0 Members and 56 Guests are viewing this topic.
Zeitmaschine
Quote from: Hoppy on August 23, 2013, 10:28:45 AM
All these things can be experimented with. Start with simple practical setups :)
Or go on with theoretical drawings and considerations. :D
When does the magnetic saturation of the core of a (transformer) coil occur? It occurs as soon as there is a high current going through the coil creating a magnetic field above the saturation point of the core.
What effect has the magnetic saturation of the core of a (transformer) coil? The magnetic saturation of the core lowers the inductance of that coil.
What effect has a lower inductance of a coil when connected to a capacitor forming a LC circuit? The lower inductance rises the resonance frequency of that LC circuit.
When does the current in an inductive circuit reach its maximum value? It reaches its maximum value when the voltage in that circuit crosses the zero line. Phase Relationships in AC Circuits
How often does a sinusoidal voltage cross the zero line? It crosses the zero line twice each cycle.
Under what conditions does parametric resonance take place? Parametric resonance takes place when the external excitation frequency equals to twice the natural frequency of the system. Wikipedia
What is the natural frequency of a transformer connected to a 50Hz grid? It's 50Hz.
Conclusion: There is no need for switching elements (like thyristors) in order to excite parametric resonance as shown in this patent (never got it to work). One and the same coil can have a different inductance depending on the saturation level of its core.
So what about some practical experiments based on these stunning news?
forest
Zeitmaschine
can you find another  reason  maybe ?  :o  the problem with theories is that : you can always find a theory explaining a working device but you mostly can't find the working theory explaining device you plan to build...... think about it...twice  ;D ;D
Hoppy
Quote from: Zeitmaschine on August 23, 2013, 04:00:07 PM
I look forward to seeing your first experimental schematic and subsequent report.
Zeitmaschine
The trick is to eliminate all stuff not really necessary to a point till almost nothing is left. Then build something with this »almost nothing«. If one needs more than two transformers and a capacitor then the design of the circuit is wrong. And I hope it stays this way. Could be it turns out that one transformer is also enough.
