0 Members and 123 Guests are viewing this topic.
cheappower2012
Zeitmaschine
This inverter has this option of applying some grids main power
when the plug is connected to grid power never seen that before.It looks to me that this inverter is an older
switching type,I have a transformer type 350 watt inverter its big,this is small,compared to it.
The buzzing noise indicates a loaded transformer,the ac power applied to the device,by plugging the inverter
is much less than 100 watts,the device loads the inverter up,hence a buzzing.You are not getting full grid
power thru this option.
The battery when hooked up must supply a little ac power which adds to the
output of the transformer so no buzz,this must be due to how the switching is done.
The ac grid and the inverter must be synchronized to prevent a short.
When there is no battery then the grid power being limited can not supply enough to
start the device without buzzing.There must be a small isolation transformer in the inverter.
I live in the US,I have never seen this kind of grid power option on any inverter here
it must serve a function.You live in that part of the world where its 220 ac.
To figure this exactly your going to have to find the exact model used and get the operators
manual or the schematic.However this has no bearing on the operation of Tariels device
in my opinion.Check on this lets say that the first device Tariel made is a kind of buzzer,electromechanical,
not per say a transformer,but made from a transformer.The transparent box video used one it buzzed at
around 400 HZ,lets say he put that in a can,with damping material,to silence it,the 2004 video,the green box video use that.
He figured out how to do the same without an electromechanical device so the 2007 video is solid state,"transformer"
The turkey device's also transformers,leading to the aquarium 2 video also a transformer.
You have a sealed box,with no clues very hard to figure out,there could be
unlimited possibilities the inventor is very clever and doesn't want you to know hes secrets.
sadang
Slavic Aryan Vedas
Book 1, Santies Perun Vedas
Santie 7, verse 109,
The all-destructive Fire of Retribution of Forces of Light,
will burn minions of The World of Darkness
and all descendants of Alien enemies,
which were filling the whole Human World
with spiritual emptiness...
Carrying on their banners:
lie and vices,laziness and cruelty,
desire for another's and lust,
fear and lack of self-confidence...
And it will be a Great End of World,
for Alien enemies, who came from The Dark World...
And will come the End of Time of Darkness,
for all Kins of The Great Race and Descendants of The Heavenly Kin...
But Sergei, these Vedas don't give any rights to consider yourself to have any advantage over any other people from Earth! This way of thinking is not at all different from the Jews one! And also Perun is not at all different from the biblical God!
On the other hand I see this topic passed the first quarter of 2000 posts and everyone beat around the bush. Nobody wants to see that there is no solutions, and nobody wants to notice the talks are resumed again and again, without bringing anything new! Nobody wants to leave the wrong paradigm of electromagnetism in particular, and of actual science in general! See you after the 1500 post!
Hoppy
Quote from: cheappower2012 on August 24, 2013, 05:34:32 PM
Zeitmaschine
You may have answered the puzzle I had - why connect the grid to an inverter if the supply battery is flat.
I have attached a schematic of how I see the tin can device interconnected. I noticed for the first time when looking at the video clips Zeitmaschine posted earlier, that when the inverter is unplugged at the end of the demo, there is a short delay before the lights switch-off. This leads me to think that the lights are relay switched and this relay is held operated for a short period by a discharging capacitor labelled C1 on the schematic. The other oddity, is that TK's assistant can be seen (at 24:32) throwing the switch on the tin can several times before the lights will stay on. This suggests to me that the relay could be a latching type and is failing to latch in cleanly on occasion. The probable reason for a latching relay is that a permanent grid supply is being switched by the relay from the rectified AC output from the inverter. When the inverter is started from a grid connection, the second relay contact (top contact on schematic) which switches the permanent grid supply to the lamps, also feeds a permanent supply to the inverter, so that the starting grid connection or battery can be disconnected, to give the impression that the device is now looping back and self-running.
The box under the worktop is I think a battery charger and the permanent grid feed is taken in to this box and then cabled off to the lamp unit on the twin cable that can be clearly seen in the video.
Zeitmaschine
Quote from: Hoppy on August 24, 2013, 06:39:37 PM
That's the strange idea on this subject. I see. ::)
Compared with this, parametric resonance seems to be rather easy. Since I have never achieved parametric resonance yet, I have no reason to believe it cannot work. Can it work or not? So far I have never seen any proof of the latter.
Besides: How does this schematic work without the connected battery charger (prior to 19:00)? When the black box under the table is not connected then it does not matter whether there is a (hidden) grid feed leading into this box or not.
T-1000
Quote from: MenofFather on August 24, 2013, 05:04:06 PM
I in other schematic remove words akula0083, that people not post this schematic on other forums, but now think maybe better post image with not remowed words. And other image were writen in same srift Akula0083, so it probarly this two schematics is from Akula0083.
If you are experimenter, here is one thing to see for yourself:
Assemble ferrite tube from ferrite rings,wind transformer primary and secondary coils. Make variable frequency and duty cycle driver of your choice for it.
Also make high voltage flyback driver and get flyback transformer of your choice without diodes.
When you get that done, you will need some coax cable and metallic tube for antenna. This will complete HV/HF capacitor discharge circuit. You will need to make very small distance on spark gap to make discharges happen stable as possible.
When you have everything assembled, attach some bulb as load to the secondary coil. As soon as you turn on transformer driver it will consume lots of amps as expected.
Now the interesting part: power on flyback circuit and put metallic antenna tube inside of ferrite rings tube. See how amperage consumption of main transformer changes. You may manage to get it from several amps to milliamps. The bulb will show you much higher output than you have directly from its driving circuit.
So this is what I see in this circuit you just posted.
Also please see some screenshots from old  Russian experimenter YT videos (can't find them anymore there) named as Катушка_1_mp4 and Катушка_2_mp4 This experiment was done few years ago and slipped from most peoples eyes due Russian language and not understanding of importance in effect.
P.S> Just managed to find copy of Катушка_1_mp4 and Катушка_2_mp4 video in http://topdownloads.ru/watch/qmirRN3O6Ko.htm http://topdownloads.ru/watch/FNuoyPr4_NA.htm and second experiment part in http://www.youtube.com/watch?v=2xWZe6j5cPE and http://www.youtube.com/watch?v=R7bmwpyNkok
