0 Members and 108 Guests are viewing this topic.
a.king21
Quote from: Hoppy on August 21, 2013, 12:35:51 PM
The attached may be relevant. Note that the effects described are damaging to a transformer and this maybe why TK never runs his 'noisy' devices for long periods of time. I have highlighted the effects that are of interest.
Hoppy: Excellent document!!!!!
We need more transformer anomalies.
ariovaldo
Quote from: aaron5120 on August 21, 2013, 12:20:53 AM
Hi ariovaldo, I saw your YT clips. That configuration seems to be an attempted replication of the Barbosa & Leal patent, isn't it?
Now, did you put a ground loop around the thick wire of the first MOT and the second MOT?
Your mesurements are incomplete as they only tell us the voltage of the secondary of the second MOT and the amperage of the primary of the first MOT. It would be much better if you can put four meters into the settup and measure input voltage and current of the first MOT and output voltage and current of the second MOT.
Yet we have not deal with the phase issue yet of the output since it is an AC circuit. But doing the above mentioned suggestion is already an advance for a better understanding of your idea.
aaron5120
My intentions was just understand the effects of Barbosa patent.
When I started the test was just for fun and see how the coupling between the 2 transforms works. When I was doing that, I put one transformer in the top of the other and is visible that doing than, in the right position, the current drops in the primary and the voltage has a slight raise in the secondary. Anyway, just giving my 2 cents.
ariovaldo
That is good documentation.
Thank you....
Grumage
Good evening to all.
Yesterday evening (UK time) Sergey posted an interesting link, since removed...............https://www.youtube.com/watch?v=4YNifHA1CoI
Now the video is a little long and repetitious however the "Grit", magnetic vortex spin, I found very interesting. I think Acca picked it up too.
I have just come back from a play in the backroom. In a medium wine glass I had filled with a mild salt solution I placed a Neo disc magnet wrapped with a conductive wire connected to the positive. I then just dangled a negative wire into the solution. Presto a whirlpool in a glass!! This soon turned to a black mess and rather a lot of Hydrogen and Chlorine!! But the spin was really there. (DC 25 Volts)
So I next tried to see if this spin could be seen on a scope, by placing the same magnet under a centralised toroidal core with about 50 turns of wire. This time dissapointment, not a trace on the scope. Now if this spin can be induced in water why does it not cut the wire and induce an emf in the coil? Any ideas?
After watching or skipping through that video just follow a couple of shorts presented by magnet flipper. There is a neat little motor demo.
Cheers Grum.
Cap-Z-ro
Perhaps if you wrapped a coil around the glass whi8le the vortex is active it might register on the scope.
Regards...
