0 Members and 319 Guests are viewing this topic.
NickZ
  Oh, there was more than just one individual singled out. Just because he mentioned something that didn't fit into what was being discussed at the moment by a few.
  Maybe we should take a vote, isn't that the democratic way. Ha!
Are ones that were previously given the boot, able to vote? Yes, NO??? Ask your moderator?
a.king21
Latest Barbosa- Leal video today.
http://www.youtube.com/watch?v=Gb_xrj2y7Vg
Published on 23 Aug 2013
Power: 39.6 kW 220V
Generation capacity Month: 28,728 kWh
Equipment installed: Industrial application
Grumage
Dear Hoppy.
You are making great progress!! I have been thinking a bit laterally, perhaps a bad move!! :)
Series resonance has the effect of greatly increasing current at the correct frequency this may also help reduce the input current. See atached your amended schematic.
As I am sure you are very aware, most of the devices we have been working with all seem to employ series resonance. It is, but a thought and as you said earlier we need to walk before we start running!!
Cheers Grum.
Hoppy
Quote from: Grumage on August 23, 2013, 01:45:55 PM
Dear Hoppy.
Cheers Grum.
I need a new AC/DC clamp meter which should be delivered to me next Tuesday. I can then get some meaningful data on my present setup. A series resonant circuit passes maximum current at resonance but no more current than is available through a direct metallic connection. We need to always bear in mind that the electrical efficiency of a device is determined by input to output energy levels, so current is just one of the variables that need to be considered and measured to ascertain system efficiency.
Like you, I am trying to think laterally and I have never got the impression that TK makes much use of measuring instruments, so to my mind his prime objective is probably to light as many bulbs as brightly as possible with the energy he has available from his remotely sited source supply. A safe energy transmission medium is important which is why I think he uses a low voltage, high current power system. I also think it feasible that he has had success in using the ground as wholly or partly one leg to his supply loop but I have not experimented in this respect, so again, this is just conjecture. I say this simply because I don't believe that the earth connections were intended for free energy extraction from the ground  ::) Although I have always been of the opinion that his devices operate in accordance with conventional electrical principles and to be fair to TK, its quite possible that he has observed an anomally that he sincerely believes is as result of energy extracted free from the environment.
