0 Members and 53 Guests are viewing this topic.
baroutologos
Quote from: T-1000 on August 25, 2013, 10:21:22 AM
If you manage to get NMR situation this may be expected.
What I wanted to point in http://www.youtube.com/watch?v=qmirRN3O6Ko&list=PL1B521AB8CEB7C605&index=95 video (and following) - when you introduce 90 degrees magnetic field on resonant frequency the ferrite rings get close to NMR conditions there and the current consumption drops on primary of transformer. This was seen in many devices and even Kapanadze devices might had that as well.
1st of all i do not think the video shows NMR at all.
2nd assuming we somehow manage to get a NMR condition, as i see it, the stimulating signal (perpedincular RF to magnetic field) will induce Larmor resonance that in turn will produce a "signal" that must far surpass in terms of energy the received by the core energy of the RF frequency.
Has anyone heard something like that? I have not for sure.
3rd What winding topology can receive that NMR signal, capture it and turn it to useful power?
ps: too many assumptions on the row
TheCell
@T-1000
I have a few understanding questions about this experiment of Ruslan.
Based on his YT video, I have drawn a schematic .
Does it represent the experiment in his YT video?
http://www.youtube.com/watch?v=xuKiLjv0UqY
With a relay I pulse this one coil and can vary the space mark ratio
of the applied pulse. A compass nearby the coil deflects only slightly,
not as in his film.
The only drawback of my flyback transformer (without diodes) could be
that one connection of the HV winding has a strong capacitive effect on
the other connections of the flyback, because you don't need to connect this
lead that is normally connected to ground. But there is no galvanic connection
of the HV winding to other connections of the flyback. If there is an arcing
in the transformer (although I don't here one) it could provide a connection
during operation.But how could I know...
Therefore , if there is a strong impulse , that should proceed trough the
thick copper wire to the ground , this capacitive effect could hinder it from
doing so.
BTW :
If you look at Fabrice Andres flyback : he uses also one like in the video of
Ruslan . The HV winding is completely the only winding in this plastic case.
Is this a must?
You see even these simple setups can't be done, there is no sense to proceed
with the more complicated. There should be an entry point for getting this effect.
He is not using a ferrite core, so NMR with ferrite can be excluded as an effect.
So what remains ? NMR with copper, an electron avalanche effect similar to radio
tubes, which tiger showed , using radio tubes not using the heating filament.
verpies
MenofFather
How I heard, that author of this video, TheCell, say letter, that this is influnce of hight frenquency to generator.
penno64
What if it was this simple -
FROM EF -transformer with no energy invested for reversal of polarity    I am trying to understand what makes Figuera's machines so distinctly different from "normal transformers and generators" that they can produce more out than in.
After reading some of the interesting contributions to this discussion I started to read some of the translations of Figuera's patents provided by hanon1492 and the explanations of Patrick J. Kelly which are accessible at "rexresearch.com"
It is now my understanding that the inducing electromagnets (aka primary coils) with their poles N and S never change their polarity. Only their intensity changes due to the resistor-commutator.
So, the machines produce AC-power in the output coils "y" because the primary coils provide changing field strength, yet never revers their polarity.
I think the saving in input energy - as a consequence of not having to reverse the polarity of the metal cores of the primaries, contrary to normal transformer operation - is Figuera's basic concept.
Edit:
In my understanding the polarity of the cores of the primary coils in Figuera's arrangement is reset by the earth's magnetic field.
How profound is this post by Marxist on EF.
Can you now see the three core transformer?
Penno
