0 Members and 71 Guests are viewing this topic.
Zeitmaschine
Quote from: NickZ on August 25, 2013, 01:27:05 AM
Or we are chasing the wild goose, as always... as so far, not one of the previous schematics, diagrams, or replications are known or proven to work.
Why should we need all this stuff anyway when Stepanov gets free energy out of two transformers and a capacitor (all 3-phase)?
Quote from: Hoppy on August 25, 2013, 03:50:47 AM
The most important point that needs to understood, is that a permanent grid feed is needed for these types of Kapanadze devices to function.
You could prove your (most important) point by building such a device with permanent grid feed and then presenting it to some smart observers as the real free energy thing. :D
baroutologos
Quote from: T-1000 on August 24, 2013, 11:18:00 PM
I will back you up on ak.png...
I remember back then, when assembling those setups, most experimenters were experiencing a case where considerable 12v input current was feeding the improvised inverter to barely light the bulb and when a HV HF spark gap was applied to antenna style to ferrite tube, then more current inrushed to inverter (transformer primary) and then bulb was more or less lit as per video. Again there were cases that current was dropping (and bulb shinning) as the video shows..but
There were not a single case that anyone could light a bulb (220v 45-60w) to such brightness (1/10 lit lets say) with miliamp power and 12 volt input.
What i remember was the case is that the draft inverter driving ferrite tube primary was made of a pair of NPN - PNP transistors composing a half bridge inverter or not driven by a 555 or similar timer circuit at 50 Hz or so.
Ferrite open magnetic flux transformer in such low frequency was operating at huge losses typically transfering a minute of input power to load (bulb) assuming properly matched.
When a HV HF spark gap signal was applied then the 555 timer was overclocked and the inverter's frequency was hasten by some orders of magnitude.
Overally efficiency would go up and losses would go down. Free energy? Not in this case.
@T1000
Is there a video of 12v miliamp input and a bright 220v 45-60-75-100 w bulb output? If so the trustworthiness of the creator is undisputed? Any more indepedent replications on that?
Too many to ask? :P
MenofFather
Quote from: Zeitmaschine on August 25, 2013, 08:05:25 AM
But I try replicate Stepanov divice and wery dificult. I try replcate with gap, resonant transformer. Using high frenquency maybe get eficient about 101-200 watts. But maybe get 92 eficienty, it hard say, because ampermeter is for 30 amps and hard determinate current. With 50 herc frnquency, need wery much many on wire and core if make big. Only maybe if make divice who using curent transformers, but also need curent transformers about 2 amps or lees, that not sell, so it not that simple like look in fist view. And it efiicienty seems about 300 precents, quite small.
magpwr
Quote from: MenofFather on August 25, 2013, 08:50:27 AM
Hi MenofFather,
One of the most overlooked root cause which result in poor efficiency or power transfer  between eg:transformers,coil is "impedance mismatch".
A simple scenario to describe is amplifier  system.If a amplifier output is design for 3Ohms speaker.You will have to use 3ohms speaker.By putting 8Ohms speaker to amplifier the sound effect is less than desired.
T-1000
    MenofFather, & T-1000:
  Can someone please check with Akula to see if these new akula 0083 circuits diagrams are really from Akula himself, and that the circuits are correct, and that they WORK, as shown.  And, that it's ok with him to show them on the forums, and Internet. Please.
        NickZ
the ak.png does not seem to be akula's own drawn circuit and it is not finished on high voltage end.
Quote from: baroutologos on August 25, 2013, 08:50:25 AM
@T1000
Too many to ask? :P
If you manage to get NMR situation this may be expected.
What I wanted to point in http://www.youtube.com/watch?v=qmirRN3O6Ko&list=PL1B521AB8CEB7C605&index=95 video (and following) - when you introduce 90 degrees magnetic field on resonant frequency the ferrite rings get close to NMR conditions there and the current consumption drops on primary of transformer. This was seen in many devices and even Kapanadze devices might had that as well.
