0 Members and 130 Guests are viewing this topic.
NickZ
    MenofFather, & T-1000:
  Can someone please check with Akula to see if these new akula 0083 circuits diagrams are really from Akula himself, and that the circuits are correct, and that they WORK, as shown.  And, that it's ok with him to show them on the forums, and Internet. Please.
  Or we are chasing the wild goose, as always... as so far, not one of the previous schematics, diagrams, or replications are known or proven to work.
        NickZ
Hoppy
Quote from: Zeitmaschine on August 24, 2013, 07:45:29 PM
That's the strange idea on this subject. I see. ::)
Compared with this, parametric resonance seems to be rather easy. Since I have never achieved parametric resonance yet, I have no reason to believe it cannot work. Can it work or not? So far I have never seen any proof of the latter.
Besides: How does this schematic work without the connected battery charger (prior to 19:00)? When the black box under the table is not connected then it does not matter whether there is a (hidden) grid feed leading into this box or not.
This is not a full circuit diagram, as there may be other components associated with T2, which cause parametric resonance in the trafo, like a suitable cap across the primary winding  ;) The inverter cannot be supplying the lamp load as the lamps stay illuminated for a short period after the inverter is disconnected.
Prior to 19:00, the battery is connected to the inverter to start the device. Only the battery charger clip leads are disconnected from the battery. The grid connection powers the charger and provides a permanent feed to the lamps. The most important point that needs to understood, is that a permanent grid feed is needed for these types of Kapanadze devices to function. The operation of the device is cleverly designed to appear like a self-running setup, complete with the eye-candy spark gap and Tesla coil.
Hoppy
Quote from: NickZ on August 25, 2013, 01:27:05 AM
        NickZ
Wishful thinking here Nick! I would have thought that if he was prepared to do that and given all the debate over the authenticity of the various schematics posted from the outset, he would have cleared this matter up a long time ago.
MenofFather
        NickZ
I can not conect with akula (I try add he to my skype contacts, but he not add me and nothing to me write). And men who send me this schematic, say, that with him hard speak. Akula send to this men schematic, like this man say. "I'm not ask schematic, but Akula send" - that he say to me over skype.
MenofFather
Quote from: T-1000 on August 24, 2013, 11:18:00 PM
If you are experimenter, here is one thing to see for yourself:
Assemble ferrite tube from ferrite rings,wind transformer primary and secondary coils. Make variable frequency and duty cycle driver of your choice for it.
Also make high voltage flyback driver and get flyback transformer of your choice without diodes.
When you get that done, you will need some coax cable and metallic tube for antenna. This will complete HV/HF capacitor discharge circuit. You will need to make very small distance on spark gap to make discharges happen stable as possible.
When you have everything assembled, attach some bulb as load to the secondary coil. As soon as you turn on transformer driver it will consume lots of amps as expected.
Now the interesting part: power on flyback circuit and put metallic antenna tube inside of ferrite rings tube. See how amperage consumption of main transformer changes. You may manage to get it from several amps to milliamps. The bulb will show you much higher output than you have directly from its driving circuit.
So this is what I see in this circuit you just posted.
Also please see some screenshots from old  Russian experimenter YT videos (can't find them anymore there) named as Катушка_1_mp4 and Катушка_2_mp4 This experiment was done few years ago and slipped from most peoples eyes due Russian language and not understanding of importance in effect.
P.S> Just managed to find copy of Катушка_1_mp4 and Катушка_2_mp4 video in http://topdownloads.ru/watch/qmirRN3O6Ko.htm http://topdownloads.ru/watch/FNuoyPr4_NA.htm and second experiment part in http://www.youtube.com/watch?v=2xWZe6j5cPE and http://www.youtube.com/watch?v=R7bmwpyNkok
Aš pabandžiau, tik ne TVS naudojau, kaip rusai vadina, o TDKS, jokio rezultato nedaro žieižirbavimas. Ir feritiniai žiedai tik 8 apie turėjau, ne per visą ilgį buvo. [size=78%]https://archive.org/details/Capture_201308[/size] Todėl pas jį gali būti įaka generatoriui nuo žiežirbavimo, mano tranzistorius turi gerą apsaugą nuo triukšmo, todėl galbut aš ir negavau tokio efekto, kaip manai?
Nors aš tik dabar pastebėjau, taisau žinutę, kad ten į vidų ferito reikia įkišti aliumininį vamzdį, o ne feritus į vamzdį. Bet vis tiek aš neturių tiek daug feritinių žiedų ir tie, kuriuos turiu pakankamai mažo diametro ir vis tiek galbūt ten įtaka žiežirbavimo (iskrenija) tranzistoriui.
