sourcing parts-
I have problem sourcing component locally eg:HV tranformer over here it's getting extremely hard to find,HV components especially anything above 3KV capacitor or even diodes.
None of the electronics components store (More than 20 store)in a building that sell really high HV component as an example.These i get it from ebay.To cut cost especially on shipment try to look for those that mentioned free delivery worldwide.
The parts do take anywhere from 1.5week to 3 weeks to arrived for my case in Asia:Singapore.
You will be surprise to know some parts are cheaper are actually in ebay with free shipment if you don't mind waiting time.It all boils down to the overall cost for a experiment or etc which is considered acceptable. ;)
   You can cannibalize capacitor discharge ignition systems from salvage yards.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
magpwr
Quote from: Сергей В. on August 19, 2013, 08:04:08 PM
Привет Bringdownthezog !!  :D
Thank you i appreciate your help to all people at "prison planet". I was reading hyiq.org site long time ago, also have readed newest update by Chris Sykes. He has very brigh mind !! If comebody know him will be good to ask him join this forum.
Bringdownthezog watch this - the same effect work in this device.
Bronepozed gave it on Realstrannik.forum
http://realstrannik.ru/forum/39-kapanadze/108060-generatory-kapanadze-obshhaya-tema.html?start=6192#147520
Magnetic-resonance source of power - video -
SELF RESONANCE TRANSFORMER IN ACTION  :D
http://www.youtube.com/watch?v=17QMaJ8GRm0
КПД выше 100% - COP > 100%.
Use E-E transformer lamels with small Neodium boron magnet in Air-Gap between both sides as on schematc.
kt805 datasheet
http://www.5v.ru/ds/trnz/kt805
Coils:
L1 - Red wire - L1 Coil
L2  -Green Wire L2 Coil
L3-L4- Black wire Output Coils - must be identical - same mass, same number of turns, diameter, isolation etc.
Winding ration 1:3 ; L1-8 turns; L2 24 turns; - both coils have same diameter. L1 wounded over L2. Output coils L3-L4 same diameter min 1.5 mm. Tuning L1 in resonance with L2.  That's all.
Last file is small PCB !!
A NEW ENERGY PHYSICS: MAKING THE IMPOSSIBLE(for official ignorant science)  POSSIBLE  -  Sweet called this effect, "Self-oscillation electric transformers" shortly OverUnity Transformer. So we know this working because so many people  had replicated it.
http://merlib.org/node/5282
SQM transformer - Bucking Magnetic Field Oscillation, or A Vector Potential Oscillation Transformer.
http://www.hyiq.org/Library/18-07-11.htm
ps: Seems nobody is interesting in replication !!
Да вы правы, как всегда мало, но у меня нет проблем!!  БУДДА. -  Yes you have right, as always a little, but i have no problems !! Buddha  :D
To Сергей В.
I have this old feeling that it's similar to MEG device ver 1.0 which i have seen couple of years ago.Yes there is overunity but with magnet in center.
Later on for version 1.5 or 2.0 the inventor for MEG used "Metglas core"(Amporphous Alloy) instead of existing ferrite which increase the COP even higher than version 1.0.
After which in version 3.0 there is also another 2 coils added on bottom horizontal part of Metglas core.There was a animation of how the switching(effecting the magnetic flux within core) suppose to be done a long time ago.
In fact this was the 1st OU experiment i wanted to try nearly 10 years ago.Since i had problem obtaining the more exotic core back then.I did not continue.It should be more easy now.
I'm not sure how many have seen this MEG experiment.It used to be in JLN Lab site.
Hoppy
Quote from: Gidfactor on August 19, 2013, 10:52:35 PM
Hoppy and zeit
http://www.youtube.com/watch?v=VAK0UgTr2CE&feature=related
Can this be verified.
Very interesting I thought no one got it to work... Hmmmm
Looks very simple it will make you laugh..
Cheers...
Yeh, but I went to sleep half way through that one  :(
magpwr
Hi T-1000 and Wesley,
This for Wesley since i had Barinum titanite which i puchased 2 years ago from ebay.
I proceed to conduct the experiment as shown in the rexresearch as shown below but without the Barium ferrite magnet.To prove if their OU experiment is valid.There is OU indeed the signal is amplified only at the resonance frequency or it's harmonics.Not only it's voltage is amplified it's current as well.But it's below ~0.5mA shorted output from another bilfilar winding for less than 1uA input.I able to light led from with less than ~1uA at input bifilar winding .
If i bypassed the barium titanite the current input to coil bilfilar input is 40mA and the Led was not lit from bilfilar output winding.
This is how i setup my experiment merely using existing 40 turns of bilfilar 18AWG on 3" toroid this is borrowed from my HHO experiment.
The inductance reading for bilfilar is 24.88mH for both winding.I did not follow 150 turns as describe in site.
As describe in rexresearch to use sine wave to use is from 20KHZ ...40KHZ.
Since i had 5 pieces of Barium titnate as attached.I proceed to use croc lead one beneath the Barium chunk and one lead over the chunk and this lead to Bifilar input.
I started with multimeter A/C setting i observed if input voltage is 0.5V A/C the output from another bilfilar winding (isolated from frequency generator)is 3.7Volts A/C for one particular sample.
If you take a look at the photo i noticed a particular chunk is different  colour from the rest as delivered to me 2 years back.The piece which at the bottom of the photo was able to resonate at 16.8KHZ for my case and gave the highest output(similar colour to white clay).The rest is between 20KHZ to 35khz(dark grey samples) .By the way i get higher reading in multimeter in 1 decimal place if i use square wave instead of sine wave.
The scope showed a amplified waveform at the output if i connect lead via Barinum but if i merely connect directly to bifilar the amplitude is the same with usual phase shift if compared with input.
Maybe with Barium magnet in hand  maybe i can program my <20mA microprocessor to output at 16.8KHZ sq wave to resonate the Barium titnate to create a loop back to allow it to self run.
For everyone else-
This experiment is a big eye opener for me.It's hard for me to prove unless 1 or more people carried out this easy experiment.There is ou in miliwatt level enough to light led from below 1uA input
But the most important requirement is a frequency generator beside multimeter and optional scope which allow you see the amplified waveform to your heart content.
To T-1000 can you recall the previous discussion we recently had in this forum about Resonance Amplifer which is proven around 6watt of overunity using a basic setup using Barium-Ferrite Magnet base on one of the site i have provided link.http://www.rexresearch.com/mra/1mra.htm#intro
I have finally found a link on where to purchase this magnet from quantity as low as 1, 200 or 1000 or 2000 depend on company.All the magnet Companies in one site is listed below.
I merely know in business sense China is the world's Main producer for neodymium magnet ,Lithium and etc.
Some companies accept wider range of payment terms :T/T, D/P, Paypal, Western Union
You might laugh if i told you the cost of magnet is $0.01 ..$0.5 ea
http://www.made-in-china.com/products-search/hot-china-products/Barium_Magnet.html
