0 Members and 510 Guests are viewing this topic.
hartiberlin
Hi romerouk,
instead of using bulbs as the load you could also use an old toaster
or a big 1 to 5 Ohm resistor or something like this.
Did you wind the 22 turn coil OVER the 84 turn coil
or did you wind it besides it ?
Is there any ferrite cores inside your coils ?
Many thanks.
romerouk
@hartiberlin
No ferrite cores inside.
The 22 turn coil is on top of the 84 turn coil.It makes a difference having this coil connected.I have tried with a 1kw heater and worked better but if I leave it on for too long I am sure it will blow it too.The wire in the heater normaly is not as bright as when connected in the circuit here.I will get some 500w bulbs too.I was talking about DC as the source to the system, diode and a capacitor connected to the MT output. I am not sure but I think it is arround 2kv.
I am scared to connect any scope probes as I am not sure what I am dealing with right now.
Quote from: romerouk on June 09, 2010, 06:37:21 PM
@hartiberlin
I recommend you connect the probe through a high resistor first to have a peak at the values you are dealing with. Also can you make a circuit drawing please.
hartiberlin
Hi romerouk ,
many thanks for confirming that you have no ferrite in there.
So maybe you can check with the heater, if it would give more
heat, when you would use more windings through the center as
I have just posted the drawing ?
Maybe you can just use a small pickup coil for your scope, so you don´t need to
directly connect your scope.
Are these big currents radio frequency burst, so are they in the Mhz range
or are they lower in frequency ?
Did you calculate  the turns of the 22 turn coil or
why did you choose 22 turns ?
Did you also try other winding numbers ?
Did you also try to wind it CW instead of CCW for this 22 turn winding ?
baroutologos
Romerouk
Here is my replication for Kapanadze-Kapagen style. No measurements yet as it is impossible to use digital equipment.
http://www.youtube.com/watch?v=a675_0onwjg
Interesting at least!
I saw the video and the diagram. You also said they are in line with Dragon's setup.
Can someone make a nice diagram of the coil? I have some difficulty in understanding it.
A Question: (if i may)
You use pure High voltage without any capacitors do you? (directly from MOT)
ps: think a party is brewing
